Question about Canon PIXMA MP130 All-In-One InkJet Printer
Red ink not printing - Canon PIXMA MP130 All-In-One InkJet Printer
    Guru:
  • 389 Answers
Clean the cartridge by utilites. Make sure in that that all colour there is. In properties of the printer make sure that level of the colour are exposed faithfully. Arouse reinstall the driver.
Posted on Oct 07, 2009
When i try to print in color, the red prints as yellow..i am not out of ink
Most printers have 4 inks: Magenta, Cyan, Yellow, and Black. Red requires the printer to print both Yellow and Magenta. If your Magenta isn't printing, red will show up yellow. When you say, "I am not out of ink", you may actually BE out of Magenta, or your magenta ink nozzles may be clogged. I don't know what brand of printer or model you have, so I can't give you exact directions to clean the nozzles. The printer driver may have that ability.
Dec 17, 2016 | Office Equipment & Supplies
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
The red ink is printing yellow
Print a "test" page, to prove that the RED ink-cartridge is not empty.
Run a few "print-head-cleaning" cycles, to make sure that the ink-jets that spray RED onto the paper are not clogged.
Jul 19, 2011 | Brother MFC-5490CN Flatbed Inkjet...
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
My mfc-240c won't print red, even with a new cartdrige.
Try running a few cleanings on the color.
Press the ink button and select cleaning,, do about five cleanings. Print the ink quality test page (from the ink button as well) and see the quality if it improved.
If it still doesnt print its possible the ink is clogged and may need servicing to replace the printer head
Apr 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
Epsonstylus CX7800- when printing color
well you must use the correct ink, you use a very thin ink, that´s way it´s bleeds, the ink is very metal corrosive, and destoy al mec. parts and bunsout the print head. NOTE:you have ruined your printer, the repair is very expensive.
Jan 13, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Red light constantly on and not printing. changed
do you print CD or plain paper, red light is mean jamed paper or change cartridge. Open the top door >press drop ink symbol> look at printer head show on ink ink tray.
Aug 01, 2009 | Epson Stylus Photo R200 InkJet Printer
HP L7680 prints red instead of black
Check your default ink setting if red is default then change it and make black ink default settings.
Thank You
Jul 28, 2009 | HP Officejet 5610 All-In-One InkJet...
Epsonstyluscx3810printer
try reseating the ink cartridges
if you still get the red ink error light - call EPSON with the date&place of purchase of the said inks
Dec 30, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Print diferent colors
Run a test print by pressing ink etc.
Do you see all 4 block lines (BK/C/Y/M) or just BK and red?
It would be helpfull if you post the test print here!
Nov 03, 2007 | Brother MFC 210C All-In-One InkJet Printer
Canon PIXMA MP130 All-In-One InkJet Printer Logo
43 people viewed this question
old marine
old marine
