Question about Samsung DLP HL-P5663W 56" TV
There is an oil leak somewhere at the tubes dripping at the pcb's. Was told by the technician that the pict tubes has to be replaced.
    President:
  • 788 Answers
Wait, there are no picture tubes in an DLP set. This diagnosis cannot be correct. I would consult another service center for a complete diagnosis.
If you have further questions, please respond to this post. I might be able to help you if I knew what your symtoms are.
Thanks for using FixYa
asnowman
Posted on Oct 07, 2009
    President:
  • Samsung Master
  • 1,922 Answers
Your pix tube must be cracked and the coolant/focus fliud is leaking out
  • 31 Answers
Theres a clear oily liquid between tubes and lenses, this produces an even picture quality throughout the entire screen, the seal for that tube has failed and either needs repair or replacement.
My imperial deep fryer is leaking from somewhere. Is there suppose to be a drip pan?
No, there is no drip pan. If the oil is leaking from the drain spout, you can screw a plug in it. If it is leaking from the tank around the burner tubes.... then you need a new fryer.
Apr 16, 2016 | Imperial Kitchen Appliances - Others
Why is oil pouring out of my air filter on my tw 125
Hi Allison,
If you are sure , that it is JUST OIL, its OK :-). I mean, the air filter of TW is originally soaked with oil, thats how it works. If you take it out, it should be wet from oil but not dripping It has a hose for excess oil in the bottom (see pict)
take the hose out and clean it. Maybe it is full.
Be sure to check, whether it is not the FUEL that is leaking. In that case it would be a carburetor issue. Also check the oil level of engine.
Jul 04, 2012 | 2000 Yamaha TW 125
Water was found leaking from my oil pan and car is overheating. I have a 95 Mazda MX3
Is it leaking FROM the oil pan, or dripping OFF the oil pan?
If its dripping OFF the oil pan, that leads me to beleive you have a coolant leak somewhere. Check the coolant level. Check for leaks.
Check your oil, if the oil is milky/coffee colored. Or if your coolant looks kinda nasty, you may be looking at a headgasket.
Jul 05, 2011 | Mazda MX-3 Cars & Trucks
Oil is dripping from somewhere out of front of engine and burning when you step on gas pedal. What is the problem?
Well, I have never heard of an oil leak that only drips and/or burns when stepping on the gas pedal. Other than that, all I can say is that the problem is that you have an oil leak. You must VISUALLY inspect the engine to find out where it is leaking from (Hard to do over the internet). If you can tell me exactly where it is leaking from, I can give you instructions on how to repair it.
May 15, 2011 | Daihatsu Rocky Cars & Trucks
Oil leak in engine.Replaced the head gasket now oil is leaking somewhere in the engine. put in new head bolts 2 times but couldn't torque to specs. Why is there oil leaking and how can I find out what the...
Well, you might check the real main seals. Also, if you cant torque them to specs, the head could still be leaking. Your best bet is to lay a piece of cardboard under it and see where the oil drips from. Then trace the leak up from there. Otherwise, raking it to a shop might be your only resort. Good Luck.
Apr 02, 2010 | 1994 Toyota 4Runner
Leaking green tube that needs to be replaced
It wont be worth it, when you change 1, it is strongly sugested you replace all 3, and they cost around 200$ a piece, but just so you know, they cant leak, unless you break the glass at the top
Dec 15, 2008 | Sony KP-46WT500 46" Rear Projection...
Samsung TV
What colour raster it seem like you got the coolling oil inside the picture tube leaked out is typical from Samsung to confirme your problem you should open the back of your rear projector and look if you see any sight oil or liquide on the PCB printer circuit board if yes it require an technician to remove the PCB and clean this oil if not too much damged and install 1 modifications kit if no oil leaked you might have problem in high voltage it call deflection PCB part No.BP94-01259G or L you still need to adjust convergence after replace a new DEF PCB require Technician level 1
Cheers
Nov 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
Leaking Oil
No,the only good solution is to replace the seal.I have tried different additives and none seem to hold up very long.Good Luck!!!!
Aug 04, 2008 | 1994 Isuzu Rodeo
Samsung DLP HL-P5663W 56" TV Logo
502 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
