Question about Jaton NVIDIA GeForce 9500GT, PCI Video Card
Video hardware error - after a while computer starts, works and then reboots!
  • 272 Answers
Maybe the cooling system is not working or the power supply is not providing proper power supply.
Can you make sure, cooling system is ok ?
Posted on Oct 07, 2009
My Laptop will not start. When Lapptop is switch on, fan starts followed by two bleeps. But no more action. Screen blank.
Your computer has memory problems. First check video. If video is working, you'll see an error message. If not, you have a parity error in your first 64K of memory. First check your SIMM's. Reseat them and reboot. If this doesn't do it, the memory chips may be bad. You can try switching the first and second banks memory chips. First banks are the memory banks that your CPU finds its first 64K of base memory in. You'll need to consult your manual to see which bank is first. If all your memory tests good, you probably need to buy another motherboard.
http://www.pchell.com/hardware/beepcodes.shtml
Aug 04, 2010 | Computers & Internet
My computer is restart automatically when i am on my work
This issue could be caused by any of the below possibilities.
  1. Software issue or error.
  2. Hardware issue or error.
  3. Heat related issue.
  4. Computer virus.
  5. Issue with operating system.
Answer:Software issue or error
Errors generated by software programs can cause a computer to reboot unexpectedly or without warning. If you are running Windows XP see the below section "For Windows XP users" before continuing.
If you are not running Windows XP or following the below steps still cause your computer to reboot without warning. Boot your computer into Safe Mode, and let the computer run in Safe Mode. Additional information and help with getting into Safe Mode can be found on document CHSAFE.
If the computer is still rebooting in Safe Mode the issue is likely not software related but something else, skip to the next section. If the computer is not rebooting in Safe Mode it is likely you have software related issue. We would recommend you run through the basic troubleshooting section for your operating system.
Windows XP is designed to automatically reboot each time an error occurs such as a BSoD. Although this may be nice for errors that do not occur often, users who have a re-occurring error may wish to identify the error to troubleshoot it. Below are the steps on how this feature can be disabled and enabled in Windows XP.
  1. From the desktop right-click on My Computer.
  2. Click the Properties option.
  3. In the System Properties window click the Advanced tab.
  4. In Advanced click the Settings button under Startup and Recovery.
  5. In the Startup and Recovery window uncheck the Automatically restart check box.
  6. Click Ok.
Now if the computer generates and error it should not automatically restart and enable you to display any errors your computer may be experiencing.
Any failing hardware component in your computer could cause your computer to unexpectedly generate an error and/or reboot without warning. If you have recently attempted to add a new hardware device, remove that device to make sure it is not causing your issues.
Make sure you are not encountering any hardware conflicts by viewing Device Manager for errors. Additional information about Device Manager can be found on our Device Manager page.
New drivers can also cause this issue, if you have recently performed any hardware driver updates you may wish to try an earlier version of the drivers. Additional information and help with computer drivers can be found on our drivers page.
If you have updated drivers and removed any hardware that could be causing this issue and continue to experience random reboots, it's possible that the memory is bad in the computer. Additional information about testing computers memory can be found on document CH000708.
Finally, hardware devices that are not installed properly in the computer can also cause random reboots. Make sure all the cables and expansion cards are connected properly to the computer. The best way to determine this is to disconnect and reconnect all cables and expansion cards.
Computer virus
Computer viruses such as the blaster virus are written to reboot your computer without warning. Usually these viruses will make the computer reboot ever 5, 10, 15 or 30 minutes after the computer has booted.
If you believe your computer may be infected with a virus or are uncertain if your computer is infected with a virus make sure your virus scanner definitions are up to date. Additional information about checking this can be found in document CH000533.
Heat related issue
Many computer today are designed to turn off or automatically reboot if the computer, processor, or other device in your computer gets to hot. If you have heard any abnormal noises coming from your computer recently such as a high squealing this could indicate a fan may be failing in your computer.
You can first start by verifying the fan on the power supply is working by examining the back of the computer and seeing if the fan is moving and moving smoothly. For all other fans in the computer you will need to either open the computer and make sure the fan are working (processor fan and case fan) and/or if your BIOS monitors the RPM of the fans enter BIOS and make sure the BIOS does not report any errors.
Users may also be able to determine how hot their computer is by onboard thermal sensors, if your computer comes equipped with these sensors make sure your CPU is not running to hot, additional information about how hot your CPU should be running can be found on document CH000687.
If after following each of the above recommendations your computer still continues to reboot it is likely that you are experiencing a Microsoft Windows operating system related issue that cannot be explained. To help make sure this is the case please try the below steps.
  1. Reboot the computer and enter CMOS setup as the computer is booting. If you are not familiar with how to enter CMOS please read through document CH000192.
  2. After you have loaded the computer in CMOS setup let the computer sit.
If the computer does not reboot while letting the computer sit in CMOS it is likely that you are in fact experiencing an issue with Microsoft Windows and it is recommend that if you have followed all of the above recommendations that you reinstall your version of Microsoft Windows. Additional information about erasing the computer and starting over can be found on document CH000186.
Jun 13, 2010 | Microsoft Windows XP Professional for PC
Boot performance monitoring error
>> Tired to reboot several times and still no video.
>> Waited until the next day and the video was working.
>> Very strange.
Sounds like overheating, either inside the monitor, or on the video-card, or inside the computer.
When it happens again, disconnect the data-cable from monitor from the desktop computer, and connect the data-cable to a laptop computer.
If the monitor works, then it's not the monitor that is the problem.
Also, when it happens again, have another monitor, and connect it, to see if the other monitor works, or if the video-card cannot "drive" either monitor.
Apr 05, 2010 | Computers & Internet
My computer reboots without warning while playing online videos or browsing the net. First it happens after working fine for some time and then it starts happening frequently. I have Windows XP media...
as my knowledge if the computer restarting by themselves always there are some error occured in this one area possibility :
1. error in software
2. error in hardware
3. error by virus infected
4. operating system issue
BUT :).. if u get this trouble after take some advennture in networld/network.. i suggest u computer ar sugessted with "blaster virus" the virus are written to reboot your computer without warning. Usually these viruses will make the computer reboot ever 5, 10, 15 or 30 minutes after the computer has booted. so the best way is update your security first
that is the first step
the second :i suggest u to run your computer in safe mode wait for several minutes if not reboot while running safe mode follow this step :
  6. Click Ok.
if still rebooting in safe mode there the issue is likely not software related but something else
the third :hardware devices that are not installed properly in the computer can also cause random reboots. Make sure all the cables and expansion cards are connected properly to the computer. The best way to determine this is to disconnect and reconnect all cables and expansion cards.
  2. After you have loaded the computer in CMOS setup let the com sit
hope u luck
Sep 27, 2009 | Office Equipment & Supplies
Ii have a message ' no active mixer device'
If a reboot does not fix this error, you may have faulty, incomplete driver information, windows is known for this at times.
uninstall your sound drivers from the hardware console, then reboot the PC and re-install them.
to get to the hardware console:
XP
right-click on " my computer " > Properties > Hardware > Device Manager > sound, video and game controllers
Vista / Windows 7
start > right-click on " my computer " > Properties > " Device manager > sound, video and game controllers
May 29, 2009 | Acer Computers & Internet
Computer crash and restart
Windows restarts without warning
Cause:
Heat related issue.
Computer virus.
Answer:
Click Ok.
Computer virus
Heat related issue
Users may also be able to determine how hot their computer is by onboard thermal sensors, if your computer comes equipped with these sensors make sure your CPU is not running to hot.
Jan 28, 2009 | Computers & Internet
Bios problem
Are you using the ON BOARD video output? or are you using an external video card?
Was the computer working and you installed SOFTWARE to enhance something?
I will assume the you know how to get into the BIOS setup to tell your cpu the diffenrnt configurations?!!
1st)Replace the VGA video card with anything...does not have to be FANCY, FANCE. and reboot...same problem? not the same problem?
2nd) take everything out of the desktop except memory and boot up.
continue adding hardware (one at a time) and reboot. If the message comes up..AFTER you've installed a hardware....that is the problem.
Nov 29, 2008 | Intel Motherboard
Rebooting on Dell D600 Latitude
Heat related issue.
Computer virus.
Click Ok.
Computer virus
Heat related issue
Nov 19, 2008 | Dell Dimension 9200 PC Desktop
Instantaneous shutdown with no warnings!
Errors generated by software programs can cause a computer to reboot unexpectedly or without warning. If you are running Windows XP see the below section "For Windows XP users" before continuing. If you are not running Windows XP or following the below steps still cause your computer to reboot without warning. Boot your computer into Safe Mode, and let the computer run in Safe Mode.
Click Ok.
Computer virus
Heat related issue
Nov 19, 2008 | Toshiba Satellite A105 Notebook
HP PAVILION LAPTOP SHUTS OFF AND REBOOTS AFTER A FEW MINUTES
Heat related issue.
Computer virus.
Click Ok.
Computer virus
Heat related issue
Nov 12, 2008 | Computers & Internet
Jaton NVIDIA GeForce 9500GT, PCI Video Card Logo
76 people viewed this question
Top Jaton Computers & Internet Experts
David Payne
David Payne
Are you a Jaton Computer and Internet Expert? Answer questions, earn points and help others
