Pioneer m-770 will not turn on
I have a pioneer m-770 amplifier and as i was playing music it turned off now wont turn on, i opened it and check to see what was the problem and one of the fuses was blown. i replaced it wth 250v fuse from radio schack but when i turned it on the fuse blew and then then i tried swicthing to a 125 v that belonged to the amp but the transistor blew also, i know for sure i need to replace that transistor but what about the fuse and why wont it turn on?
  • mantk1078 May 25, 2009
    Yes i have the same problem in my pioneer M770 will not turn on because the fuse is blown, I replace the fuse with a different Amp.
    but was blew. Maybe something else is bad because i still have the problem.
You probably have a short in the circuit some where. you need to replace the transistor and look at all the solder joints to make sure there not damaged or cracked. i have the same amplifier and i replaced the fuse several times and it blew every time up until the last time when the 4 of the power output transistors blew. what ever you do do not try and power it on till you do all the things i told you or you will have sparks and fire. my mistake cost me my amplifier. but might help you get yours repaired
Posted on Dec 24, 2007
Why pioneer deh-x6500bt wont turn on now?
Axle and Music system are interdependent of each other.
Check fuses and wiring of music system.
Jun 18, 2014 | Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth...
No power to amp
You probably have a bad channel or you could try unpluging the amp for 2 minutes and plug it in again to let it reset.
Jan 26, 2014 | Pioneer A109 2-Channel Amplifier
How do i connect my sony str-de525 to my pioneer cx-770
If you want to connect output of Sony STR-DE525 to input of Pioneer CX-770. Then connect Video/Audio out (or Tape Rec Out) of Sony to CD/LD-VCR input of Pioneer.
May 04, 2012 | Sony Audio Players & Recorders
Subwoofer wont play
Check your rca cables they might be loose or not connected to the amp or the radio. Sometimes those rca cable outlets get worn out by being bumped, moved, hooking up and pulling out connectors. Plug in your rca cords and wiggle them on the amp while radio is on and see if the music cuts in and out
Nov 20, 2008 | Pioneer GM-5100T Car Audio Amplifier
Amp trouble
Check the remote turn on line from your deck & make sure there is 12 volts on it when everything is on. Check the ground, too.
Jun 30, 2007 | Pioneer GM-D510M Car Audio Amplifier
Head unit is on but no sound coming out
I Had That Happen To Me Its A Ground Problem. Check The Negtive Speaker Terminal And The Ground Wire Runing To The HeadUnit This Should Fix It.
Dec 17, 2006 | Kenwood KAC-9152D Car Audio Amplifier
1,346 people viewed this question
 Grubhead
Grubhead
