Question about Brother LS-2125 Mechanical Sewing Machine
The needle will move but bobbon wont spin
The needle will move but the whole bottom part bobbin ect. won't even move just the needdle
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 152 Answers
If the mechanism that the bobbin case it attached to doesn't move at all, you have a problem in the drive system of the machine. Either a screw has loosened in one of the gears or in the linkage to the bobbin area from the top of the machine. Unfortunately a trip to your service tech will be needed.
Posted on Oct 07, 2009
Thread keeps getting tangled in bobbon and wont sew
try a new needle
make sure the bobbin is inserted correctly,, counter clock wise
also check the upper thread tension, also check to make sure there aren't any loose thread or lint in the tension disc area
make sure the top thread has not come off the thread take up lever
check in the bobbin area for lint or loose threads
Dec 15, 2014 | Sewing Machines
try changing the needle
rethread using EVERY thread guide
make sure the thread has not come off the thread take up lever
make sure the bobbin is inserted the right way--counter clockwise
make sure the bobbin case is inserted correctly if it's a side or front loading bobbin
clean in the bobbin area and under the needle plate
NEEDLE THREAD WILL NOT PICK UP BOBBIN THREAS
you should try these needle called the organ needle they have 10 pcs. HAx1 130/705H 15x1 size 100/16 these needles are longer and strong . Maybe the one you have is too short
Oct 19, 2014 | Elna Quilter's Dream 6003Q
My sewing machine is properly threaded up etc but will not catch the thread from the bobbin please help..
Your timing is off, remove the floor plate on the table and run the flywheel over by hand, the needle should bottom out and start its up stroke. At this  time the hook on the bobbon carrior should pick up the loop in the thread. If not loosen the set screws on the back of the bobbon  carrior and adjust.  What type machine is it ? and model number ,, let me know. trisquare@frontier.com
Apr 22, 2011 | Sewing Machines
How do you thread the bottom bobbin?
Depends, it is a top load bobbon or does the bobbon go below the needle shaft. ???
Just remember that when you place the bobbon into the shuttle the tread always has to pull clockwise. So if you are holding the bobbon facing you the thread comes from the top to the right.
Lay the bobben into the shuttle making sure you pull the threads in a clock wise motion until you pull it under a metal point that looks like a flattened needle. This is also your bobben tension and then take your hand and turn the clutch wheel slowly. You will see the thread loop around the bobben thread and pull it up.
Dec 20, 2010 | Singer Sewing Machines
I have a Janome Model DC 3018.My problem is that bobbin thread goes around several loops and jams ( it will not come up). What should be done to correct this?
It is probably one of two things, the upper thread is not in the take up lever "this is the lever that moves up and down with the needle and is located at the top pf the machine when the needle is in the up position or the bobbin case is damaged. If the bobbon case is damaged, it neede to be replaced.
Good Luck
Oct 18, 2010 | Janome Sewing Machines
When the needle goes down, it doesn't pick up the bobbin thread
There are several reasons for this problem and it could be the result of one of the following:
1) the bobbon thread and threaded incorrectly (the thread should be spinning of the bobbin clockwise),
2) the incorrect bobbin type is being used (eg flat instead of the bevelled type),
3) the incorrect needle is being used (rounded instread of flat and viz )
Aug 16, 2009 | Sewing Machines
Neddle hitting the bobbon
does the hook assembly move when you turn the handwheel? If no, then your hook drive gears are shot.
Jun 07, 2009 | Brother LS-1217 Mechanical Sewing Machine
My machine will not sew
When sewing anything that is rubberized you should use silicon spray this will help the fabric move along and will keep the needle from accumulating the rubber buildup and sticking in the bobbon casing.
May 20, 2009 | Sewing Machines
Brother LS-2125 Mechanical Sewing Machine Logo
108 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
