Question about Whirlpool GEQ9800P Electric Dryer
Whirlpool Clean tough gas dryer
I used this yesterday and it worked fine. I started to use it this morning, and all that happened was a humming noise and it will not tumble. what should I do to fix this?
  • terrynic Jan 04, 2008
    Our Whirlpool gas dryer will not start. Prior to this I noticed that the dryer would start before I pushed the "start" button. Now when I push the "start" button I get a loud humming noise. What could be causing this? TLN
  • 833 Answers
Probably, you are hearing the motor turning. The belt likely broke.
Posted on Dec 24, 2007
Whirlpool gas dryer takes longer to dry though it heats up and turns, yet it has a humming/buzzing noise. What could be the problem?
Had the same problem. There was a bit of a kink in the vent duct which caused lint to build up in duct and also inside the dryer itself over years. I replaced the duct and took dryer apart and cleaned out the air passages.It works great now. As for the humming, mine started about 2 1/2 years ago and I still don't know why.
Jun 04, 2012 | Whirlpool Dryers
Whirlpool Dryer Starts fine, but then stops and start button stops working
This is a sign of the Motor failing. The motor is over heating and then wont start again. When the start button is pushed, does it make a humming noise? If so replace drive motor and it will fix it all up!
Apr 24, 2012 | Whirlpool Dryers
GE gas dryer won't start
you need a new motor
Apr 11, 2012 | Dryers
My whirlpool gas LGB6300PW0 dryer won't start. I press the start button and hear a humming noise, but no motor turning over. Please tell me that my 5 yr old dryer doesn't already need a new motor!...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
May 18, 2011 | Whirlpool LGV4634JQ Gas Dryer
Working fine this morn went to use again wont start
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
May 19, 2010 | Whirlpool LER4634J Electric Dryer
Amana gas dryer wont start. just makes a faint buzzing noise
The drive motor starting capacitor is likely dead. This can be tested if you are competent enough to take the thing apart and use an electronic multimeter. Otherwise it is a cheap part to replace, depending on how much the repair guy charges for labor and to be called out.
Mar 18, 2009 | Amana NDG5800 Gas Dryer
Moisture in dryer
is it cold outside clean your vent run dryer with out vent on gas dryer?
Feb 24, 2009 | Maytag LSE7806A Top Load Stacked...
Whirlpool Duet Sport Gas Dryer - Works fine but makes loud noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
Nov 24, 2008 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Whirlpool gas dryer won't start
you most likely have a bad motor. Motors run around 100 dollars since the machine is 20 years old it would be a good idea to replace it with a new dryer. if i were you i would stick with a whirlpool product.
Oct 13, 2008 | Whirlpool GGQ8831L Gas Dryer
sounds like your motor is bad or the start relay on motor.. dont think you can replace just the start relay on that motor
Nov 06, 2007 | Whirlpool LGR3624JQ Gas Dryer
Whirlpool GEQ9800P Electric Dryer Logo
52 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
