Question about LaCie Ethernet Disk Mini, 500 GB Hard Disk Drive with Gigabit Ethernet & USB 2.0 Interface, 7200 rpm... IDE Hard Drive
I have a shared folder with files in it. I disabled one share, then the rest of the shared folders went gone. how will I recover the data in it?
  • 728 Answers
Hi sej_nb5,
A shared folder is only a way to access data files from multiple computers. If you are using the external drive, you will need to go and click on ":My Computer" and then find that drive, It will be called "E drive" or "F drive" in the list, and when you click on that drive you will have access to the entire drive, and you will need to navigate to those folders and files. You can re-share the drive when you get to the folder that you want by right clicking and choosing share.
Good Luck,
Mark
Posted on Oct 07, 2009
Tip
Sharing Your Own Computer's Stuff with the Network
To share a file or folder with your fellow computer users, move the file into your Shared Documents folder, which lives in your My Computer window. (You must move or copy a file into the Shared Documents folder; shortcuts don't always work.)
After you place your file or folder into your Shared Documents folder, it appears in the Shared Documents folder of everybody else using your computer.
Administrators can share folders without having to move them into the Shared Documents folder. The trick is to follow these steps:
1. Right-click on a folder you'd like to share and choose Sharing and Security from the pop-up menu.
Open My Computer and right-click on the folder you'd like to share. When the menu appears, select Sharing and Security. A window appears, showing the Properties for that folder. It opens to the Sharing tab.
Right-click on a folder and choose Sharing and Security to share the folder on the network.
2. Click the box marked Share This Folder on the Network.
A check mark in that box lets everybody peek at, grab, steal, change, or delete any of the files in that folder. To let visitors look inside the files but not change them, remove the check mark from the box marked Allow Network Users to Change My Files.
3. Click OK.
Now that particular folder and all its contents are available for everybody on the network to share.
Sharing a lot of folders isn't a good idea because it gives network visitors too much control over your computer. Even if you trust people, they might accidentally mess something up. To be safe, only share files by placing them in the Shared Document folder.
Inside Shared Documents live two more folders, Shared Music and Shared Pictures. Those two folders are also available to any user. So, if you want to share documents with any user of your computer, store them in the Shared Documents folder. When you make MP3s from your CDs, store them in the Shared Music folder, too, so that everybody can enjoy them.
on Dec 01, 2009 | Computers & Internet
Can not connect to window 7 pc. The BP-3600 can connect to the router and out the internet but not the pc. I tried both auto and manual. The error message I get for the auto mode user and password...
Hi.
I quote a comments from Microsoft Support:
This can occur if there is a folder permissions issue or some settings within the Blu Ray Player which might cause this. It could also be the security program blocking the share.
A few things you can try is creating a separate shared folder on the desktop rather than using the shared documents and then try accessing it from the player.
You can also try to disable your firewall and security program and then try accessing the shared folder.
Try turning off user account control and check.
You might also be able to resolve the problem by taking ownership of the folder.
To take ownership of a folder
1. Right-click the folder that you want to take ownership of, and then click Properties.
2. Click the Security tab, click Advanced, and then click the Owner tab.
3. Click Edit. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
4. Click the name of the person you want to give ownership to.
5. If you want that person to be the owner of files and subfolders in this folder, select the Replace owner on sub containers and objects check box.
6. Click OK."
Here the source
Regards.
Ginko.
Dec 31, 2010 | Samsung BD-P3600 Blu-Ray Player
Hi, I have two pc running with windows xp operating system. From User 1 i need to access user 2 windows folder and program files folder otherway around also but I can't how? Even if I shared windows folder...
First thing Windows XP Home Edition will give you numerous problems when sharing files, you should consider using windows XP Pro for that sort of operations.
Assuming you have Windows XP Pro installed in both computers:
1 - Create the same user on both computers ( same account name, same password ) blank passwords are not allow between file sharing as per windows xp group policy.
2 - Create a resource to share ( example: C:\)
3 - Disable simple file sharing
* go to control panel
* click on folder options
* click the VIEW tab
* unckeck the use sharing wizard
4 - Make sure that the user that will be used for authenticating between computers have the proper NTFS permissions and the proper access to the shared sources.
5 - Try to connect to the shared sources when asked for username and password type the credentials of the newly created user.
Now you should be able to connect to the shared sources both ways.
Oct 18, 2010 | Computers & Internet
How can i set up network file sharing
First step is to check if the file sharing option is checked in my computer folder options.
Start- My computer- TOOLS - FOLDER OPTIONS- and click on the second tab VIEW- scroll down to the last option which will show as USE SIMPLE FILE SHARING.
Level 1: My Documents (Private) loadTOCNode(3, 'moreinformation'); The owner of the file or folder has read and write permission to the file or folder. Nobody else may read or write to the folder or the files in it. All subfolders that are contained in a folder that is marked as private remain private unless you change the parent folder permissions.
If you are a Computer Administrator and create a user password for your account by using the User Accounts Control Panel tool, you are prompted to make your files and folder private.
Note The option to make a folder private (Level 1) is available only to a user account in its own My Documents folder.
To configure a folder and all the files in it to Level 1, follow these steps:
  1. Right-click the folder, and then click Sharing and Security.
  2. Select the Make this Folder Private check box, and then click OK.
Local NTFS Permissions:
  • Owner: Full Control
  • System: Full Control
Network Share Permissions:
  • Not Shared
Level 2 (Default): My Documents (Default) loadTOCNode(3, 'moreinformation'); The owner of the file or folder and local Computer Administrators have read and write permission to the file or folder. Nobody else may read or write to the folder or the files in it. This is the default setting for all the folders and files in each user's My Documents folder.
To configure a folder and all the files in it to Level 2, follow these steps:
  2. Make sure that both the Make this Folder Private and the Share this folder on the network check boxes are cleared, and then click OK.
  • Administrators: Full Control
  • Not Shared
Level 3: Files in shared documents available to local users loadTOCNode(3, 'moreinformation'); Files are shared with users who log on to the computer locally. Local Computer Administrators can read, write, and delete the files in the Shared Documents folder. Restricted Users can only read the files in the Shared Documents folder. In Windows XP Professional, Power Users may also read, write, or delete any files in the Shared Documents Folder. The Power Users group is available only in Windows XP Professional. Remote users cannot access folders or files at Level 3. To allow remote users to access files, you must share them out on the network (Level 4 or 5).
To configure a file or a folder and all the files in it to Level 3, start Microsoft Windows Explorer, and then copy or move the file or folder to the Shared Documents folder under My Computer.
  • Power Users: Change
  • Restricted Users: Read
  • Not Shared
Level 4: Shared on the Network (Read-Only) loadTOCNode(3, 'moreinformation'); Files are shared for everyone to read on the network. All local users, including the Guest account, can read the files. But they cannot modify the contents. Any user can read and change your files.
To configure a folder and all the files in it to Level 4, follow these steps:
  2. Click to select the Share this folder on the network check box
  3. Click to clear the Allow network users to change my files check box, and then click OK.
  • Everyone: Read
  • Everyone: Read
Level 5: Shared on the network (Read and Write) loadTOCNode(3, 'moreinformation'); This level is the most available and least secure access level. Any user (local or remote) can read, write, change, or delete a file in a folder shared at this access level. We recommend that this level be used only for a closed network that has a firewall configured. All local users including the Guest account can also read and modify the files.
To configure a folder and all the files in it to Level 5, follow these steps:
  2. Click to select the Share this folder on the network check box, and then click OK.
  • Everyone: Change
  • Everyone: Full Control
Note All NTFS permissions that refer to Everyone include the Guest account.
All the levels that this article describes are mutually exclusive. Private folders (Level 1) cannot be shared unless they are no longer private. Shared folders (Level 4 and 5) cannot be made private until they are unshared.
If you create a folder in the Shared Documents folder (Level 3), share it on the network, and then allow network users to change your files (Level 5), the permissions for Level 5 are effective for the folder, the files in that folder, and the subfolders. The other files and folders in the Shared Documents folder remain configured at Level 3.
Jul 20, 2010 | Microsoft Windows Vista Ultimate Edition
Shared folder no long accesible xp and vista
Assuming that you have created a shard folder before, "Sharing Files and Folders" should be enabled on your machine.
Go to your Control Panel -> Folder Options adn click the "View" tab. Scroll all the way down and disable "Use simple file sharing (Recommended)".
Now the "Sharing and Security" option should appear again if you right-click a folder.
Microsoft has a write-up on this for general information. See here.
In regards to the possible Trojan - I would need the exact file name to find more information. What you can do from your end is to run an online scan with Kaspersky WebScanner.
Note: You should use Internet Explorer to run this scan, and you must disable your Anti Virus program during the scan.
Click the Accept button.
You will be prompted to install an ActiveX component from Kaspersky, Click Yes.
* The program will launch and then begin downloading the latest definition files:
* Once the files have been downloaded click on NEXT
* Now click on Scan Settings
* In the scan settings make that the following are selected:
o Scan using the following Anti-Virus database:
Extended (if available otherwise Standard)
o Scan Options:
Scan Archives
Scan Mail Bases
* Click OK
* Now under select a target to scan:
Select My Computer
* This will program will start and scan your system.
* The scan will take a while so be patient and let it run.
* Once the scan is complete it will display the results if your system has been infected.
o Now click on the View scan report link:
* Click the Save report as button
* Under Save as type, choose Text file (*.txt)
* Save the file to your desktop as Kaspersky.txt
* Copy and paste that information in your next post if you like.
If you have any more questions, or file sharing is still not working, just come back here and leave a comment - I'm happy to help.
Jul 14, 2009 | Computers & Internet
Unable to network
Are they running Windows XP? If so enable file sharing...
  1. Open My Computer from the Start Menu or Windows XP Desktop. A new My Computer window will appear.
  2. Open the Tools menu and choose the "Folder Options..." option from this menu. A new Folder Options window will appear.
  3. Click on the View tab and locate the "Use Simple File Sharing (Recommended)" checkbox in the list of Advanced Settings.
  4. To enable Simple File Sharing, ensure this checkbox is checked. To disable Simple File Sharing, ensure this checkbox is not checked. Click inside the checkbox to alternately enable and disable the option.
  5. Click OK to close the Folder Options window. The settings for Simple File Sharing are now updated; no computer reboot is required.
Jul 07, 2009 | Netopia Computers & Internet
Bluetooth Share folder
You can can change the default blue tooth folder to phone memory.
Open connection manager > Tap on settings > Select bluetooth >Tap FTP > disable Enable file sharing by removing the check mark next to it > Or you can change the defualt folder from bluetooth share to my documents on the phone menmory or storage card
Thanks
proton
Oct 14, 2008 | HTC P3300 Smartphone
Making a shared folder
Go to this site http://fhctech.org/fhc/networking/xp-sharing-folder.htm for winxp or
http://kb.iu.edu/data/ahrs.html For win2000
http://www.maximumpcguides.com/share-a-folder-in-windows-vista/ for vista
Hope this helps if not please specify the Operating system of your computer
Sep 17, 2008 | Computers & Internet
File sharing
it is possible
If you have multiple computers in your home and they are connected through a home network, you can share files among your computers. That means you no longer have to copy files to a floppy disk or USB flash drive to transfer them to another computer. Once you configure your computer to share files, you (or another user with the appropriate permissions) can, by using Windows Explorer, open them from other computers connected to the network, just like you’d open files that are stored on a single computer. You can also choose to have folders visible—but not modifiable—from other computers on the network.
To share files on your computer with other computers on a network, you need to:
Share a folder on your computer. This will make all of the files in the folder available to all the computers on your network (you can’t share individual files).
Set up user accounts on your computer for everyone who needs to connect to your shared folder. If any of the accounts are Limited User accounts (unless an account is a Computer Administrator account, it is a Limited User account), follow the steps in Set permissions for files and folders to enable them to open your files.
To access shared files that are on another computer on your network, you need to:
• Connect to the shared folder from other computers on the network. This procedure is described in Map a network drive.
Note: By default, file permissions only allow your user account and administrators on your local computer to open your files, regardless of whether a person is sitting at your keyboard or at another computer. It may help to keep these three things in mind when setting up file sharing:
• Files have user permission settings.
• Every computer has its own user database.
• Some accounts are administrator accounts and some aren’t.
Configure your computer to share files To share a folder on your computer so that files stored in the folder can be accessed from other computers on your home network
1.
Log on to your computer as an administrator. For more information, see Access the administrator account from the Welcome screen.
2.
Click Start, and then click My Documents.
68599-click-my-documents.gif 3.
Right-click the folder that you want to share, and then click Sharing and Security.
68599-click-sharing-and-security.gificotip.gif Tip: If you want to share your entire My Documents folder, open My Documents, and then click the Up button on the toolbar. You can then select the My Documents folder.
4.
If you see a message that reads, As a security measure, Windows has disabled remote access to this computer, click the Network Setup Wizard link. Then follow the instructions in How to set up your computer for home networking. On the File and printer sharing page of the Network Setup Wizard, be sure to select Turn on file and printer sharing. If you do not see this message, skip this step and go to step 5.
68599-click-network-setup-wizard.gif Note: If you do not see the Network Setup Wizard link or the Share this folder on the network check box, your computer probably has Simple File Sharing disabled. This is a common change made to computers used for business. In fact, it happens automatically when a computer joins an Active Directory domain. You should follow these instructions to share a folder instead.
5.
In the Properties dialog box, select the Share this folder on the network check box.
68599-click-share-this-folder.gif 6.
If you want to be able to edit your files from any computer on your network (instead of just being able to open them without saving any changes), select the Allow network users to change my files check box.
68599-click-allow-network-users-to-change-my-files.gif 7.
Click OK.
68599-click-ok.gif Windows Explorer will show a hand holding the folder icon, indicating that the folder is now shared.
To connect to the shared folder from another computer, follow the steps described in How to map a network drive.
Note: By default, only you and other people with an administrator account on the computer sharing the folder will be able to open your files. To limit access of specific users with an administrator account on the computer sharing the folder, read How to set permissions for files and folders.
Aug 14, 2008 | Microsoft Windows XP Professional
Open Questions:
See all LaCie Ethernet Disk Mini, 500 GB Hard Disk Drive Questions
LaCie Ethernet Disk Mini, 500 GB Hard Disk Drive with Gigabit Ethernet & USB 2.0 Interface, 7200 rpm... IDE Hard Drive Logo
189 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
