Question about Saitek X52 Flight Control System
I need to replace the cable that conects the
I need to replace the cable that connects the throtle to the joystike
The cable is a male-to-male PS/2 cable, of the same plug design as those used on keyboards and mice.
They can be bought as is, or if it is easier/cheaper to buy a KVM cable (with a PS/2 mouse and keyboard cable), the KVM cable can be used in a pinch. It just looks a little clunkier as it also has a VGA cable.
Posted on Nov 21, 2009
2001 Mercury Mountaineer keeps blowing the PCM power diode (fuse #19)
Check all of the battery terminals and cables and check the wires on the starter/selonoid, start from the battery and follow the cable out and check all conections , clean and tighten them and if it still does it the starter/selonoid is bad and needs replacement...
Sep 18, 2008 | 2001 Mercury Mountaineer
Motorola E398 Keypad not working. Only power on/off (red button) works and no other button works.
frist remove joystik and chek other kepad its key ok the joystik replesh
Apr 04, 2011 | Cell Phones
Where is the TPS located on a 1994 Ford Tarus?
TPS-Throttle Position Sensor
They all better be on the throttle body, on most vehicles
Oct 14, 2010 | 1994 Ford Taurus
Icant find the IAC valve in a 2004 F150 5.4L 3V can anyone tell me where is located
it will be on the throtle body this is were the throtle cable hooks up to unless it is a drive by wire (no cable) then it will not have a iac if you are having idling problems with an drive by wire you will need to replace the throtle control $$$$$$$$$$ 500 600 for part but it is a bolt on and go part no programig
Dec 31, 2009 | 2004 Ford F150
1993 Olds v6 races when started. Replaced idle air valve. no change. Checked throtle position sensor. It seems to be working. Took to mechanic and he replaced the main computer and idle problem seemed to...
my 1994 had the same problem,where the TPS sensor connects there is a small rod that moves you should be able to see it without taking anything apart it wsa rusty and sticking so i sprayed it with wd-40 a couple of times and that solved the problem for me,don't know it that will help but maybe it's worth a try. or maybe your throtle cable to the gas pedal has worn a grove inside the cable and you can't see this problem,but atleast have it checked to see if it's sticking.
Oct 27, 2009 | Oldsmobile Cutlass Ciera Cars & Trucks
How do you replace the throtle cable on a 97 sportster 1200
first you need to take apart the throttle thats is done by 2 screws under the throttle the cable will be cloped in to a slide that rotates to pull the cabel. after that fallow the bable to the engin it will clip in on a nother slide that is on the intake manifold that controls the throttle there might be a screw or two holding it, you may have to remove some things to get to it
Jun 02, 2009 | 2000 Harley Davidson XL 1200 S Sportster...
Xbox360 conection to modem
you will need a ethernet cable to connect it to the modem. the modem then needs a DSL cable wihch should connect to splitter in your phone line.
Jan 27, 2009 | Microsoft Xbox 360 Console
Windstar garbage
Did you try starting the van while giving it half (or more) throtle? sometimes, but not usually, after removing a battery a vehicle's computer needs to "re-learn" some of its programing. the vehicle won't start or idle without some throtle. taking the vehicle for a drive if you can get it started will get the computer working properly agian if that is the problem.
Aug 06, 2008 | 2000 Ford Windstar
Saitek X52 Flight Control System Logo
558 people viewed this question
Top Saitek Video Game Consoles & Games Experts
Hjalmer Lamminen
Hjalmer Lamminen
Rob Emerson
Rob Emerson
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
