Question about Metolius Rock & Ice Climbing
How can buildings act as climatic filters - Metolius Rock & Ice Climbing
  • 121 Answers
Posted on Oct 15, 2009
18 hp v twin Kawasaki won't idle acts like chock is on, not getting full rpm, new carb new fuel pump new air filter runs same without air filter
have u adjusted the carb ? motor with lot of hrs the compression air intake wont be the same as a newer motor like the carb is. feul lines n pump not getting dirt build up from tank?
Apr 17, 2017 | kawasaki Motorcycles
Hi i have a Isuzu kb 300tdi lx when i start the vehicle after standing for 6 hours and more the oil lights burns for +- 3 seconds what can be the problem
Your oil pressure in every engine has to build up! What this is telling you is the bearings and oil channels have lost the oil pressure! Don't be alarmed this is a normal occurance! You can use a higher viscosity depending on where you reside? In warmer climate states a higher viscosity oil can be used like 10w30 or just 30w oil in colder climates a lower viscosity can be used like 5w or 10w generally the oil pressure taking 3 seconds to build might be the oil is due to be changed as the viscosity has been degraded or the oil pump has wear on it but as long as your pressure climbs and doesn't stay at zero you are safe if it goes above its normal position you have either a spun bearing or a stopped up oil filter not allowing the oil to travel and build up pressure!
Jan 16, 2015 | Vehicle Parts & Accessories
Fuel filter land cruiser
Well, the fuel pump may be going bad. There's a fabric screen on the pick up tube in the gas tank that may be plugged. Look in the gas tank for sludge build uo.
Jan 24, 2014 | Cars & Trucks
Dryer not heating checked heater it is ok what else can i check
Make sure lint filter is clean - all the way through the components from where it leaves the drum until ir exits the conduit to the outside of the house. Many times the lint build up can block the air flow and keep the unit from functioning efficiently. This is probably true more in humid climates but I have had this happen in the Las Vegas desert as well.
Aug 16, 2011 | Frigidaire FEX831CS Top Load Stacked...
How often do i need to replace my fuel filter?
SIMPLE MAINT SCHEDULE , IS CHANGING IT ONCE A YEAR, but it depends where you live, If this truck is a diesel & you live in a northern climate, change your filter once a year but not until you know for ceretain that you are buying winter grade fuel, ie: nov
Reason for this is that there will be wax/parafin build up in the filter that your ran on the summer fuel, it can congeal in the filter in winter becasue of this build up. If you replace the filter in late autumn, then tat filter will not have a congeal problem because the there hasnt been anything but winter grade fuel through it, , and its safe to run all next summer , but the summers residue will cause problems next winter , so change again in late autumn .
Sep 27, 2010 | 2001 Dodge Ram 2500 Truck
I just bought a CLIMATE KEEPER ceramic heater model #HC-0104m, it does not have an air filter to filter the air going tnru the heater elements, what happens when the elements get stopped up and they will...
warranty is usually 90 days parts n labor. when the cells build up with lint and dust, the elements may burn it off but if its really stopped up, blow air through it in the opposite direction. use a blow gun on an air compressor.
Oct 25, 2009 | Heating & Cooling
How can a building act as a climatic filter? How did it come that man should build? I have been giving assignment and i have done my best to get answers for those two questions i have asked but i have not...
You want to filter the climate? Which part, how much, what do you want to remove from the climate? Man builds for something to do so that he doesn't have to think about his precarious position before GOD.
Oct 04, 2009 | General M-D Building Products Purpose Box...
98 GM 5.7 slugish @ 70
Sounds like it is starving for fuel...the other guys sound right...check your fuel filter and fuel pressure...if the filter is nearly stopped up the pump would build pressure which would "push" past the filter and make it feel more powerful...then as the pressure drops it starts to starve again until the pressure builds up enough. Also, with the vehicle parked and running, get someone to rev it up while you feel the air coming out of the exhaust...if it isn't a good amount of pressure coming out of the tailpipe, your converter may be stopping up. be careful not to get burned by the exhaust though.
Mar 05, 2009 | 1998 GMC Sierra
Air filter and climate control filter
your climate filter located at glove compartment,you need to take off it,or sometimes it is in the grill near windshield,the filter you need to take off the cover in the engine then follow the airduck
Jun 24, 2008 | Mercedes-Benz ML320 Cars & Trucks
Rock & Ice Climbing Logo
488 people viewed this question
Top Metolius Rock & Ice Climbing Experts
Makenzie Floyd
Level 1 Expert
ray gallant
Betty L Kidd
Betty L Kidd
Are you a Metolius Rock and Ice Climbing Expert? Answer questions, earn points and help others
