Codes changed again on 7/10/09 - Televison & Video
Ck engine light on again..
Have your dealer look up this service bulletin.
NUMBER: 18-037-11
GROUP: Vehicle Performance
DATE: August 02, 2011
It states your PCM needs reprogrammed with the error code you are receiving P06DE. Was a pretty common problem back then.
Mar 24, 2015 | 2011 Dodge Avenger Heat
Truck would not start had a obd code 340 changed cps started good for 2 wks then it showed a 340 code would not start.
When you get OBD Codes-- you do not change parts
You use the codes & trouble charts-- to component test--
the system-- that set the fault code,to find a problem
If you found no problem, or no tested & failed part,why
change it?
Without factory service & diagnostic manuals & professional
scan tool software & wiring diagrams, your at the mercy of
a repair shop,because you do not have the info or knowledge
needed, to work on a vehicle
Oct 07, 2014 | Dodge Dakota Cars & Trucks
I have a apple mac laptop. I have changed my region code 5 times already and saying that i cannot change it back. Is there a way that I can unlock the region code and start all over again?
When you change the code 5 times
your drive locks.
Try to find new firmware for it and upgrade.
It will reset the code again.
Or you have to buy a new drive.
Hope this was to any help.
Feb 26, 2011 | Computers & Internet
Need code to program universal remote
All you have to do is follow all the steps to enter the code and when you get to the point of entering the code (DONT) just press the channel up button repeatedly but at a slow pace the remote will eventually change the channel on your tv (Tv has to be on) when it changes (STOP) and press the enter/ok, or similar button and that will lock in the code and vwalla you dont have to get up and change the station again.and if it messes up again the follow the same steps and it will fix it again.Good Luck too you.If you follow the instructions this will take you through all the tv codes that the remote has stored and eventually the code for your tv.
Jan 02, 2011 | RCA TruFlat 27F520T 27" TV
Changed the battery on our chrysler grand voyager radio locked!
try to unhook the battery again for a minute or two..might help. then try the code again after hooking up battery again.
Mar 07, 2010 | 2004 Chrysler Voyager
Need to change region code on nec dvd/hdd player
default region code for the drive is 1 but make sure you dont need to change the region code again and again ... coz it gives you only 3 trys and than you will have to flash it with the firmware again .... in some scenarios that too doesnt work so you will be wasting a drive so plz try avoiding the scenario where you have to change the code
Oct 31, 2008 | Televison & Video
Region code unlock
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} What do you mean region code?
Sep 30, 2008 | Computers & Internet
Starview codes
TW 9TH JULY
07 97 B3 F2 89 EC 8D B6
FC FB D3 21 C4 E0 7A FE
PLEASE LEAVE A RATING THANKS AND GOOD LUCK
Jul 05, 2008 | Audio Players & Recorders
I cannot understand why my phone does not accept the default security code 12345
Try to remove battery for few hours and try again if it wont work so just flash it in cellshop!
Nov 15, 2007 | Nokia 2600
Televison & Video Logo
Top Televison & Video Experts
