USB port installation
Can't figure out where to plug in front usb port cables on jetway motherboard
  • 5 more comments
  • jattjatti Mar 05, 2008
    hi,
    actually prob. is that my pc not showing the pen drive and memory card reader
  • Dbox Mar 26, 2008
    Can't figure out how to connect the usb ports of the front panel for the msi kt4v Motherboard.
  • stexvel Apr 30, 2008
    I don't know where to connect front USB....my motherboard (MSI KT4AV - MS6712) has 4 rear usb's and 2 front, and I don't know in which jumper I have to connect cabe from front usb....front usb cable has 3 jumpers, and on my motherboard there is 10 jumpers for USB....i tried some combinations....but it doesn't work...help....stexvel@hotmail.com
  • grafit4print Jul 11, 2008
    hi guys want to know where to plug front high speed usb 2.0 cable on motherboard
  • Anonymous Nov 12, 2008
    usb
  • fuckingboard Dec 14, 2008
    ******* motheboard :/ USB not running ... this is ****
  • Anonymous Jan 15, 2009
    yes
NavajoGirl,
I have a Jetway 663AS. The USB Header is J5 and is a 10 pin connector with 1 pin missing. It can be found near the battery.
HTH,
Paul
Posted on Dec 29, 2007
P6610f motherboard
Are you following Anti-Static Procedures?
If you, or the person who took it apart has not, you can use the motherboard for a Frisbee.
(Processor for a neck trinket, and Ram Memory for Christmas decorations)
Moving on.........
HP Support > Pavilion p6610f Desktop PC > Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=4299342
Product information > Product specifications > Motherboard Specifications, N-Alvorix-RS880-uATX (Alvorix),
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02560084&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=4299342
A) Let's start with the two power cables coming from the Power Supply, that go to the motherboard;
1) 24-pin ATX main power cable
Looking at the motherboard photo, the 24-pin ATX main power cable's connector; is at the bottom.
Two rows of 12 socket holes, in a yellowish/whitish connector.
Motherboard installed in computer case, you will find it to the Right.
(The motherboard view shown, is clocked 90 degrees to the Right; in comparison to how it actually sits in the computer case)
GENERAL example,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
[NOTE* Color of connector does NOT matter ]
Note the hinged Lock Clip on the power cable's connector.
Also the TAB on the motherboard connector.
When power cable is deemed to be plugged in tightly, and properly; the Lock Clip will be over the Tab.
{Lock Clip operates on the same principle, as a see-saw on a playground. Top is squeezed in to release Lock Clip}
2) 4-pin ATX +12 Volt power cable
Looking at the motherboard photo, the motherboard connector for this power cable is;
Straight up from the white Processor socket,
To the right of the square finned Aluminum Heatsink.
General example of said power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Has a Lock Clip too.
Remember about the color of connector, thing.
Can be pink with neon polka dots. Doesn't matter.
WHAT the power cable IS, does matter.
This power cable is power for the Processor.
It ain't plugged in, you have no computer.
(Scroll down to Motherboard Layout. It is PU521 )
That's it for power cables that plug into the motherboard.
Moving on..........
The Harddrive is a SATA unit. The optical drive is a SATA unit.
(CD/DVD drive)
Means you need a SATA power cable for each one of them.
General example,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
Note the L-shaped opening in the connector. Hard to see in this photo, but I will show a better view in a minute.
Also; between a SATA data cable's connector, and a SATA power cable's connector; the SATA power cable connector is the larger of the two.
Has 15 contact pins.
SATA data cable connector has 7-pins.
Often there is a lock on this power cable's connector.
A tab that sticks up, or a 'bulb' type affair.
Depress with thumb, when plugging in, or unplugging.
Harddrive needs a power cable, and data cable.
So does optical drive/s.
B) General example of a SATA data cable, and it's respective connector,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
Just referring to the cable shown at the top, for now.
Now you can see the L-shaped opening a little better.
See how the 'foot' of the L goes down? That is the direction you want it, when plugging in.
The motherboard connector shown below the SATA data cable, is a SATA connector.
This particular style is OPEN.
Your motherboard uses the type that is CLOSED.
Note also the L shape on the motherboard connector.
The connector shown for that SATA data cable, is a 90 degree bent elbow.
If your SATA data cables have this style of connector, they plug into the Harddrive, and optical drive/s.
The straight type of connector, plugs into the motherboard.
It can also plug into the Harddrive, and optical drive; if your SATA data cable has two straight connectors.
The SATA data cable connectors on your motherboard, are all the way to the Left. (In the motherboard photo)
Orange, Light Blue, Dark Blue, and White.
Note that they have a L shape in the middle.
Now scroll down the HP Support page, to Motherboard Layout.
Orange = SATA4
Dark Blue = SATA1
Light Blue = SATA3
White = SATA2
SATA1 is for the Harddrive
SATA2 is for an optical drive.
If you have more than 1 optical drive, it plugs into SATA3.
(Make sure SATA3 is ENABLED in BIOS Setup)
C) The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to; is the Front Panel header.
Looking at the motherboard photo, look again at the Orange SATA4 connector. To the Immediate RIGHT is the Front Panel header,
http://www.findlaptopdriver.com/n-alvorix-rs880-uatx-front-panel-motherboard/
I believe though, that the cable coming from the Front Panel; has one solid plug-on connector. Not individual wires.
Note how the Front Panel header on the motherboard, is missing one pin. This is the Key.
The cable connector going to it, should have one socket hole blocked off.
Should only be one cable coming from the Front Panel, that has the correct plug-on connector.
The other cables coming from the Front Panel, will have different size plug-on connectors.
Going further.........
Look at what is installed in the Front Panel;
USB ports, audio ports, (Headphone and Microphone), Card Reader, etc.
You can follow the cables, and get a pretty good idea of where they go, in the Front Panel.
For example you can follow the cables that go to the USB ports.
Follow the two cables that go to the Card Reader.
Follow the cables that go to Microphone, and Headphone jacks.
Then by process of elimination, you know which cable goes to the Front Panel header.
D) Front Audio
Looking at the motherboard photo, look towards the Top/Left corner.
The Yellow header is for the Front Panel audio ports.
Headphone, and Microphone.
E) Coming down the Left side, in the motherboard photo; look at the two White rectangular headers.
Match up in the Motherboard Layout, and bottom of HP Support page.
USB1 2, and USB1 2.
EACH USB header, is for TWO USB ports.
That is why they both have USB1 2 marked near them, in Motherboard Layout.
A Card Reader SHOULD use two cables, and One USB header.
It may be though, that the Card Reader will use both of those White USB headers.
Either the Card Reader plugs into them, or the USB ports in the Front Panel.
If the cable connector fits, plug that cable in. (On)
USB is USB.
Card Reader uses USB too.
Point?
If the cable's connector fits, plug it in. (On)
In the motherboard photo, there are two White connectors;
Above the Orange SATA4 connector, and Below the Light Blue, and White SATA connectors.
(Light Blue = SATA3, White = SATA2)
The USB ports up front probably connect to them. (Front Panel)
Follow the cables to Front Panel USB ports.
What type of connector do the cables use?
All FOUR of those USB connectors on the motherboard, may NOT be used.
Perhaps just two of them.
That doesn't 'sound' very concise, huh?
However it is my contention, that each cable coming from the Front Panel; should have a different connector.
Going further;
The Card Reader, and the USB ports in the Front Panel; may have the SAME type of connector, on the end of their cables.
Again, the Card Reader uses a USB header, (Or headers), on the motherboard.
So do the two USB ports in the Front Panel.
Therefore it does not matter which USB header on the motherboard, that either one of them are connected to.
F) Looking at the motherboard photo, look above the Ram Memory slots, to the far Right.
Right above ram memory Slot 1, that is White in color. (DIMM 1)
There is a small Electrolytic Capacitor, with a Black plastic sleeve.
Right above it is a small White 3-pin connector.
This is where the Processor fan plugs in.
(CPU_FAN)
G) Right above the square Aluminum finned Heatsink, is the 3-pin connector for the computer case fan.
SYS_FAN
(System Fan)
(The square Aluminum finned Heatsink, sits on the Northbridge chip.
Which is part of the motherboard chipset)
That about does it for me.
Please post additional questions in a Comment.
Regards,
joecoolvette
[Seems like I gave a solution for this before.
I can't pull it up in Solutions I have given, so do not know for sure.
Want to see someones user account?
If you are a member of FixYa, all you have to do is click on their user name (Example; joecoolvette), or user icon ]
Mar 23, 2013 | HEWLETT-PACKARD Hewlett Packard Pavilion...
How can i setteled the front panal usb pin connect on the usb panal on motherboard gigabyte845 gvm-rz
There are 2 USB Ports for the Front Panel USB ie F_USB1 / F_USB2 beside the "PWR_LED". You can use either F_USB ports. Just plug in the USB cable pin accordingly in the Configuration below. Be sure the the negative & positve pins are correctly plug in or it might caused damage to you Mainboard. (Pins 9 &10 not used). For further reference you can download the manual @ Link
Pin No.- Configuration
1-Power 2-Power
3-USBDx- 4-USBDy-
5-USBDx+ 6-USBDy+
7-GND 8-GND
9-No pin 10-NC
Hope it helps.
Aug 06, 2011 | Gigabyte 8IG1000MK Motherboard
Is there a way to attach mutimedia card reader to gateway micro atx motherboard
I'm not sure which model number you have, but you are able and have USB ports on your computer, then the answer is yes. You can do it two ways: One way (simplest way) is to buy an external multi-reader that plugs into a USB port. The second (More permanent), is when you open up your case and look at your motherboard, you should see a white cable that is connecting to your front-mounted USB ports. Follow it back to the motherboard and see if you have another slot to put another cable in for you multi-reader (and make sure you have a spot available in the front of your case to put the multi-reader). If you don't have a spot, or another plug, then go to newegg.com and buy an internal reader with at least one or two USB ports, and replace your existing front USB port.
Mar 12, 2010 | Gateway (Sound/VideoOn) ATX Motherboard...
My usb ports stopped working. i unistalled them and restarted my computer. computer saw the usb ports on start up but still doesn't see any devices I plug into it. Is it a bad motherboard or a driver...
Some computers have both USB ports on the front and back of the case. The ones on the bark are directly off the motherboard while the ones on the front are usually connected by a separate cable. If you are trying the front ports, try one of the rear ones instead. if it works in the back, that cable may need to be reconnected inside the case.
Feb 26, 2010 | MSI 865GVM2-LS Motherboard
Usb 1 2 3 or not working
Found that the people that put the computer together had not powed the port, the port worked but as it had now power no device wold appear to work, Changed the jumper to power the port and everthing is now working.
Thaks george
Dec 26, 2009 | Jetway MB GTDual-STD-G NF4-MCP 754...
When I plug my wireless usb modem in it reboots my comp.
sounds like the modem could be shorted out if you know anyone else who has a usb modem ask if you can try there modem on you computetr
Dec 05, 2009 | Jetway PM800DMS Motherboard
USB port problems
You need the motherboard specs, which you can look up on the internet, based on the maker.
With the USB ports, the front ones often don't include power.
So plug a powered 4 port hub into the front port, and then the hub will supply the power after that.
Jun 26, 2009 | MSI K7N2 Delta-ILSR (MS-6570-030)...
Pluging in extra usb ports/Mic and headphone jacks from the tower
Answer me this. You're case is an Antec tower? The motherboard is the Asus P4P800 SE ? Is this correct?
If you have you're manual you can see what goes where on the board for front panel connector page. 2-31. (This diagram shows you how to connect the front mic & speaker).
To connect the Antec's front USB ports plug the case USB front connectors onto USB56 & USB78 shown on page. 2-30. Most case wires are already set within their USB connectors & the Antec's front USB connector should fit right on the mother board's pin's. If you need you're user manual, download from Asus by clicking on this link. http://support.asus.com/download/download.aspx?modelname=P4P800%20SE&SLanguage=en-us
Good Luck!
Mike
May 19, 2008 | ASUS P4P800SE Motherboard
Havimg prob with the 2 usb ports located in front
Hi manky, Normally front USB ports have a pair of 4 wire cable with connectors marked red wire is vcc; white wire is -D; green wire is +D; and black wire is gnd. The motherboard would normally have two pairs of dual pin connectors that would be sitting side by side or in-line with uneven pins - 4 and 5 pins; then another 4 and 5 pins. Please refer to the attached simple diagram for your connection. For some reason I couldn't get hold of a manual from the Gigabyte site of your particular model GA-81KHXT. Nonetheless hopes this works for you. Pls post again how things turn up. Good luck and kind regards.
Jun 01, 2007 | Intel Motherboard
Computers & Internet Logo
855 people viewed this question
Alun Cox
David Payne
David Payne
