Question about Dell OptiPlex 210L PC Desktop
My graphic on board display problem..can i flash bios
  • 252 Answers
Yes, you can flash the BIOS but be very careful. First see if the updated BIOS upgrades video issues.
You have to give more information. Is it not working at all?
Have you tried a video card in the AGP slot on the motherboard?
Posted on Oct 07, 2009
  • 728 Answers
Hi cinkaduk,
I can't necessarily determine what is wrong with your graphic's based on the information that you gave, but it never hurts to have current bios and update your drivers on any machine. You can find your HERE. Make sure you enter the correct os and then you'll be on your way.
Good Luck,
and don't forget to leave a rating,
Thanks
Mark
Radeon hd 6780
you may need to enter the BIOS and change the graphics settings to external graphics else it will try to use the on-board graphics, which won't work if you have disabled the drivers
Start from scratch, reinstall windows 7 then check the BIOS is set to use on-board graphics. Does the display work ? if it does proceed to the HD6780. Put it in the slot. boot to BIOS ad change to selection to external graphics or whatever is appropriate,
Then go to the AMD webpage if you can and use the sanner to automatically find the driver for your card and automatically download and install. be aware that it may try to install software that you don't want by default. If don't want the software, deselect it it (usually by unticking boxes)
hope this goes well
7.March.2015
Apr 28, 2014 | ATI Computers & Internet
Why some graphic motherboard in Graphic card port disply came but in normal display not came
Difficult to understand your question.
If an external monitor works then the problem is Cheapest to most expensive:
MB to Power inverter cable is bad (No light to board) to check shine a flash light at you screen if still black not this
Power inverter is bad
Cable from Motherboard to Laptop screen is bad flashing on wiggle test will show flickering image
Display panel on laptop is bad if this is the case replace the Display cable/ Inverter power cable/LCD
this may still not solve the problem if you are not sure take to a local repair shop
Mar 30, 2013 | AMD 486542-001 - HP Pavilion DV7 Series...
SIS Mirage 3+ Integrated Graphics is not working
If you have the on-board graphics enabled in the Bios and have the proper drivers installed for your graphics chip then Yes the on-board graphics chip is dead.
Aug 19, 2012 | ASUS Computers & Internet
I have new intel dh55tc . I get display through nvidia graphics card . can I get display through vga.
Hi.
You can get a display through > DVI, VGA, HDMI which are on-board. You can also use the nVidia card which may be better.
Regards.
Jun 15, 2011 | Intel DH55TC Motherboard
No display on monitor & if ram open and restart on then no sound on buzzer.
*Please Read full post before trying Also download the Online manual for this motherboard it takes only a minute and probably will answer a lot of questions you might have regarding *********** Board.*
Um... i am assuming your able to still see the display on the monitor if you plug your monitor into the on board video card. I am also assuming that the problem your talking about accursed when you plug in a video card into *********** board and then plug your monitor into that video card. I am also assuming your graphics card that you want to plug into *********** board is a AGP slot card.
If both of these conditions apply to you then try this.
Start your computer with your on board graphics card and unplug any other graphics card form *********** board.
Next go into your bios, and follow these instructions:
Go to "Advanced", "Chipset", And then "AGP configuration".
Next change your "Select AGP 3.0 Data Ratio" to "4X".
Next change your "Graphics Adapter Priority" to "AGP/Int-VGA"
*make sure its set to" AGP/Int-VGA" or your display will not work and you will need to reset your bios via the mother boards jumper cables.*
After that hit esc and go to "Exit" select "Exit
Sep 24, 2010 | ASUS K8S-MX Motherboard
GA-K8VM800M - No Display
hi it could be your on board gpu these are not changeable, you could also check in the bios weather the first graphics display is the on board one and not an external one, the only way you can do this and also check to see if it is your on board gup is put in an external graphics card if this works then it is possible that your gpu is u/s, but check in bios first it might be just the setting that needs changing....hope this helps
Feb 22, 2010 | Gigabyte GA-K8VM800M Motherboard
Can u see the different of system board 374709-001 vs 374711-001
HP probably isnt lying to you. the video chip they replaced, 374709-001, was 128 Mb chip, your new one is 256 Mb. When HP installed the new one, the most likely failed to update / reinstall the bios. If the bios was not updated, the computer would not recognize the extra 128 Mb of graphics, as graphics chips are not plug and play.
If you provide me the model number of the computer i can link instructions on flashing the bios; However, i would call HP and see what they can do.
~gnomer
Feb 01, 2009 | ATI RADEON X600 Pro, (128 MB) PCI Express...
Motherboard bois copier software
YOU CAN DOWNLOAD THE BIOS FLASH FOR THE BOARD TO BOOTABLE MEDIA AND FLASH/UPDATE THE BIOS.THIS MAY WORK.RICHARDM69
Dec 04, 2008 | Intel Motherboard
Motherboard installation
Hello mecompe,
If you installed an AGP graphics card before your fist boot of the system, you will not receive display. By default the onboard graphics is set to boot display. (If this is the case, remove the AGP graphics card & boot the system). The Asus P4SGX-MX can only use a 4x AGP 1.5volt (only) card.
There is an order of sequences to perform before installing/ adding an AGP graphics card on to the board when the board also uses an integrated graphics card.
First, shut down the system & unplug the power supply from the PC. Connect your monitor to the VGA port at the rear of the board. Remove the AGP card. Re-connect the power supply & boot the system. You should have display? Re-boot the system. As the system starts up press the delete key on the keyboard every 2 seconds. The bios main menu will load. (Open your manual). Go to
section 2.4.3, page 2-20 under Advanced, PCI configuration. Set Primary VGA bios to
[AGP VGA Card]. Save the bios & exit. The system will auto restart. Press & hold the power on/ off button on the PC case until the system shuts off. Unplug the power cord from the PC. Insert the AGP card into the AGP slot. Connect your monitor to the AGP card.
Check all internal data & power cables, (Incase something came loose). Re-connect the power cord & boot the system. You should have display! Install your video software.
If your using the integrated VGA PCI graphics card, go over the bios settings page 2-18 & 2-20.
Need the Asus manual? Click this link;
http://support.asus.com/download/download.aspx?modelname=P4SGX-MX&SLanguage=en-us
To view the manual you'll also need Adobe PDF reader, click this next link for Adobe.
http://www.adobe.com/products/reader/
(The green led (light), means standby. The board is receiving 5volts DC.
If you still do not have display just let me know.
Good luck mecompe!
Mike
Oct 28, 2008 | ASUS P4SGX-MX Motherboard
Dell OptiPlex 210L PC Desktop Logo
83 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
