Ac compressor locked up today have a new one what oil and how much do i need
  • 252 Answers
The new one will have the required type and amount of oil already in it.
Posted on Oct 07, 2009
How much lag oil do i add to new ac compressor and new condenser 2011 buick lacrosse.
pag oil--condenser--1oz
If more than that was drained from condenser, add the whole amount. Hope you can read it. I can only tell you what my database shows. I'm not an ac person.
Jul 08, 2017 | Buick Cars & Trucks
After you change the compressor do you need oil.
if you fitted a new ac compressor , they normally come pre oiled so adding oil is not necessary
if you fitted a previously used ac compressor , the amount of oil added has to be measure carefully as there will still be oil in the ac system and pipes
as the gas has to be added by pressure gauges , best if you get an accredited ac specialist add the oil if necessary and fill with gas
Jun 28, 2017 | Air Tools & Compressors
How much pag oil go in my Dodge Durango ac compressor 2004 model
there will be no need to put oil in an ac compressor
new compressors already have oil in them and old units have the oil through out the ac system that comes back in with the gas.
Jun 07, 2015 | 2004 Dodge Durango
AC compressor locked up and broke belt
That happens when the system leaks,not just refrigerant
but the refrigerant oil with it.
The clutch can be another problem.
Now you need to determine if the clutch is the only problem
If you seized a compressor, you have trash throughout the
entire system & at todays prices & a 1996 vehicle, I wouldn't
fix that.
The clutch or compressor alone you could have done,
but not if it burnt up & sent debris everywhere.
Jun 05, 2012 | 1996 Pontiac Grand Am
How to replace ac compressor to a 2003 f 250 5.4
An Air-Conditioner loses its fizz with passage of time due to constant usage or wear and tear.Just dial to Dailfix they will help you with all things.
AC Repairs Services in Hyderabad Dialfix
Jul 15, 2011 | Ford F-250 Cars & Trucks
My 1997 cadillac refrigerant , i got r 134 coolant that it said to buy and the compressor want come on to charge on the gage its almost to the red (warning) level do i keep putting in till it gets enough...
NOPE STOP CHARGING DONT PUT NO MORE REFRIGERANT IN SYSTEM.DO GOING TO DAMAGE NEW COMPRESSOR AND THE EXCESS PRESSURE WILL BUILD UP CAUSE THE REFRIGERANT CANISTER TO BURST EXPLODE INJURY OR FATALLY HURT YOU. BEST TAKE CAR TO A GARAGE.LET GARAGE PUMP DOWN AC SYSTEM AND CHARGE UP.BECAUSE YOU WILL DAMAGE NEW COMPRESSOR. MOST OF TIME I WILL HOT WIRE THE AC COMPRESSOR. MAKE SURE COMPRESSOR HAS 2 OUNCES OIL IN IT.IF COMPRESSOR START UP NO OIL IT WILL LOCK UP.DONT KEEP PUTTING REFRIGERANT IN THE AC SYSTEM, THE R 134A GOING TO FREEZE UP TOO MUCH MOISTURE IN SYSTEM YOU HAVE TO HAVE A VACUUM PUMP TO PUMP DOWN AC SYSTEM CHECK FOR LEAKS BEFORE CHARGING SYSTEM UP.LOW SIDE NEED TO BE 31 - 36 PSI THE HIGH SIDE SHOULD BE 165 - 205 PSI.
Jun 24, 2011 | 1997 Cadillac DeVille
2000 Chevy Malibu...Working on my AC replacing the compressor...What is the fluid capacity of the compressor/AC system on this vehicle...If I've added more than enough, how do I drain excess fluid to...
NEW AC COMPRESSOR POUR OUT SHIPPING OIL COME WITH IT ADD THEM SAME AMOUNT.IF YOU NOT SURE AND OIL BEEN POURED OUT.ADD 2 OUNCE R 134A REFRIGERANT OIL TO NEW COMPRESSOR. YOUR AC SYSTEM HOLD 1.75 LBS R 134A REFRIGERANT.
Jun 22, 2011 | 2000 Chevrolet Malibu
How much oil do i put in my 2000 dodge stratus air conditioner compressor?
Most the time its 8 oz,, need to check with the seller and see the specs on compressor,it should say on ac compressor
Aug 22, 2010 | 2000 Dodge Stratus
Hi..i had to change a/c condencer, and the a/c compresser, both at the same time.how will i go about charging the system? do i need to add coolent too both ports? or just the low side.?
YOU TAKE TO A GARAGE LET THEM PUMP IT DOWN FIRST MAKE SURE YOU PUT THE RIGHT AMOUNT REFRIGERANT OIL IN COMPRESSOR.IT COME WITH SHIPPING OIL IN IT BUT YOU HAVE TO POUR IT OUT.PUT IN THE RIGHT AMOUNT OF REFRIGERANT OIL IN COMPRESSOR LOOK IN OWNERS MANUAL TO PUT IN THE RIGHT AMOUNT.NOW IF YOUR OLD COMPRESSOR SEIZED OR LOCKED UP THEN LET GARAGE FLUSH OUT METAL SHAVINGS OUT .IF YOU DONT FLUSH OUT SHAVINGS THE NEW COMPRESSOR WILL BE DESTROYED.ALSO YOU HAVE TO REPLACED THE ACCUMULATOR OR ORIFICE TUBE IF EQUIPPED.IF OLD COMPRESSOR DIDNT LOCK UP.PUT NEW REFRIGERANT OIL IN COMPRESSOR IT TAKE AT LEAST 1 OUNCE OF OIL BUT CHECK OWNERS MANUAL ALL VECHICLE HAS DIFFERENT SPECS.AFTER COMPRESSOR OIL BEEN PUT IN EVERYTHING ALL REFRIGERANT LINES TIGHT.TAKE VECHICLE TO A GARAGE THAT DO AIR CONDITIONER WORK.THEY HAVE TO USE A VACUUM PUMP TO PUMP DOWN THE AC SYSTEM TO REMOVE MOISTURE AND LEAK TEST THE SYSTEM WHILE IT PUMP DOWN.IF YOU DONT LET THE GARAGE PUMP DOWN SYSTEM. THE MOISTURE WILL FREEZE UP IN AC SYSTEM CAUSING POOR OR NO COOLING.THE GARAGE GOING TO CHARGE YOU TO PUMP DOWN AND CHARGE UP SYSTEM.IT WOULD BE CHEAPER TO DO THIS THAN TO BUY A VACUUM PUMP AND MANIFOLD GAUGE SET.WHEN DOING AC WORK YOU NEED SPECIAL EQUIPMENT AND TOOLS TO DO THE JOB OR THE AC SYSTEM WILL NOT WORK RIGHT.
Jun 12, 2010 | 2004 Nissan XTerra
Installed new air conditioning compressor in 2002 Pontiac Grand Prix - how much compressor oil do I need to put in?
If you have not cleaned out the ac system,the ac system will have oil in it,but,the compressor most likely does not have any in it,so pour about 4 to 5 oz in the low side opening on the compressor before installing it,and turn the center nut of the compressor clutch about 8 to 10 times,oil will try and come out the high side,when it does,this will be enough turning.If the system needs more oil,add as needed when freon is put in the system.If the oil is not added to the ac compressor before installing,the compressor could be damaged.Please rate if this was helpful,thank you.
Jun 11, 2010 | 2002 Pontiac Grand Prix
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
