Question about LG 52SX4D 52" HDTV
Mitsubishi WD 73827 Will not turn on
My Mitsubishi WD 73827 will not turn on. I have unpluged it for 5 min a couple times I have reset it and still nothing. The green light just blinks and turns off. I press power and nothing.
  • LG Master
  • 8,617 Answers
Does the LED blink a two digit code. This set has 2 1000uf @16V capacitors on the PWB that will cause this symptom . Let me know if you need further assistance, there are also 4 1000uf @ 35V on the DM and 3 1000uf@16v on the FMT that will cause all kinds of problems if you change the PWB capacitors I would change the ones on the other boards
Posted on Apr 09, 2008
  • Alicia Breckel
    Alicia Breckel Mar 14, 2015
    Can u send me the instructions on how to check these to my email. Zoe1412000@gmail.com
Mitsubishi WD 65737 black screen
Sounds like the back light has gone mate. Unfortunately this usually makes the tv obsolete
Dec 22, 2017 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi 73" DLP powers on, through welcome
If you are getting at turn on source and back ground is all blue the set will shut down rather quickly;
I have a suggestion, if it works fine, and if not it will not hurt anything.
with original Mitsubishi remote turn set on and then Menu, 1,2,3, enter.
This is the soft reset that most of these sets have (cannot be sure since Model number above is correct?)
The reset button on the front (if it has it) just shuts the set down and reboots the DM unit inside.
Most of these sets when it is pressed the green light will blink for about 70 seconds and go out; that is the DM unit rebooting and the soft restart is something else.
Let me know what you find before you rate this information.
SD TECH
Oct 05, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Wd 73827 . replaced lamp and can not get the tv to turn on.
hold down the device and menu button on the same time for 5 sec. You shpuld get 2 digit error code from green led. Let me know.
Sep 01, 2011 | Mitsubishi Televison & Video
How do you hard reset an Mitsubishi WE65737?
Hello
Plug out it from the wall power socket, and wait for at least 30 minutes or so. It will be best to unplug it overnight. OK.
Jun 29, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Problem with mitsubishi wd65737. thought the bulb was bad, bought a new bulb replaced it and now the screen doesnt want to come on. light on the front of the tv turns green, you have sound but no picture...
Lets try an error code operational checl. Unplug the tv and plug it back in. With the standby LED on press and hold the MENU and DEVICE/INPUT buttons for 5 seconds. The LED will flash a certain number of times pause for a while and blink again. Count the blinks before and after the pass, then post it here so that I can tell you what the problem is
Mar 27, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
I wanted to know how to reboot or restart the TV
With the Mitsubishi remote, press menu then 2-4-7-0 all within 5 seconds. The first option will be initialize. Press enter on the remote and the TV will reset to factory defaults. If you customized any input names or favorite channels, write them down, they will likely change when executing this reset.
Bill W
Integrityhomeworx.com
Mar 23, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I have a WD-52525 set that the green light kept blinking after a power outage. The reset button never worked. I unplugged the set for 30 seconds and re-plugged it back in. The light began blinking between...
Bad digital/power module. Contact Mitsubishi, they may cover part of repair, I am serious. If not, have a an authorized servicer send module to Mitsubishi for rebuild program. The only economical solution.
Jan 18, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Open Questions:
See all LG 52SX4D 52" HDTV Questions
LG 52SX4D 52" HDTV Logo
195 people viewed this question
Steve Allison
Steve Allison
