Question about Hamilton Beach BrewStation 47224 Coffee Maker
Cleaning process after aprox 2 cups the coffee is not running on a full stream seems that something is clogged or needs harsh cleaning please advise.
    Master:
    Sergeant:
  • 482 Answers
Tri peroxide, let it set for a while. then run water thou it to clean it out a few times
Posted on Dec 24, 2007
Why cant I get a full cup of coffee
Brewing a Partial Cup
If the brewer is not brewing the full amount selected, it may be caused by the following:
  • The exit needle is clogged by coffee grounds or cocoa mix. Please refer to the K-Cup Holder cleaning instructions.
  • The brewer needs to be descaled. Please refer to the descaling instructions.
  • The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup pack.
Jul 27, 2014 | Keurig B60 Coffee Maker
My Keurig coffee maker seems to be clogged - it spits out just a little bit of coffee, or none at all. How do I fix it?
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jul 17, 2011 | Keurig Platinum B70 Coffee Maker
I can't get a full cup of coffee. I've descaled my machine and it still doesn't work properly. Any other suggestions?
If your brewer is not brewing the full amount selected, it may be caused by the following:
  • The brewer may need to be de-scaled. Please refer to the de-scaling instructions.
  • The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup.
Jan 14, 2011 | Keurig B60 Coffee Maker
My Keurig was running fine and recently I purchased a box of Timothy's coffee which seemed to have bubbled lids...since then my machine doesn't brew and entire cup of coffee and it shuts off when its...
I have the same problem. Timothy's seem to be the culprit. I hate to blame a specific k-cup, but I can run a cup of my wife's favorite (non-Timothy's) through right after I have the problem and they work fine - so that clearly points to the k-cup as the problem. Maybe they are more full of grounds or manufactured weaker...when I have the problem, I took apart a k-cup and the filter had broke, therefore all grounds were clogging water exit... I love the Timithy's coffee - best taste and strong, but maybe they aren't designed the best.
Nov 18, 2010 | Keurig B60 Coffee Maker
After cleaning/descaling my coffee maker still
If you put water in the basket, does it empty rather quickly? If it does, have you tried putting in a paper filter to help with the spillage?
Nov 24, 2009 | Keurig Coffee Makers & Espresso Machines
I have a Jura S9A that is about 2 years old, brewed about 1600 cups. Regular filter changes/cleanings. When I brew a coffee, it dribbles out, but makes a full cup of coffee. It also has trouble getting a...
It's all plugged with 'lime scale'. That's the white stuff that builds up from hard water. Regular vinegar run through at least two cycles will clear it, then a couple with fresh water to rinse it. That will bring it back to normal flow!
Oct 10, 2009 | Jura Capresso Impressa S9 Coffee...
First cup of the day ony fills half way
Have you cleaned the exit needle? Seem to be clogged up, more info here: http://www.keurig.com/help/B60_Use&Care_guide_spreads.pdf
Nov 16, 2008 | Keurig B60 Coffee Maker
Keurig Special Edition B60
I assume your coffe maker used to produce more coffee for each use. Roughly 6 ounces per large cup, and now is only making 3 oz. cups.
If your coffee maker is sputtering and not able to "suck" enough water to fill your cups of coffee it is most likely due to cavitation caused in the little pump due to a stoppage, which is most likely lime or scale buildup somewhere in the pump line.
To fix it, don't take your coffee maker apart. Get a bottle of distilled white vinegar, and pour it straight into the empty water resevoir. Press brew with no coffee pod so you are just running the vinegar through the system. Pour the vinegar out of the cup and back into the resevoir. Add some ice to cool it off. Repeat about 10 times. This should clear out the toughest lime scale clog.
After you notice the cups are filling full of water, Replace the vinegar with fresh water. Run about 5 or 6 cups of fresh water through the system to get rid of the vinegar.
Make coffee/tea/whatever.
Jade
Oct 06, 2007 | Keurig Special Edition B60 Coffee Maker
Hamilton Beach BrewStation 47224 Coffee Maker Logo
172 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
jason
80stech
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
