Question about Brother DCP 115C All-In-One InkJet Printer
Copies poorly from glossy paper, produces vertical
Copies poorly from book pages printed black on glossy white paper, produces vertical bands of black, even at greatest brightness setting
jay196969
  • 41 Answers
SOURCE: horizontal banding
have you tryed to update your drivers on the printer
Posted on Dec 15, 2007
  • 5 Answers
SOURCE: White band on photo glossy output
Open printer, remove drum, clean laser lens with soft dry cloth, reinstall drum.
Manufacturer's Instructions
website: printer.konicaminolta.com
white vertical line (s) / how to clean the laser lens
Cleaning the printer. (5 pages)
Worked for me
Watemusic
Posted on May 04, 2008
SOURCE: Print Problem - vertical lines
I have MFC 7820N. Noticed same problem as other when making copies. Vertical line used to appear.
Open the Scanner where you can see the glass - Flatbed ( where you put the documents to copy)
Make sure that Glass is Clean.
Now make there is Glass on left side about 1x9 inch. Make sure this glass is clean. I had rubbery stain on that I had to rub it off.
Vertical line does not appear when I make copy from Feeder or Flatbed.
Posted on Dec 15, 2008
SOURCE: Brother MFC-9840CDW says no paper when trying to
MP tray stands for MultiPurpose tray. Whatever document you are trying to print is set to print from the multipurpose tray that opens up from the front of the printer. You need to adjust this setting in your software's print settings.
Posted on Aug 11, 2009
SOURCE: not printing glossy A4 paper / paper jam / no paper feed
dont use thick photo paper like 230 gsm up, instead use 180 gsm papers. but if you dont want to waste the purchased thick photo papers, you can open the back and manually insert the paper once the printing process started. i tried this as a trial & error basis until i had perfected it.... hope it works with yours.
Posted on Aug 17, 2009
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
How do I fix this
Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans
support.hp.com/us-en/document/c02881567
Figure : Sample output with vertical colored bands or lines ... Remove any paper from the automatic document feeder (ADF) tray. ... To protect the scanner, do not spray the glass cleaner directly on the glass. .... determine if your printer is still under warranty, and then Contact HP Support to schedule a repair or replacement.
How to get rid of lines on a copied page - YouTube
? 2:10
https://www.youtube.com/watch?v=xTJpCg5sHl0
Feb 17, 2010 - Uploaded by Wayne Springer
When you make copies on your copy machine, does it ever leave a black vertical line ... QLS ' How to Eliminate Vertical Linesfrom Scans, Copies & Faxes ... Part 2- Fix or repair color laser printer with fading, light print, or lines ...
Dec 29, 2015 | Office Equipment & Supplies
White vertical band in Cyan and Black
try to clean the laserwindows of the printer.
Mar 25, 2013 | Xerox Phaser 6125 Laser Printer
I'm getting a color line going down the page on my pictures and the quality of the picture is no good
IssueWhen you copy, fax, or scan an original, the resulting output contains vertical bands, lines, or streaks in one or more colors.When you print the original, the output is normal. Figure 1: Sample output with vertical white or black linesc01892760.gif Figure 2: Sample output with vertical colored bands or linesc01892761.gif
NOTE: This article does not apply to most PSC products, to the Photosmart C6100 or C7200 series, or to the Photosmart Premium C309a and C309c All-in-Ones.If you are using a PSC product other than the PSC 2400 or 2500 series All-in-Ones, go to Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans (c01887564) (in English).If you are using a Photosmart Premium C6100 or C7200 series All-in-One, go to Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans (c00899181) (in English). If you are using a Photosmart Premium C309a or C309c All-in-One, go to Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans (c01622189) (in English). Solution one: Reset the All-in-One If there is static interference, or loose connections with the product, this can result in bands or lines in the copy, fax, or scan output. To resolve this issue, check the product connections and reset the product.
  1. Make sure the product is powered on, and then disconnect the power cord from the product.
  2. Disconnect the USB cable from the product, and then disconnect it from the computer.
  3. Reconnect the USB cable to the computer, and then reconnect it securely to the product.
  4. Disconnect the power cord from the wall outlet, and then reconnect it to the wall outlet.
  5. Reconnect the power cord to the product.
  6. Press the Power button (c01892763.gif ) to turn on the product.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , see the next solution.
Solution two: Clean the All-in-One and print a blank copy If the scanner glass or the white underside of the lid has fingerprints, smudges, lint, dust, or other debris, this can slow performance and affect copy and scan quality. To resolve this issue, clean the All-in-One. Before you begin, gather the following materials:
  • Several clean, soft, lint-free cloths
  • Mild glass cleaner
Step one: Clean the scanner glass and lid
  1. Press the Power button (c01892763.gif ) to turn off the product, and then disconnect the power cord from the product.
  2. Open the scanner lid. Figure 3: Open the scanner lidc01893292.gif
  3. Spray a clean, soft, lint-free cloth with mild glass cleaner.
  4. Wipe the scanner glass and the white underside of the scanner lid with the dampened cloth. Figure 4: Scanner glassc01893293.gif Figure 5: Scanner lidc01893294.gif
  5. Dry the scanner glass thoroughly with a clean, dry cloth, or chamois to prevent spotting, and then dry the white underside of the scanner lid.
  6. Close the scanner lid.
  7. Reconnect the power cord to the back of the product, and then press the Power or Start button (c01892763.gif ) to turn on the product.
Step two: Make a blank copy
  1. Remove any originals from the scanner glass.
  2. Load plain white paper in the input tray.
  3. Press Start Copy Black to make a blank copy.
If the copy is clean, there is no need to continue troubleshooting.If the copy has vertical bands, lines, or streaks, there might be dust inside the product, poor internal connections, or the product might be damaged. See the next solution. Solution three: Service the All-in-One If you have completed all the steps listed above and are still experiencing a problem, service the product. Causes
  • Static interference
  • Loose USB cable or power cord connection
  • Fingerprints, smudges, lint, or dust on the scanner glass
  • Dirt or debris on the scanner lid
  • Scratched or damaged scanner glass
  • Poor internal connections
  • Dirt or debris inside the product
  • Damaged or faulty scanner bulb or parts
Jan 27, 2010 | HP Photosmart 2610 All-In-One InkJet...
Poor paper feed with large printings
This is a known issue, the printer is not designed to do large volume. A thicker paper helps a little, as a rougher paper. If you have to use the old plain glossy white typing paper then using "rubber renew" or some other similar product on the pickup rollers helps in the short term. Just keep in mind that inkjets like this are really designed to print a couple pages or to make hard copies of photographs, not for large jobs.
Oct 02, 2009 | HP Deskjet 6940 InkJet Printer
Just want to print black !
hallow ,,,if your lookin to just print black and white so .while printing ,go the printing properties or prefrencies ,,in the colour option click just use black and white
Jan 10, 2009 | Office Equipment & Supplies
Black smugs on any glossy print
check the fusing area. (where the paper is heated)there is an adjustment for envelop . set it to normal because the pressure on fixing unit is too loose.
Jul 11, 2008 | HP Color LaserJet 2600n Printer
Horizontal banding
Dec 15, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Worked for me
Watemusic
Nov 13, 2007 | Minolta magicolor 2400W Laser Printer
Brother DCP 115C All-In-One InkJet Printer Logo
14 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
