I AM TRYING TO HOOK UP MY LAPTOP TO THE TV (STATED ABOVE, PHILIPS 47PFL5522D) VIA HDMI CABLE BUT THE TV COMES UP WITH "NO SIGNAL BEING RECIEVED." I DID THIS A MONTH AGO AND IT WORKED, NO PROBLEM. I HAVE TRIED ON A DIFFERENT TV AND IT WORKS FINE. WHY IS THE TV NOW DISPLAYING "NO SIGNAL BEING RECEIVED" - HOW CAN I REMEDY THIS?
  • 87 Answers
Hi there! first to check here is the HDMI connection, if there are okay then next to check is the desktop properties on PC. From desktop open the Display Properties and go to Settings Tab. On that window you to ensure that you are selecting Multiple Monitors on the display. set the resolution of your display to minimal ratio just to avoid some error such as Mode is not Supported.
Hope this could help.
Posted on Oct 07, 2009
Lt-50a330 trying to connect laptop but it says "not supported"
If your laptop has a HDMI port just use a HDMI cable to connect it. Unless you are trying to do it wireless in which case you need the data from the laptop to go first to a receiver, then the tv.
Apr 13, 2013 | Televison & Video
No signal when I hook my Dell XPS laptop to my Element HDTV
turn off tv and laptop. connect the hdmi cable to your tv and laptop turn tv on then log onto your laptop Both devices need to be off when connecting the hdmi cable
Apr 13, 2013 | Dell XPS Computers & Internet
No audio input from TV on DVD Home Theatre
U have audio signal incompatibility. If the audio output is digital it may not work with an analog input, etc.
May 08, 2017 | Audio Players & Recorders
Laptop connection
Buy a HDMI cable.Hook up one side of the HDMI cable to ur tv HDMI Hub.The other side of the HDMI cable to ur laptop USB Hub.That it u got a connnection,now go in ur tv input pick which HDMI inputs,u put it in,example 1 to 4 HDMI Hubs.Pick the one HDMI Hub that ur laptop it hook up in.That it now u got ur LCD tv used as a monitor.
Apr 27, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
I am trying to hook up a Sony BDP-S360 via HDMI
I don't know what kind of TV you have, but on some TVs the HDMI inputs have to be enabled via the TV setup menu. Try looking at the setup status.
Dec 27, 2009 | Sony BDP-S360 DVD Player
HDMi ( no signal, not supported) doesn't work with Dmr-Ez47v
Any HDMI cable manufactured in the last couple of years should all be HDMI 1.1 compliant, your problem is most likely the logic board in the TV itself or the HDMI connector on the logic board has a bad connection..
Have you tried hooking-up a standard DB15 VGA cable to the AKAI TV and your laptop?
If this works your problem is in the TV and will most likely have to be repaired to receive the HDMI signal since your Panasonic DVR and your laptop are not recognized by the HDMI input on the TV.
Ren
Jun 03, 2009 | Akai LCT2785TA 27 in. LCD Television
No Pc Audio on HDMI
bad hdmi cable common problem
Apr 27, 2009 | LG 37LG30 37 in. LCD HDTV
Trying to hook compaq presario laptop to philips lcd digital tv
hey fox,
sounds to me like a connection problem. If the compaqs output is vga, you need to convert the input (tv side ) to hdmi, component, s-vidio... what ever you can find. Typically when you hook up your computer to a flat screen or such, its best to try to use the hdmi ports or the rpg. But if thats not available you need to take the outout from your laptop ( whatever type that might be and input it into your flat screen tv. If you input laptop into tv under ( eg..HDMI) then when you VIEW it you need to select the correct source on your flat screen. Such as hdmi or pcmi or rpg.I know that the do sell alot of cables that adapt from one type of connection to another. Typically only one cable is required from the laptop to the flat screen. If you think about it you are only using the flat screen as a monitor.
Feb 14, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Trying to connect PC to Philips LCD HDTV
While the tv is on the right input, and the computer is running, try unhooking the cable and hooking it back in. That's the only way I can get my Philips to detect the HDMI signal from my pc. I haven't found a fix for it though.
Jan 29, 2008 | Philips 37PF9996 37 in. HD-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
