Question about Panasonic DMR-E80H DVD Recorder
I needed to replace me hard drive with a 160gb. After repluging, front panel says unformated disc. Help.
  • Obertelli
    Obertelli May 11, 2010
    What are the jumper settings on the back of the new drive? They need to match those on the old drive and from memory I think that the last one I did worked when all the jumpers were removed.
  • 19 Answers
You can format the hard drive through Functions, Disc Setting.
Posted on Dec 14, 2009
IMac won't read Imation 160GB Apollo 2.5
Mac's won't read windows format disc, even if it's capable of reading the files wich I believe Newer Mac Operating Systems CAN DO, it can not read the file SYSTEM used to place them on the disc. You need a third computer. Put the files on a nother computer or two if you need the room or on another media or pocket drive. Use a program that VERIFIES the were moved without errors while copying them, the use the Mac to format the now empty disc drive and download Mac Pooler, or File Stuffer, and copy the files back onto the disc. Now the Mac will be able to read the drive they're on.
Feb 16, 2014 | Imation 160GB Apollo 2.5" Portable USB 2.0...
Replace hard drive
Most of the gateway slimlines are the same.
  1. When looking at the front of the desktop, while it is standing up right. Remove the back right screws (2)
  2. Slide side panel off
  3. Gently pull up the 3 plastic latches for the front cover panel.
  4. This should allow the front panel to slide off.
  5. Now unscrew the screws attached to the ODD (optical disc drive)
  6. Disconnect the cables attached to the ODD and the Hard drive (HDD)
  7. Unscrew the screws to the HDD.
  8. Now put it back together.
Oct 21, 2013 | Gateway SX2855 Case
Can not login to netflix apple tv have the apple
tried unpluging internet access box then repluging it... still says no internet access though the light on internet box shows that it is on
Sep 25, 2013 | Apple TV MB189LL/A 160GB RTL 160 GB USB...
I cannot format my 16 gb pendrive is show unable to format the pendrive
i cannot open or format my 16gb transend pendrive ...when i tries to open a message appeares " please inset a disc into drive "........plz help me..
Oct 27, 2010 | Transcend 160Gb StoreJet 25 Unveils Rugged...
I have a mini simple tech 160gb hard drive that when I plug it in an error message about power surge on the USB port. What can I do to get the data off of the drive
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 17, 2010 | SimpleTech Signature Mini 160GB External...
Tried to setup new hard drive and it froze...help
you need to set the drive, scan it frome windows, or look at the device managment, disk managment located under administrative tools, your new hard drive should be listed there as unhealty or unformated, format it and it should work fine.
May 11, 2010 | LaCie (301015) 120 GB Hard Drive
160gb usb 2.0 portable hard drive that is froz
Try plugging it into a different USB port may not be enough power from that port
Dec 06, 2009 | Iomega Computers & Internet
Broke external hard drive
It depends on how badly bent it is. If you're stable with your hands, and can use a small nail to pry the deformed peice straight, do so carefully. If however you absolutely need to save the data on the drive and can't afford to have the bent peice fully break off, take it to your local computer repair store and they should be able to replace the connection.
May 05, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
Seagate 160GB SATA Hard Drive Installation.
Hi, Was the original 20Gb HD also a SATA or was it installed as an IDE? Try installing a fresh clean Windows rather than the restore disc. However, you will need the drivers for the SATA 160Gb and press F6 when Windows installers ask you to. Post back how things turn up or should you need further information. Hope this be of some idea/help. Good luck and kind regards.
Sep 08, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
Panasonic DMR-E80H DVD Recorder Logo
278 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
