Question about Riso Office Equipment & Supplies
Riso GR3750 has a 'clamp error', does anyone know if this is a common problem and how it may be fixed
  • 4 Answers
SOURCE: Riso HC5500 System Error - Restart!
does the machine show any error code?
Posted on Sep 02, 2009
SOURCE: Riso GR3750 T1 error Drum Jam
The hook is located just above the power supply once the back cover is off. Also there is a drum release centered under the drum that a screwdriver can disengage.
Posted on Apr 22, 2008
  • 4 Answers
I had this problem too: just unlock the hook under the drum; disengage the drum then pull out the drum; then check the home position if not in position open the behind cover, pull the belt until you get the puller to the home position. You will get the same problem if you will not put the main drum puller to the home position. chimuntu@yahoo.com
Posted on Jan 24, 2009
SOURCE: riso gr 3770 error T14
how can i solve the Error T14 for Riso Gr 3770
Thanks
Posted on Jul 31, 2009
  • 55 Answers
SOURCE: riso graph GR3750 marca falla
"Risograph GR3750 marks to fault T11. I need consultation to solve this problem. Or it is necessary to call to technical support?"
Error T11 means: Call service.
Here some details of the error which may help to solve it: Pressure Control Motor Lock • In 100ms from turning ON of the pressure control motor, the encoder sensor cannot detect a pulse. • In 5 seconds from turning ON of the pressure control motor, the pressure centering sensor is not turned ON/OFF. • When the fuse of the main power board is gone.
Posted on Apr 29, 2011
Riso GR3750
this copier can not print envelops
Jul 13, 2012 | Riso RZ220 Duplicator
Riso graph GR3750 marca falla t11 necesito asesoria para solucionar este problema. O es necesario llamar a soporte tecnico ??
Feb 28, 2011 | Riso RZ220 Duplicator
What is a T11 error code mean on a Risograph GR3750?
this problem is on pressure motor, stay in rear part machine,i don´t remember of the code for testing. after i put here, if you need pass e- mail for luizalexdias@hotmail.com
May 05, 2010 | Riso RZ220 Duplicator
Riso GR3750
T2 indicates an elevator motor failure. Take off the back cover and check the lower limit sensor for the paper tray to make sure its not full of dust.
Reset can be done by holding the reset key down during power up.
Test mode is entered by holding down LINE/PHOTO and the M/P buttons during power up.
Test mode# 102 tests operation of the elevator motor.
Aug 27, 2009 | Eagle Signal Br1 30min Reset Timer
Riso gr 3770 error T14
Thanks
May 12, 2009 | Riso RZ220 Duplicator
Riso gr 3750 error T14
Means a clamp error. Inspect the clamp on the drum to make sure it moves smoothly and that that clamping mechanism in the back of the machine works as well.
Apr 06, 2009 | Canon PC-140 Black and White Copier
I need help with the error code. s04-307 in my riso hc 5000
Oct 22, 2008 | Office Equipment & Supplies
Aug 06, 2008 | Office Equipment & Supplies
Riso HC5500 error code
Hc5000 System Error S03-231
Jul 09, 2008 | Riso RZ220 Duplicator
Apr 21, 2008 | Office Equipment & Supplies
53 people viewed this question
Top Riso Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marius Chiriac
paulfvincent
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
