Question about Canon Bubble Jet S900 InkJet Photo Printer
S900. Amber power light flashes 7 times then green once. unable to get any further, any ideas please GG
    President:
  • 787 Answers
Probably the waste ink tank is full.Try this:
Turn off the printer.
Press and hold the RESUME button, then press and hold the POWER button.
Release the RESUME button, then press and release the RESUME button two more times in succession. (youre still holding the POWER button during this). The printer mechanics will move momentarily.
You are now in Service mode.
Pressing the RESUME key will select a function; for example, pressing RESUME 4 times will select the clear waste ink counter function. The lamp will alternate color with each key press.
1. service/factory test printout, including ink sensor check
2. EEPROM info printout
3. EEPROM initialization
4. Clear the waste-ink counter
5. Printer model setting. (more selections beyond this- leave this alone)
After selecting mode, press the POWER button to commit the change, and return to the top of the function selection menu. Pressing the POWER button again turns off the printer for a restart.
Posted on Oct 07, 2009
Dell inspiron 1525 - plugged in not charging shown on battery icon. Battery power light blinks 4 times amber then once blue.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. Call Dell for a replacement. (See
Chapter 5, "Getting Help," for
instructions.)
No. Call Dell for technical assistance. (See Chapter 5, "Getting Help," for
instructions.)
Feb 13, 2011 | Dell Inspiron 1525 Notebook
The printer has flashing light, it rotates between yellow and green but never turns to solid green light, It does not accept any print job. Please advise
Issue: Power light (or Alarm and Power lights) alternate(s) between orange and green
Solution: The S900 may require repair
Unfortunately, the issue you describe seems to indicate that your product requires repair service.
Source:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/s_series/s900#ServiceAndSupport
You could try updating the driver, also available at the link above but the manufacturer's website seems definite that repair is in order.
Sorry for this news.
Dec 09, 2010 | Canon S900 InkJet Printer
Power light flashes green once then amber 7 times
change/clean manually the main roller because it observe ink.
Jun 23, 2010 | Canon i950 InkJet Photo Printer
The ready light is flashing green then amber. What does this mean
This lights pattern means the waste tank needs the blotter replaced.
Then once replaced, the tank reset needs to be performed.
Waste Ink Tank Reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and release the Resume button
4. Press Resume button 2 times then release BOTH buttons.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
Jun 15, 2010 | Canon i950 InkJet Photo Printer
When i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked...
when i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked normally after being off for a couple of days, but now it is doing that again.
Amber light flashes 7 times, then green for a couple of seconds, then amber 7 times etc.
Jun 02, 2010 | Canon BJ I6500 InkJet Printer
Won't print.flashes amber 5 times and then green once
Hi try it may work
1. Turn off printer
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 24, 2010 | Canon i860 InkJet Photo Printer
On my ip2000 the power light flashes green then amber and turns itself off
Canon PIXMA IP2000
You may RESET the printer code first if you like or do it after you clean the pad
In some cases you may need to REMOVE THE PRINT HEAD FIRST or the reset code will not work. This was true of the S900 and i960 so, remove the print head first before doing this reset.
This is the correct code for the S and I (like i960) series of printers. (M series below this)
1) Power off printer
2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3) Hold POWER and Release RESUME.
4) Press RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6) Press power to set data.
7) Print away!
For other codes for other printers and more info go here to this big forum (but try the above first) Fix Your Own Printer Generally many of Canon's models use exactly this same code, the i models use the same code, all the s models use the same code.
Dec 01, 2009 | Canon i850 InkJet Photo Printer
Canon PIXMA iP3000 waste ink tank showing nealry full..
Follow this procedure:
1. Turn off printer
Nov 04, 2009 | Canon Office Equipment & Supplies
Loooong boot time
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 10, 2008 | Dell Dimension 8400 PC Desktop
Canon i320 amber light flashing will not print
I believe that 7 amber flashes refer to a cartridge error. Check that the cartridge is seated correctly.
Nov 05, 2008 | Canon i80 InkJet Printer
Canon Bubble Jet S900 InkJet Photo Printer Logo
393 people viewed this question
old marine
old marine
