Question about Samsung SyncMaster 940N Flat panel Monitor
My samsung syncmaster 940n is no longer working, the blue light is on but the monitor is blank. Is there anything i can do?
  • Samsung Master
  • 1,684 Answers
This problem is usually caused by a failure of the power supply board controlling the back lights. Here is a link to a repair guide with disassembly and repair instructions that should help you get the monitor back up and running again.
http://www.ccl-la.com/blog/index.php/repairing-a-samsung-940n-with-a-blinking-power-light/
I hope this helps, if so please rate my solution.
BuddyMc
Posted on Feb 26, 2012
    Problem Solver:
  • 19 Answers
It mite not a problem from the monitor, try and check your data receiver cable either from a computer system with another monitor.
If the response is different i.e not displaying... its a hardware problem... a vendor can check it for you
Posted on Oct 07, 2009
When I turn on computer,monitor doesn't show anything sometimes 1,2 hours , and then finally I can see descktop on computer...All that time,monitor is trying to show picture (I can see like blinki
This is a known symptom of a failure in the power supply board. Here is a link to a repair guide that shows how to dis-assemble and the unit and then what to look for and replace on the power supply board to bring the unit back to working condition.
And here is a picture of the power supply board that needs to repair.
BuddyMc
Feb 22, 2012 | Samsung SyncMaster 940N Flat panel Monitor
Hi. I have a samsung syncmaster 940n black. After i turn on my computer the screen if just black and the blue light(where i turn the monitor on) just blinks.It worked normally yesterday.
The most common problem with the 940N units is a failure of the power supply/back light inverter board. This is easy to repair be replacing 6 capacitors on the power supply. Here is a link to a repair guide with dis-assembly instructions and what to look for and replace and the power board.
And here is the power supply board.
BuddyMc
Feb 17, 2011 | Samsung SyncMaster 940N 19 inch LCD...
After startup on Sammsung SyncMaster 940 N I do not see
Sounds like system software needs to be replaced... re-installed. It probably got corrupted somehow since it is not rebooting properly. Use the original discs that came with the computer. Thnx
Jul 24, 2010 | Samsung SyncMaster 940N (Silver) LCD...
SyncMaster 940N - screen has gone dark when turned on and computer booted up. If I get close to the screen I can just about see something on the screen. I have brought up the service menu and all the...
Your problem is usually caused by a bad power supply. You should be able to do the repair yourself, if just requires replacing 6 capacitors on the power supply board. Here is a link to a repair guide that shows how to disassemble the monitor and repair the power supply board.
And here is the a picture of the power supply board.
BuddyMc
Apr 16, 2010 | Samsung SyncMaster 940N Flat panel Monitor
Stand for the monitor on a samsung syncMaster 940n broken
It depends bad the parts are broken, this is 2007 model, you may have hard time getting replacement parts, details pictures will help.
http://s807.photobucket.com/home/budm/allalbums
Mar 29, 2010 | Samsung SyncMaster 940N Flat panel Monitor
The monitor was working fine,but for one night the system was not shut down and when i cancel it then it shows only black.Samsung N940
theo_christo, Get into my FIXYA profile and see if anything interests you or your BLACK or BLACK/BLANK screen symptom. Learn about the "flashlight" test that every "CCFL backlit lcd" monitor owner should know how to do and interpret the results of. 12fixlouie READ, READ, READ!
Feb 01, 2010 | Samsung SyncMaster 940N Flat panel Monitor
My monitor 940n samsung syncmaster gone in black...
I have just had this same problem. The problem mostlikely is a blown fuse on the inverter board. Mine was blown on the board and also a Capacitor (470nF/25V) was bad beside the Fuse.
I replaced both and monitor is working now again. After install the picture was a little grainy with little artifacts. In another post i found that the Power Supply board needs to be cleaned for unwanted residue. After that picture was fine again.
BEWARE that you need a soldering iron and a steady hand to replace these parts. If you are unfamiliar with soldering at all have an expert take a look at this. The Power boards uses 220v so DO NOT connect it to the Power when opened.
Starworx
Aug 10, 2009 | Samsung SyncMaster 940N Flat panel Monitor
Samsung syncmaster 913c
press the blue fn button and look for a screen on the buttons F1 through F12
Jun 17, 2009 | Samsung SyncMaster 940N Flat panel Monitor
Screen goes blank after 2 seconds
Do you have the video set to a range that this display cannot handle? Try rebooting into Safe Mode and set the resolution down to 800x600 or 1024x768 and see if it that will get you back. If so, then look up the specs of the display and set it no higher than it's max.
If it physicaly powers OFF, then you probably have a power issue.
Jan 20, 2009 | Samsung SyncMaster 940N 19 inch LCD...
Samsung Syncmaster 940n - white screen
This is a known symptom of a failed power supply board. Here is a repair guide for this unit that shows how to dis-assemble the unit and then what to look for and replace to rebuilt the power supply board and bring the monitor back to life.
And here is a picture of the power supply board.
I hope this helps you, if so please rate my solution.
BuddyMc
Mar 25, 2008 | Samsung SyncMaster 940N Flat panel Monitor
Samsung SyncMaster 940N Flat panel Monitor Logo
1,411 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
