I have a kadak easy share printer 5100 and want to print photo size photos but am unable to get the printer off copy or scan and i wnat to press print but this will not register
    Problem Solver:
  • 15 Answers
For this problem, the best thing to do would be upgrading the software and firmware of the printer. The link for the same is
kodak.com/go/5100downloads
Posted on Oct 15, 2009
My calibration page printed on plain white text paper
When you calibrate the 5100 AIO, first, you push in the photo paper drawer until it CLICKS. Next, print an alignment sheet. It will use the photo paper. Pull the drawer out, put the printed sheet in the scanner bed, with the arrow in the right hand corner, closest to you. Press start and it will scan and print a sheet on full sized paper.
If your initial scan doesn't print onto photo paper, you don't have the drawer pushed in the whole way. There is a definite click and the green light will turn on.
May 14, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
How to use photo feature on Lexmark Impact S305
1. From the printer control panel, press the Photobutton.
2. Insert a memory card, flash drive, or digital camera set to mass storagemode.
If document files and image files are stored in the memory device, then pressthe arrow buttons to select Photos, and then press OK.
3. Press the arrow buttons to scroll to Easy Photo or Print Photos, and thenpress OK.
Notes:
• Select Easy Photo if you want to print photos quickly.
• Select Print Photos if you want to customize the photos before printing them.
4. Press the arrow buttons to select a photo printing option, and then pressOK.
Note: You can choose to print the most recent photo, print all the photos,print photos that fall within a date range, print photos by selecting the photonumbers on a proof sheet, or print pre-selected photos from a digital camerausing Digital Print Order Format (DPOF). The DPOF option appears only whenthere is a valid DPOF file in your memory device.
5. Adjust the print settings:
• If you are in the Easy Photo menu, then press the arrow buttons to select thepaper and photo . Press OK each time you make a selection.
• If you are in the Print Photos menu, then press the arrow buttons to selectthe photo , paper , paper type, layout, photo effects, and quality ofthe photos, and to adjust the brightness and color effects of the photos. PressOK each time you make a selection.
6. Press the Color/Black button to set a color or black-and-white print.
When you select color or black-only printing, the light near your choice comeson.
7. Press the Start button.For more info, you can also check the User's Guide for your printer. To access it, on your computer, click on Start > All Programs > Lexmark > S300 Series > View User's Guide.
Apr 08, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
Koadak easy share all in one, won't print in bacl
Check the version of AiO software you are using. We had to re-install the Aio Kodak software yesterday because the print que did not register when I changed the ink cartridges. The AiO would scan, but the computer side still thought it was out of ink.
Perhaps the latest software will fix your problem too.
Juliasew
Jan 30, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Can I scan pictures to my computer?
Yes ... your all-in-one can print, copy and scan.
http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf
Scan an image
You can start a scan from your computer or from the HP All-in-One.
This section explains how to scan from the control panel of the HP All-in-One only. To use the scan features, the HP All-in-One and computer must be connected and turned on. The HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) must
also be installed and running on your computer prior to scanning.
● On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running.
Note Closing the HP Digital Imaging Monitor icon in the Windows system tray can cause the HP All-in-One to lose some of its scan functionality. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software.
● On a Mac, the software is always running.
Tip You can use the HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) to scan images, including panorama images. Using this software, you can also edit, print, and even share your scanned images. For more information, see the onscreen Help that came with the HP All-in-One.
To save a scan to a memory card
1. Make sure your memory card is inserted into the appropriate slot on the HP All-in- One.
2. Load your original print side down in the right front corner of the glass.
3. Press the Scan Menu button.
4. Press to highlight Scan to Memory Card, and then press OK.
The HP All-in-One scans the image and saves the file to the memory card in the JPEG format.
To scan a photo and reprint it
1. Press Reprints.
2. When prompted, load your original photo print side down on the right front corner of the glass, and then do one of the following:
To reprint your original photo using the default print settings
➔ Press Print Photos.
To change print settings before reprinting your original photo
a. Press OK.
Basics Guide 13
HP All-in-One overview
b. Press or to highlight a paper size, and then press OK.
The paper size choices available vary depending on your country/region.
Note Depending on the paper size you choose, you might be prompted to choose a layout for the photos on your pages.
c. When the Fix Faded Original? prompt appears, highlight Yes or No as appropriate, and then press OK.
The HP All-in-One scans your original and shows a preview of the photo on the display.
d. Press OK to display the selection menu.
Tip If you want to print more than one copy of the selected photo, press to highlight Copies, and then press OK. Use the arrows to increase or decrease the number of copies.
If you want to edit the photo before printing, press to highlight Edit
Photo, and then press OK.
e. Press to highlight Done, and then press OK.
The Print Summary screen appears.
f. Press or to highlight one of the following options, and then press OK.
Print Options Enables you to manually specify the type of paper on which you are printing and whether you want to print a date and
time stamp on your photo.
By default, the Paper Type is set to Automatic and the
Date Stamp setting is set to Off. If you want, you can
change the defaults of these settings with the Set New
Defaults option.
Print Preview Displays a preview of what your printed page will look like. This enables you to verify your settings before printing and
wasting paper and ink on potential mistakes.
Print Now Prints your photo with the size and layout you selected.
To scan to a computer
1. Load your original print side down in the right front corner of the glass.
2. Press Scan Menu.
3. Press to highlight Scan to Computer, and then press OK.
4. If the HP All-in-One is connected to one or more computers on a network, do the following:
a. Press OK to select Select Computer.
A list of the computers connected to the HP All-in-One appears on the display.
Note The Select Computer menu might list computers with a USB
connection in addition to those connected through the network.
Jul 06, 2009 | HP Photosmart C5180 All-In-One InkJet...
I cannot scan photographs to computer
hi! there,
well,if you are trying to print a photo under photo album
and you want to select photo or you are to fetch photo, if you click this you are going to menu of your windows exactly, on that you go to my picture,on that menu select your picture to print,if you selected your picture your going back to your photo print menu in this photo print menu it will flash your picture to print,there option there before you print,set all this e.i your photo size 4x6,5x10 or wallet size depend on you,on lay out you have to select how does it print on you photo paper is it 4 pic on one photo paper or 6 etc..the thing is it has you to return in menu in order to flash your photo,this will help you print your own photo no need to go to your photo shop to develop it easy.cheers have a good day thank's to log in fixya don't forget to rate me.
Apr 03, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Kodak Easy Share 5100 will not print after I changed black cartridge
Press copy and photo at the same time and print a demo sheet. Look at the eyes of the two kids in the picture, if they look like zombies, your printhead is clogged. try cleaning the printhead and print the demo again. If it's the same, you need a new printhead. Call Kodak.
Oct 08, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak easy chare 5100 scanner
kodak is the worse i have the same problems just wait till you need new ink
Aug 25, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5100 only prints half the page
My Kodak Easy Share 500 decided to only print 1/2 the photo today.  For over 1 year it has worked just fine.  Any ideas?
Apr 28, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Photos
Does this help? You obviously have to insert the media type into the media slot on the far right.(omoademola) Using the top control panel Printing tasks Scanning/Copying/Faxing tasks Troubleshooting
The top control panel lets you print an image from a photo card, scan a document or image, and copy a document or image with the press of a button.
Button/Light: Function: 1 Power : Turns the All-In-One on or off. 2 Copy: light Illuminates when Copy Mode is selected. 3 Mode: Changes the copy, scan, or photo card mode. 4 Scan: light Illuminates when Scan Mode is selected. 5 Photo Card: light Illuminates when Photo Card Mode is selected. 6 Rotate: Rotates the image 90 degrees. 7 LCD Panel: Number of Copies- this changes the copy count. Note: This feature is not active in Scan Mode. 8 Display: Shows copy, scan, and photo card selections. 9 Resize: Enlarges or reduces the size of the image. 10 Page Preview: Shows a preview of the output. 11 Select: Secures an option. 12 Menu: Provides options for image. 13 Arrow : Scrolls left, right, up, or down. 14 Stop/Clear: Cancels a print job or clears a selection. 15 Color Start: Initiates color copy, scan, or photo card output. 16 Black Start: Initiates black copy, scan, or photo card output.
Jan 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
k24674
jasbo
jasbo
