Question about Hyundai ImageQuest L70S 17" LCD Monitor
Hello. I have Hyundai imagequest L70S LCD monitor, but it does not support some resolutions i need to use. Can i somehow fix it?
    Problem Solver:
  • 13 Answers
I don't think so.
Posted on Oct 07, 2009
Bogdan
  • 198 Answers
SOURCE: Regarding L1515S 15" LCD Monitor Resolution
Hello mallik, The LCD monitor is actually a active matrix of small transistors (3 for each pixel). They have one native resolution, a FIXED one for example you monitor has 1024 x 768 pixels. This results in 786432 pixels displayed on the screen. Because each pixel is controlled by 3 transistors there will be 2359296 transistors controlling your entire screen. This is a fix number. You can't raise the resolution to 1280 x 1024 because this will require as you can see now... a lot more transistors on the same surface. All you can do is to lower the resolution, in this case 4 pixels (12 transistors) form a larger pixel acording to that lower resolution. The image can look blurry in these situations. THe bottom ideea is that a LCD pannel (more corectly said, TFT (thin transistor film) pannel, has one optimum resolution, it's native one. The higher the better, when choosing one to buy, but you can't raise the resolution over that. You can just lower it. It works different then the normal conventional CRT monitors. Sorry for my bad english as I live in a non english-speaking country. Also if you have anymore questions please post a comment.
Posted on Mar 25, 2007
SOURCE: Monitors goes black - Hyundai Q17
Thanks. I sent the monitor to Hyundai as it was under guarantee. After a 3-months-wait (!!) it came back with a new bulb.
Thanks !
Posted on Oct 31, 2007
SOURCE: L70N Monitor driver
http://driverscollection.com/?file_cid=24622933713hBuWizS5I1EwOBkI
Posted on Dec 20, 2008
SOURCE: I have a Hyundai Image Quest L70S, the screen goes blank
hello, mine lcd it is extinguished continually. I have tried to open it and seems us or a problem on a condenser dell' inverter. Someone you would know dirmi where to find the outline in order to understand like repairing it?
Posted on Jan 31, 2009
  • 152 Answers
SOURCE: Hyundai imagequest Q17 montior problem
ontherhodes5, Your monitor will probably need servicing for one or both power supplys in the unit. Yes, If you can get a new oem Switch-mode-power-supply/inverter board you might get it working. I suspect that it (smps) can't supply the voltages needed by the logic-interface board- therefore no digital data can be processed for display on the screen, which should be white-bright but now only gray. (dim) because the 1000v ac from inverter circuit is also missing 10to40% of it's output. Your best bet will be to find out if Hundai can do a repair/swapout. You send yours+$40 to $90 and they send you a Refurbished same model with new CCF tubes, Inverter board, smps board. It seems that sooner or later these lcd ccf (cold cathode fluorescent tube backlights) will need servicing. Don't feel bad about this monitor. There are about, (guess only) 2500 more of all makes and models with similar power supply problems out there. To see whats inside a lcd search YOUTUBE for vids of servicing or repair of lcd screens or similar.. also www badcaps.net ??? or lcdrepair.us or visit electronicrepairguide.com run by a Jestine Yong. Ignore the sales pitch and just look fyi. hope this was of some help. drop me a note if possible. I'm louie12fix on fixya or lmistyrel@ aol.com BYE
Posted on Mar 30, 2009
Video Mode Not supported message when connecting my laptop to the monitor
Your lap top video resolution is set too high for the external monitor to handle, your monitor can only handle up to 1280 x 1024 @60Hz. You need to lower the PC resolution.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 25, 2010 | Hyundai ImageQuest L70S 17" LCD Monitor
Do I need a special audio wire to go from my monitor to the pc
Just mini stereo phone jacks male to male, Green audio line out on the PC to Monitor audio line in at the monitor. Try RADIOSHACK.
May 19, 2010 | Hyundai ImageQuest L70S 17" LCD Monitor
When i turn on the screen it says video mode not supported
you may have configured the resolution or video settings to one setting that is not supported.
this monitor should support 24 bit color depth and make sure you're resolution is not larger than Native (Recommended) Resolution1280 x 1024
right click on an empty space on your desktop and go under properties then click on settings tab and change values accordingly.
Mar 26, 2010 | Hyundai ImageQuest L70S 17" LCD Monitor
Power on Green Light Blinks but no picture. Will not turn on. Hyundai Image Quest L705
bwpvemail, The units "switch-mode-power-supply" may be in shutdown mode. A tech will need to evaluate. Check to see if Hyundai has a refurbished swapout+cash program?? It's that or trade in for new wide screen, so the tech in the store "back-room" can possibly put $8 in new filter capacitors in your unit and with a little luck will have a 17" L70s for 1-2 more years use. 12fixlouie
Dec 08, 2009 | Hyundai ImageQuest L70S 17" LCD Monitor
Jan 08, 2009 | Hyundai ImageQuest L70S 17" LCD Monitor
L70S Issue
Not sure if this helps but run my computer in safe mode and do a virus scan. This worked well for me, hope it helps.
Oct 12, 2008 | Hyundai ImageQuest L70S 17" LCD Monitor
Monitor Speaker
Make sure the speaker input from the computer is plugged into the back.
Make sure the volume control is turned up and not muted on the front.
Mar 14, 2008 | Hyundai ImageQuest L70S 17" LCD Monitor
Words are not clear
if its a crt monitor dump it,if its a lcd monitor try changing your screen resolution from display properties,or on the monitor check the brightness and contrast controls.
Dec 26, 2007 | Hyundai ImageQuest L70S 17" LCD Monitor
Hyundai ImageQuest L70S 17" LCD Monitor Logo
236 people viewed this question
Top Hyundai Computers & Internet Experts
rhodesworks
 Zackery G
Zackery G
Level 1 Expert
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
