Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Coffee not coming through with crema head after de scale?
    President:
  • 1,618 Answers
Is the discharge grounds wet or dry?
If wet then clean out screens on brew unit, they might be blocked.
If dry run descale again that might clear out the blockage.
Posted on Oct 07, 2009
My bes870 will not create enough pressure to form a good crema ,grind setting is 2-3 .Amount of ground coffee is correct but the pressure does not go much past the pre fusion pressure .The machine has...
For an 8 month old machine it should still be under warranty unless commercial use. (similar unresolved Q posted http://www.fixya.com/support/t20409606-get_pressure_up).
Jul 20, 2014 | Breville Barista Express Espresso Machine...
Tip
De-Scale Keurig coffee units
<br /><br />The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.<br /><br />Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.<br />Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.<br />If you taste vinegar..use more clean water, until the taste is ok.<br /><br /><br />
on Dec 22, 2010 | Coffee Makers & Espresso Machines
My coffee maker has the words de scale in the corner or something like that. Also all the lights are not coming on except the one for the most amount of coffee and it just trickles down to not even half a...
Sorry to read about your issue.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 25, 2010 | Keurig B60 Coffee Maker
When k cup is placed in machine no coffee comes out, with out k cup water comes out
sfd
also clean the holes at the bottom of the k cup holder
Dec 24, 2010 | Keurig Platinum B70 Coffee Maker
Now water only comes out of one hole in head
The head could be blocked up.
Remove the head via the 2 hex screws,inspect and clean as necessary.
Dec 20, 2009 | Gaggia Classic Espresso Machine
Solis SL70 Espresso Machine: Pump Switch Light Turns Off
Mine has always worked that way; it only seems to have enough power to do a single set of 25 second shots before a short re-heat
Aug 02, 2009 | Solis Crema SL-70 Espresso Machine
Inconsistent quality of crema and coffee
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Sep 19, 2008 | Gaggia Titanium Espresso Machine
I de-scaled the coffee maker. Now the water comes out so fast that the grounds are overflowing the filter. Can I calibrate it myself? How?
It sounds like the sprayhead is missing. It looks like a little shower head and is screwed on where the water comes out.
Apr 18, 2008 | Bunn (279000002) Coffee Maker
UNABLE TO GET GOOD CREMA ON TOP OF COFFEE:
It could be. Your grind should determine the amount of time that it takes the shot to pour. Standard is 18 - 30 seconds. I prefer 25. If it only takes 10 sec, your crema will be weak.
Are your beans fresh? Older beans produce less crema. By old, I mean more than a month if properly stored.
What is the temperature of you shots? The water coming out of the head should be about 195 F which makes the shots roughly 170-185. If it's too cold, you'll get worse crema. It's also possible to have mostly steam in contact with the grounds which will give the same results. Both indicate other problems.
Make sure your group head screen isn't clogged. And make sure everything is very clean, especially inside the handle (under the grounds basket - just pop it out with a screwdriver). Good luck!
Dec 16, 2007 | Rancilio Silvia Espresso Machine
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
124 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
