Question about Acer Computers & Internet
Acer Veriton M464 E4700 2.6Mhz cpu upgrade on MCP730 Mobo
Hi, I have an Acer Veriton M464 E4700 2.6Mhz on an Acer MCP730 Mobo, and I'm doing my homework to see about upgrading the CPU when the warrant runs out in 6 months. I've contacted Acer, but once again they keep trying to take money from me by selling me information.
The MCP730 is their own motherboard, and even though it is a Socket775, i'm sure that some cpus are not compatible. Any pointers gratefully received.Thanks in advance.
  • 1 more comment
  • npharrison Oct 07, 2009
    Hi, thanks for writing, but not quite what I have in mind. The main reason, hence me putting that it is an Acer MCP730 Mobo, is that is an Acer original board, therefore the specs aren't widly available.
    Yes, I could do a new Mobo, processors and ram, but with OS, I might as well buy a new pc. So not worth it, especially when with the right info from Acer i could switch processor and cooler. So I'll keep trying.
    PS newegg didn't help with any of the above. Cheers.
    Problem Solver:
  • 5 Answers
Go to www.newegg.com and whatever you want to upgrade click on that item and match it up with your current board (by looking at the specifications and matching them). I suggest to buy a new mobo and all new processors and ram. You can use your old case, hard drive and all that good stuff that is removable.
Posted on Oct 07, 2009
Veriton m264
in bios try all 0,s
Dec 21, 2013 | Acer Computers & Internet
Demounting SATA Optical Drive
Remove the case facia, it's a bit tight so pull firmly but gently.
Then release the green quick fit clip and you can slide the drive out.
Apr 16, 2012 | Acer Veriton M464 (4718235937997) PC...
HOW TO OPEN SIDE PANNEL ON ACER M464
On the rear of the M464, lower right hand side, there is an odd shaped black plastic piece, pull this off and that will reveal a flat metal tab, slide it to the bottom of the machine and hold it there while you pull the side cover off.
Oct 27, 2011 | Acer Veriton M464 (4718235937997) PC...
Need to purchase a motherboard for an Acer Veriton M464
U can purchase motherboard from acer service center.U should check the price at market also.Then take whatever u like.
Jan 08, 2011 | Acer (ACERMOTHERBOARD)
Describe your acer veriton m410 problem Problem: Power supply works but no video or keyboard or mouse. USB mouse was acting strangely before the end
Mobo may be fried. Best suggestion, take it to your local computer repair shop and have the CPU, NPU, Memory, etc. tested.
Mar 08, 2010 | Acer Veriton M410-UD4000C Athlon 64 X2...
DVI output problems with Acer Veriton M464
If you are comfortable with opening the case, you can try this: Unplug the power supply, make sure are constantly grounded (touching metal)remove add-in video card. Locate the "Clear CMOS" jumper (usually 3 pins in a row with two shorted via a plastic jumper). Remove the jumper and short the other 2 pins (if originally pins 1-2 with 3 open, short 2-3 with 1 open) for a few seconds. Then replace on original pins. Plug monitor into motherboard video port and power on. If it works, you can leave as is or try to re-install your video card following the same precautions when opening the case and probably changing BIOS settings to utilize the add-on card.
Sep 12, 2009 | Acer Computers & Internet
Acer Veriton M464 - BIOS options disabled by default
no. BIOS is manually enable and disable hardware function in the machine. it prevent detection of uninstalled hardware.
if you enable all of the options, the machine will not be able to power up because some of the hardwares are not installed.
Apr 07, 2009 | Acer Computers & Internet
Computers & Internet Logo
1,874 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
