Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Wd645 has no power to on/off switch. changed plug
Hotpoint washer/dryer wd645 has no power to on/off switch. changed plug fuse but still no power. noticed a slight squeal on last wash but cycle completed before power failed.
    Genius:
  • Hotpoint Master
  • 1,474 Answers
Could be mains choke. Mains power comes into mahine via wall socket /worth checking this then onto mains filter/Choke..then to switch..So if no power here check this..wish you well
Posted on Oct 07, 2009
Why is there no power?
Hotpoint red led flashes Washing Machines Questions ...
www.fixya.com > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
Oct 27, 2015 | Hotpoint Aquarius WD640 Front Load...
My aquarius washer/dryer wd645 is flashing f-07
dont warry it will be for few time then it will be ok
Mar 30, 2015 | Hotpoint -Ariston Aquarius WD645 Front...
I NEED A MANUAL FOR HOTPOINT AQUARIUS WDL520G
You should be able to download the user manual from the following site: hotpointservice.co.uk/pages/manual
Or directly download from this link: Hotpoint/Laundry/WDL520 (pdf)
Hope helps.
Sep 25, 2011 | Hotpoint -Ariston Aquarius WD645 Front...
My hotpoint ultima dryer has no power to it changed fuse checked plug socket emptied water tank cleaned both filters
power comes in at mains lead goes to the choke /filter from here onto the door interlock switch then onto timer ......hope this helps
Feb 26, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hi ,, my machine has no power ,, when i push the start button there is nothing at all ,, no lights nothing ,, i have tried the plug and fuse ,,the machine is the hotpoint wd645 ,,, many thanks
Try the plug in another socket that you know is o/k, if still no go ,then you need to remove top cover and rear panel, and check all connectins to control module/s.
Make sure the door is fully catch is fully engaged, as sometimes the spring can give out in the door handle.
Jan 16, 2010 | Hotpoint -Ariston Aquarius WD645 Front...
Hotpoint washer/dryer aqaurius stopd mid cycle with message F-01
f01 is a motor short circuit. you will probably need a new one and maybe the circuit board that powers it if all the lights went out unless the fuse is gone.
Jan 28, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wd645 flashing f-08
The manual says F08 - Heater relay cannot be activated.The dryer might be having difficulty with this.It is not something that can be fixed.Heater Relay equipment might be damaged.Might have to call a repairman to set this right.Good luck.Do post comments for more help.
Jan 10, 2009 | LG WD-14124RD Front Load Washer / Dryer
My hotpoint washer is stopping mid cycle if i dont pump the water out it floods it will only work on thr h cycle
I WOULD HAVE THE PRESSURE SWITCH CHANGED OR CHECK THE SMALL TUBE GOING FROM THE PRESSURE SWITCH TO THE DRUM AS IT MAY BE CHOKE WITH WASHING POWER AT THE DRUM
Jul 15, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius+ WD645
Yes, you will need a test meter. unplug machine, remove to, in the middle on top you will see a heater, you will need to test this. there is also a fusable link, that is incorprated in one of the wires that go to the heater. you will also find to thermostats linked through the wiring, one of these may have a reset button on it.
Dec 07, 2007 | Washing Machines
Problem with our washer/dryer
sump/filter is blocked instead of flushing on dry cycle is filling as not pumping well. ring hotpoint to reorder pts cheaper then anyone
Jan 06, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
246 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
