Question about Car Audio & Video
Mtx 9500 rubber gasket
Do you know where I can get parts, and price? I need a rubber gasket from cone too basket for a MTX9500series 12inch sub. please advise. thank you Ron rak7roll@yahoo.com
  • 65 Answers
You may find what you need at partsexpress.com . They have everything, plus some. They also have free catalogs which have tons of car audio acessories that you would normally pay an arm an a leg for.
Posted on Dec 24, 2007
I just bought 2 12 inch mtx thunder tc512 to replace my old school mtx blue thunders, everything worked great, but when i hooked up the new 12s i get nothing, zero, zip, nadda, there is nothing wrong
use a d cell battery and touch + of speaker to + of battery and hold it by doin the same with the -'s too if move they work if not there junk
Sep 09, 2012 | MTX Car Audio & Video
I have 4 mtx 9500 12in subs 2 of them is on a mtx 92001 and the other is on a mtx 4001d . would it be better to run all four on the mtx 4001d. for more power and a better sound or how should i run this set...
NEVER mix different power amps. Depending on the ohms of your subs, sell one of the amps, up to you. The 4001 has more power, but either amp will do the job, the amp needs to see a 1 ohm load, so your subs have to be dual 2 ohms, or single 4 ohms to do this. If your subs are dual 4 ohms then you will have to run your amp at 2 ohms which would be have the power, or a half an ohm, (Not Recomended) and be at double the power. You may be able to do a competion sound off and just "Burp" the subs, but at a half an ohm, dont expect to listen to it to long before it goes into protect and shuts down.
Sep 06, 2011 | MTX Thunder Elite TE4001D Car Amp
What kind of sub would go good with my amp the MTX 4105 d amp
you can try the new soundstream T5 or a MTX 9500 but the T5 would sound deeper and cleaner
Aug 04, 2010 | MTX Thunder 4250D Car Audio Amplifier
How can i bridge a mtx 9500 using a mono amp?
You cant bridge it to the MONO AMP . You can only bridge subs & speakers to 2 CH & 4 CH AMPS that are bridgeable. Because if it appears that there is 2 channels on a Mono amp its so its convenient for you to hook up 2 4ohm subs to it easily But both channels are actually connect internally together in parallel inside the amp unlike a 2 channel they are separate.
So just connect your mtx 9500 to a plus and a minus and doesnt matter which since all the + terminals of are connected together and - are connected together already.
Whats important is on the side of the sub/box it reads 2 ohms. The lower the ohms the more power the Mono amp will put out. Mono amps are designed to handle 2ohm loads.
If it reads 4ohms The MONO amp is the wrong amp to use cause the power will be weaker. So if you have a 1000 Watt Mono amp at 4ohms the sub will only get 500 WATTS Max while a 2 ohm will get the full 1000 Watts.
If it reads 4 ohms connect it to a 2CHANNEL AMP and BRIDGE IT (connect + of the sub to 1st channels positive of the amp then connect - of the sub to 2nd channels negative of the amp) . The power will be doubled when you bridge it on a 2 channel amp. NOW if it was a 2 ohm sub and you bridged it to the 2 channel amp it will fry the subs and ruin the amp. 2 CHANNELS CANT TAKE A 2OHM LOAD BRIDGED OK.
Apr 08, 2010 | MTX (SLH-T7512X2-A) Car Speaker
How do i wire mtx 9500 subs 2 10'' down to a one ohm
THE T9510-04 SUBS ARE SINGLE COIL SUBS AND YOU CAN VIEW THAT WIRING DIAGRAM AT THE FOLLOWING LINK:
http://www.mtx.com/caraudio/products/subwoofers/TechData_T9510-04.pdf
THE T9510-44 SUBS ARE DUAL VOICE-COIL SUBS AND YOU CAN VIEW THAT WIRING DIAGRAM AT THE FOLLOWING LINK:
http://www.mtx.com/caraudio/products/subwoofers/TechData_T9510-44.pdf
SINCE YOU NEED A 1 OHM LOAD, I PRESUME BRIDGED AND ARE USING TWO SUBS, THEN HOPEFULLY YOU HAVE THE DUAL VOICE COIL TYPE, AS THEY ARE DUAL 4 OHM AND YOU WILL HAVE TO CONNECT THE VOICE-COILS IN PARALLEL WHICH WILL MAKE EACH SPEAKER A 2 OHM SPEAKER AND THEN CONNECT THE TWO SPEAKERS THEMSELVES IN PARALLEL AND THIS WILL PROVIDE YOU THE 1 OHM LOAD. IF YOU IN FACT HAVE THE SINGLE 4 OHM VOICE COIL VERSION, THEN IT WILL ONLY PARALLEL THE PAIR DOWN TO 2 OHMS. OK. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Jan 08, 2010 | MTX T9510-44 - 10" 9500 Thunder Series...
I have 1 "12" kicker L7 and i got into a car accident. the sub works greath but the outer face has a crack in it.. its not big but i wanted to know what could i do to fix the problem
If the cone has a crack in it, that is USUALLY fatal, but you MIGHT try using the BLACK ABS plumbing glue to repair the plastic.
I don't know what you mean by the front face.
IF you mean the frame around the cone, I would grind out a groove (Vee it) over the crack and mix and fill with JB Weld. Paint to match when the material has set up and is smoothed a bit.
Nov 09, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
I have 2 6x9 speakers up front 4 6 1/2 3-ways
Hello rjmiller4039,
Although amps with 5 channels are pretty rare, you can get one. Alpine, Boston Acoustics, Infinity, JL audio, MTX, and Polk all have 5-channels ranging in price from around $350 up to around $1,000. The Alpine PDX-5 will output 75X4 watts RMS for the front and rear stereo channels and 300 watts to the mono sub channel. It is priced at $599.99 at Crutchfield.
Hope this helps.
Sep 18, 2009 | Jl Audio 500/1 Car Audio Amplifier
Rotten foam rubbers
You can have "The Speaker Factory" re cone them. Call for an est.first Generally gonna be less expensive to replace.
Jun 25, 2009 | MTX Road Thunder RT-1240 Car Subwoofer
Surround problem
if you have woofer in tight enclosure you might want to use a vented enclosure .This will lower speaker suspension displacement .Or if you already have speaker in vented box ,it also possible you have wrong volume box..If surround is just ungluing from basket rim .You can try using GORILLA glue to reglue to rim .If its tearing at cone then lower the volume.LOL
Dec 06, 2007 | Eclipse SW9152 Car Subwoofer
Car Audio & Video Logo
236 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
