Looking for English version manual for Miele Novotronic T 200-53 model as well as Miele Softtronic W 400-15 dryer machine. Please email to nwmsdoc@cs.com thank you so very much
  • 82 Answers
SOURCE: Door stuck closed on a Miele Novotronic W+862!
does the machine have water in it if so the door will not open check filter
Posted on Aug 02, 2009
Gallois
SOURCE: Hi, i have a miele novotronic w 916 and it's not spinning
I mean this is not a filter error and i think the power main board inside on front bottom EL110 has an defekt and must change.
Or you can post the problem on my board www.avpc.de with photos for solving together and find another cheap used power board for it ...
Posted on Sep 09, 2009
reverendrave
  • 24 Answers
SOURCE: replace door seal miele novotonic w 502
Hello mc2739,
It's been awhile for me since I have done this so I searched on the internet and found the following. The instructions are pretty detailed. You may want to contact Miele if any problems
1. Open the machine door.
2. Turn the main power off and unplug the machine from the wall.
3. Completely remove the powder dispenser drawer (it will come out so far (and stop), then there is a small button at the rear of the dispenser which you need to depress to remove it fully, you'll see this button once you've withdrawn the drawer to its stop position.
5. Undo and remove the 3 x hexagonal head bolts surrounding the door seal (they are at approximately the 2, 6 and 10 o'clock positions). Note these bolts actually secure the front panel to the machine chassis, they do not retain the door seal. Don't worry the front will not drop off.
6. Now look at the aperture of the powder dispenser drawer (you have of course removed the actual drawer earlier). Locate the lower left hand corner of the aperture, and you'll see a recessed philips head screw in a hole. Undo and remove that screw.
7. Now, you'll need to get on your hands and knees. You DO NOT need to tilt, or lift up the washing machine to do the next bit. Locate the underside of the front panel right at the bottom. You'll notice that it sticks out about half an inch or so and is proud of what I would call the kick plate which extends right down to the floor. You need to look on the underside of the front panel, about an inch or so in from the left hand edge. There you will see a spring loaded clip which when closed is located within a slot on the underside of the front panel. Using a flat bladed screwdriver, you need to carefully lever the spring clip open whilst gently pulling the whole front panel (from the left side) ajar. It will just suddenly pop out once you've done it.
8. Open the pump access door lower left hand side of the front panel) and unclip the drain tube from its plastic retaining clip.
9. Now carefully swing open the whole front panel, it opens like a door (hinged on the right hand side). It might be a little stiff as there are a whost of leads attached to it, but it is designed to open fully (with the leads attached) to about 90 degrees.
10. Next, unseat the rubber door seal from around the door opening area (on the chassis, not the front panel, obvioulsy), so that the seal the flops away from the chassis and lies just inside the machine.
11. You will notice that there is a thin steel band holding the door seal in place around the drum. On the right hand side (at about the 3 o'clock position), you'ss see a tensioning screw for the band. With a flat bladed screwdriver undo this completely and remove the screw (it is accessible from above with a long screwdriver). Be aware that there is 1 x washer and 1 x 'nut' type fitting that will fall out when you remove the screw. Locate these and retain them for later.
12. Now extend the steel band to its maximum opening (by moving the 2 x lugs apart where the now removed screw was).
13. You can now remove the steel band. Then pull it out through the hole/door aperture in the chassis.
14. Locate the small rubber tag at about the 12 o'clock position where the seal is attached to the drum and tug it. The seal will then come away from the drum. Remove the old seal completely.
15. Using your new seal, place this correctly around the drum (there is a lip on the seal and this has to go over the lip on the drum. Remember, the seal goes on the OUTSIDE of the drum. Ensure the 'tag' is at the 12 o'clock position.
16. Reassembly is then the reverse of removal.
17. Make sure that you do up the retaining steel band sufficiently and that you correctly locate the sela on the chassis front panel (there is a groove in the seal which will locate the seal in the aperture).
18. Finally, once you're done, put the machine through a few rinse cycles (where the water level is high) and look for leaks. If you have a leak, it is likely that your door seal has a rip/tear, or that it has not been correctly located around the drum - in which case you'll need to investigate.
Posted on Sep 17, 2009
  • 177 Answers
SOURCE: How do I use the washing machine, a miele novotronic w 969
The I is the pre-wash and the III is the main wash where you put the soap powder. the # star looking symbol is the fabric conditioner.
If you don't have a manual you can download this from the miele website.
Posted on Jan 18, 2010
Testimonial: "Thanx for the help. I managed to get my first wash very successfully. "
  • 177 Answers
SOURCE: Miele Novotronic W 833 won't drain
hi,
if your washing machine drains into a spigot in the u bend under your sink you will probably find a blockage here. you need to remove the drain hose and have a look in the hole.
if not when you remove the fluff filter have a look in the hole and make sure the drain pump turns freely. you can also run a drain spin cycle with the fluff filter removed and make sure the drain pump is working.
Posted on Jun 14, 2010
Testimonial: "Thank you!"
Miele Novotronic w963 motor does not turn after water filling
Hello, my question is, I have washing machine MIELE NOVOTRONIC W 963, is broken, Which Miele model HAVE SIMILAR MOTOR ,thank you . William
Jan 03, 2013 | Miele Novotronic W1918A Front Load Washer
Unable to find an english operating manual for a miele w822 washing m/c
Hi Dear. I assume this machine made for Nederlands - Dutch market. You can not obtain English manual for it. You may contact your local Miele center. They may able to supply you translated copy of user manual. Thanks.
Note: What I can understand from control panel, buttons from left to right : Door Button - On/Off - Pre -wash - Water Plus (adds more water)- Gentle wash and Short wash then Final spin speed selector.
Right hand side Program & wash temperature selector (Clock wise): Cottons - Minimum Iron - Delicate - Wool - Starch - Spin only - Pump only & Mini Program (Quick Wash)
Mar 07, 2012 | Miele Washing Machines
I need from manual guide on English for dryer Miele t565c
I have a t565c novotronic dryer,the light in the drum comes on but when i close the door and turn it on it want start .?
Dec 28, 2010 | Miele Novotronic T220 Electric Dryer
I dont have manual for miele T5213 so cant tell - should heat button be pressed in for low temp. Doesn't seen to have time difference when drying towels
hi i have a miele t5213 dryer it was ok yesterday but today it is
not getting hot can you help also i dint have a manual for this
machine i lost it during moving house
regards jeff
Sep 19, 2010 | Miele Novotronic T1570C Electric Dryer
Jan 10, 2010 | Miele Novotronic W1918A Front Load Washer
Where is the reset button for the miele t200 novotronic special tumble dryer please
there is no reset button for this unit. if it is not heating you may have blown your thermostat
Oct 30, 2009 | Miele Novotronic T1570C Electric Dryer
Miele T220 Novotronic
Miele is a top notch machine. Try checking your vent hose. It may be blocked in some way.
Jan 28, 2009 | Miele Novotronic T220 Electric Dryer
Wate rleak Miele premier 300
I have exactly the same problem with my new Miele washer dryer - and my kitchen is soaking wet. Have you found a solution ?
Jul 28, 2008 | Miele Novotronic Premier 500 Front Load...
Washing Machines Logo
105 people viewed this question
Top Washing Machines Experts
