Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
The washer works no power tp driver
The dryer worked then after it was done no power we just bought it used
  • 38 Answers
First check out your fuse or breaker box to make sure you have proper power to the outlet.
If the outlet provides 220 volts I would check the door switch and then the high limit found in the very upper rear of the cabinet above the heat element.
the high limit is a non resetable heat sensor if it blows the dryer will be dead until you replace it.
Bear in mind that this is no easy machine to work on, getting to the high limit is extreme but even checking the door switch will be difficult.
Good Luck
Quentin
Posted on Oct 09, 2009
I bought a TP-LINK TLWN7200ND adapter, but it doesn't detect any 802.11b/g router, even with the latest version fo the driver for Windows XP. How can I fix it? Does only work with TP-LINK 802.11n...
i have used a similar adapter on windows 7 as well as on ubuntu 10.04 (linux), and it detects it upon restart without any external drivers.
try on a system with any of these to confirm that the adapter is good. this could be a hardware fault.
also, try changing the card slot as there could be a problem with the slot.
if it works fine on these, then make sure you are using the correct drivers (the ones exactly for this device and not for another similar device)
Jun 08, 2011 | TP-LINK TPLink Tp link Tl wn7200nd 150mbps...
Mousepad not working
Each Touchbad should have basic functionality by default in every Operating system, letting it be used even when no driver is installed. However, try pressing FN and F7 together and see if the touchpad works again. Some people accidently press this FN + F7 key when they mute the sound with the FN + F8 key.
The FN + F7 is there to disable/enable the touchpad as some people use a USB mouse instead of the touchpad.
If you still need the drivers, here are the download links. Please choose desired driver by Operating system and Touchpad brand...
Acer Windows XP TP Drivers Synaptics
Acer Windows XP TP Drivers ALPS
Acer Windows 7 TP Drivers Synaptics
Acer Windows 7 TP Drivers ALPS
Acer Windows Vista TP Drivers Synaptics
May 18, 2010 | Acer Aspire One PC Notebook
Just bought the washer and dryer. Dryer works washer does not how do i hook up washer
Hi .. There should be a seo\parate power cord for each unit. If there is not a separate cord , then look for a cord the interconnects the two uniots .
May 03, 2010 | Kenmore 94702 Front Load Stacked Washer /...
Asko dryer has no power.Washer ok
By-passed fuses,dealer said he's done hundreds.Saved me a service call.This is the 1st and only problem we've had in 10 years! We love our Asco.
Feb 16, 2010 | Asko Dryers
GE Spacemaker Washer/Dryer wont start only washer or only dryer
Did you figure out a solution to this problem? I just bought a brand new Frigidaire and it is doing the exact same thing, except it never worked properly. I thought it was the unit and had HH Greg bring another out but the 2nd one did the same as the first.
Feb 09, 2010 | GE WSM2700W Unitized Spacemaker Washer and...
How do I prep my Kenmore Elite He5t washer for move to new house
Washers n dryers usually require some balancing after a move to the new area, and when you lift the washer on a dolly, you lift it from the rear. Assuming you've already tipped the washer slighlty to one side, checked the bottom for which side has the most metal underneath. This is best done with 2 people. Do the same with the dryer. The braces are used to help balance or to keep from tipping when the machine was packed inside a large box.
May 23, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Hotpoint wd865 dryer stopped working
I always start at the plug to make sure it has 220, a dryer will run but no heat with 110. This was a common problem when everyone used fuses instead of breakers, just an old habit.
Then I check the heating element and thermostats, this must be done with an OHM meter. More than likely it will one of these.
Dec 23, 2008 | Hotpoint Ultima WF865 Front Load Washer
Daewoo Lanos 2001 windshield washer pump not working???
Try to find the fuse, if the fuse is ok try to remove the cable under the pump and reconnect them, if the pump still dosent work u need to buy a nes one and replace it.
By the way, start with check that u have power to the pump, buy a test lamp tp do that, you need to be two for testing that, one for pushing the switch and one to check the test-pamp.
Nov 19, 2008 | 2001 Daewoo Lanos
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
74 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
