Question about Ryobi Garden
Chainsaw brake stays on - Ryobi Garden
  • 1,498 Answers
Hi Peter,
I'm sure you've tried the the full range of motion with the Guard.
You've inspected the drive gear for obstructions and all the other external "Could Be's". So that leaves internal, either the link between the guard and the brake has jammed or something is interfering with the clutch.
If it's still under warranty, bring it in.
If you have never worked on a chain saw before, I'd advise getting it to a shop.
If you are comfortable taking the machine apart and confident you can get it back together, clear a work area that you don't mind getting oily. Pull the bar and chain. And start on the housing.
When you get the clutch exposed, the band around it is the brake.
Work the guard to see what the problem is.
If you can't get it to release, comment me back with a detailed description of what you found. We'll take it from there
Best regards,
Mike
Posted on Oct 07, 2009
Chainsaw brake
if it is new take it back for a warranty adjustment or repalcement
Sep 09, 2016 | Ryobi Garden
Cant stay running
What to do if your chainsaw won't stay running?
arborist101.com/what-to-do-if-your-chainsaw-wont-stay-running/
Idle ports may be plugged or blocked - This is the small ports in the carburetor where the fuel passes through when in idle. ... Vent in the Fuel Cap is plugged - If the vents in the fuel caps are clogged the fuel becomes vacuum locked. ... Starting with the High Speed screw, turn it ...
Craftsman 16" Chainsaw Fix - Won't Run - Fixed! - YouTube
? 1:32
https://www.youtube.com/watch?v=aIUVQziXBPY
Jul 7, 2011 - Uploaded by BriggsRepair
Is this Craftsman 16" chainsaw broken? Hardly. Watch this carburetor fix and how it runs brand new!
Chainsaw won't stay running - DoItYourself.com Community Forums
www.doityourself.com/.../360759-chainsaw-wont-stay-running.html
Sep 20, 2008 - Chainsaw won't stay running. Craftsman 16" chainsaw, fuel/oil ratio 40:1. Saw is 10 years old, used once or twice a season. Last used in spring ... chainsaw wont stay running
Aug 1, 2015
Craftsman chainsaw won't stay running
Oct 30, 2010
Chain saw won't stay running
Oct 2, 2006
Poulan Chainsaw - starts but won't run
Apr 28, 2006
More results from www.doityourself.com
Why won't my chainsaw stay running? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 31, 2016 | Garden
My chainsaw starts and runs but the chain won't turn so it shuts itself off. What am I doing wrong?
Check the braking bar. You usually start the chainsaw with the brake in the 'on' as a safety feature. You have to release the brake before powering up the chain, otherwise you are fighting against the brake and the engine will shut down. Hope this helps.
Jul 09, 2014 | Garden
Ryobi pcn 4040 chainsaw won't start What is the
1st add fuel/oil mix to fuel tank , then top off oil tank with bar oil , place saw down on flat surface , press 'ON" button above trigger handle to ON (its marked on case) then pull out blue choke handle till it clicks and stays out , press primer bulb with thumb 8 to 10 times bulb will become harder to press as it fills carb , push chain brake forward (on) ` place left hand on top of saw and right hand on start cord , hold saw down firmly and pull cord vigorsly several times till it sort of starts (sound) , squeeze trigger in and pull cord once more , saw should take off running , chain wont move ,walk to wood pile then disengage the chain brake and cut wood , if saw fails to start after this procedure then there must be a fault in saw , consult a exp small engine dealer for repairs
Sep 01, 2013 | Ryobi 18-inch Electric Chainsaw Chain Saws
Problem chain / break cover chainsaw
Hi, hold the cover in a vice where the bar nuts normally tighten up to, then pull the chainbrake lever back in the direction the handle bar would be. You will feel a click and the lever will stay back and the brake band will be released. Then refitted cover to the saw. Regards Phil.
Aug 20, 2012 | Garden
Chainsaw chain brake on Ryobi PCN 4040
remove the cover and check the spring
Apr 13, 2012 | Ryobi Garden
Chain will not turn when on or off
Sounds like the chain brake may be engaged. You should have a lever that looks somewhat like a handguard on the top of the chainsaw, right in front of the handle you hold the saw with. It should "snap" when you disengage the chain brake by pulling the lever back towards you.
You can find replacement chainsaw parts at PartsBuggy.com.
Sep 15, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Chain on chainsaw will not turn at all when on or off
Sep 15, 2011 | Garden
I have a Homelite Chainsaw 45cc Power Stroke. Model No. UT10946D. The chain brake is always applied. Brake lever will not latch in the released position. I've disassembled it and do not see anything...
I have the same model (ut10946d) and used it for less than 2 tanks of gas when the chain froze. I noticed it was slowing down and it seemed like the chain brake was not disengaging and staying in the "unlocked" position.
I took the tool apart today and found that the band that rubs on the clutch to stop the chain was dragging on the clutch because it doesn't disengage all the way. The heat from the friction melted the plastic parts around the clutch housing and crankshaft. So now I have a chainsaw that I bought new, used for less than an hour, and is now junk due to poor design and/or product control.
I WILL NEVER BUY ANOTHER HOMELITE GAS POWERED TOOL AS LONG AS I LIVE. THEY ARE PURE JUNK!
My solution, call homelite and complain about it, maybe they'll stand behind their design flaws - but I doubt it.
Jun 18, 2010 | Garden
Ran chainsaw with brake on and chainsaw will not start now
Hi
Too much fuel at the sparkplug.The fuel accumulated in the cilinder because of brake left.Put the button in off position,remove the sparkplug and dry it,pull the starter for a while until the fuel is out from the cilinder.Put the sparkplug and start the engine.
best regards savumihai71
Dec 19, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
67 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
