Question about Acer Aspire 3680 Laptop
Hi, just turned on my acer aspire, and whilst power is going through it, the screen won't come on. is this a common problem?
  • Acer Master
  • 32,281 Answers
Does the laptop appear to boot up but cannot see an image on the screen?
If this is the case the LCD screen maybe faulty.
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.lcdparts.net
Posted on Oct 07, 2009
My Acer Aspire 5810tzg won't start, I've check the power cable and battery and they work fine on other machines, it just won't turn on
There is one thing you can attempt before seeking repairs. You should try a power reset.
1) Unplug the AC adapter
2) Remove the battery
3) Hold down the power button for 30 seconds and then release it
4) Insert battery
5) Plug in AC adapter and see if the laptop can power on
If it does not power on, you may need to seek support with Acer.
Oct 24, 2012 | Apevia Lithium Ion Battery Pack 4400 mAh...
I keep the message General Protection fault with a black screen when I turn my acer aspire 3000 on and it won't go past that screen/What can I do to fix it?
To repair corrupted system file/s, boot up with the Windows installation CD then -
Press R to repair when instructed.
Press 1 or Enter to repair the C:\Windows folder.
Then type chkdsk /r and then press Enter.
The repair process will take quite a long time.
Jun 16, 2012 | Acer Aspire 3000 Notebook
Why won't my laptop boot?
sounds like an unhappy computer try this
turn off computer
press F8 and turn power on at same time
should open to SAFE Mode
run that for a bit then restart
let me know how that works for you
May 22, 2012 | Apevia Lithium Ion Battery Pack 4400 mAh...
Acer Aspire 5732Z won't turn on - the light comes on for a few seconds and then turns off - whilst the light is on the disk drive will open - the screen doesn't show anything
Could be bad ram,hard drive or possibly a bad display panel or video card.Try using different ram and removing the hard drive then try it.Also,connect it to an external display and see if it shows video or not.If after trying these things it still isn't showing let me know and i'll try to help more.
Nov 22, 2011 | Computers & Internet
Hey there! Can anybody help me about my acer aspire 8920g media console is does not work, it will response by touch, showing lights on etc. Play button, volume, nothing does not work. I have try reboot...
I think I have managed to solve this problem
POWER ON THE LAPTOP
whilst its booting up, you can use the FOLLOWING KEYS TO see picture on the screen:
FN + F6
Whilst its booting, also HIT F2, once your in the bios
Go to:
EXIT > LOAD SETUP DEFAULTS
EXIT SAVING CHANGES > SELECT YES
It should then reboot and ... now its working...SO FAR.
After doing this, the screen stays on, operating system loads up fine.
And I have done approx 10 restarts and also approx 5 power downs and then power on.
Hope this helps
Sep 24, 2010 | Acer Aspire 6920 Notebook PC
It is an acer aspire 3680 laptop. when i power it on it says the acer screen and then it goes to a command prompt and say that the operating system is not found. please help me.
if youre sure you have an OS first ,,then go into bios settings(F2 whilst booting) and see if correct boot sequence is enabled,navigate with"tab"keys/arrow keys.save with "enter "key
save and exit once you are familiar with these pages
Sep 10, 2010 | Acer Aspire 3680 Laptop
Red light when i turn on and nothing comes up on screen
hi make sure all cables are connected properly if no look it sounds like you have a memory problem. if you open the side of your computer case you should see a memory stick that looks like this picture below if their is more than one of them remove one and try to turn it on if nothing happens swap them over and try again making sure all power is off whilst going inside you pc . sdram.jpg
Feb 23, 2010 | Acer Aspire SA20 PC Desktop
My Acer Aspire 5920 won t turn on The battery light blinks but it is plugged up
try pressing on fn+f5 or fn+f6 a couple of times each. Maybe the screen got switched to projector status by mistake.
Jan 07, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5100 crashes when not plugged into charger.
yeppers..power supply is on multi colored unhappy mode..you'll need a new one..
Mar 21, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 3680 Laptop Logo
77 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
