Question about Canon Pixma iP6000D InkJet Photo Printer
Faces too pink in my ip6700D
All the faces are comming out just a little too pink. All the rest of colors in the photo are just fine.
  • 1 more comment
  • Hollybelle Dec 28, 2007
    IP6600D - Same problem. Photo editor image is perfect. Printed pictures look like subject has been out in the sun too long.
  • jeahue Dec 31, 2007
    We are having the same problem. The faces are too red and pink. But other items in the pictures are normal.
  • Anonymous Jan 07, 2008
    faces are too pink Have cleaned several times, but still have problem.
    President:
  • 4,402 Answers
Solution: Manually adjust color from the driver (Windows)
Manual Color Adjustment Follow the steps below to make fine adjustments to the color hue for the printed output. These settings will only make minor color adjustments. If more drastic color adjustment is necessary, use an image editing application.
  1. On the Windows desktop, click 'Start', point to 'Settings', then click 'Printers' (Windows XP: On the Start menu, click 'Printers and Faxes', Windows Vista Click / Select Start from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'.).
    Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
  2. Windows 2000/XP/Vista: Right-click the printer icon, then click 'Printing Preferences'. Windows 98/Me: Right-click the printer icon, then click 'Properties'.
  3. On the Main tab, select 'Manual' for 'Color Adjustment.'
  4. On the Manual Color Adjustment screen, adjust each color individually to achieve the desired effect.
    Note: This screen may vary depending on model.
Posted on Jan 15, 2008
Changed bulb, people faces are still pink, purple, green. You never know what you will get. the color is fine for the first 15 min. or so.
well at this point if you took a look at the color wheel and it is ok and have color problems then the problem will be coming from the DMD board
you need to replace the light engine
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!
Oct 20, 2010 | Mitsubishi WD-57731 57" Projection HDTV
Orange faces
Under printer driver properties clean the print head.
Use only genuine ink crg.
Use only genuine photo paper.
Jul 02, 2010 | Canon Pixma iP6000D InkJet Photo Printer
Epson Stylus Photo R340 Faces in photo are printing day-glo green
Possible printhead or driver issue.
Are you using Adobe photoshop? Please try to print also using a different application to isolate the issue.
Make sure that you are using correct epson cartridges.
Please print a nozzle check pattern. If you see gaps, missing colors or missing lines on the pattern, clean the printhead using the driver.
If the nozzle check pattern printed out successfully, please trash and re-install the drivers. The driver is available on epson.com
Apr 29, 2009 | Epson Stylus Photo R340 InkJet Printer
My IP6700D prints some color but with a green cast
Someone forgot to peel the tape off the PM cartridge, must have been me.Thanks
Jan 04, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
When we print out a photo on the Epsom Stylus R300 the faces seem to have too much pink in them.
Right click on your printer in the control panel. In the window that pops up right click on the epsonR300 icon. Then click on printer preferences. From hear you can adjust your color levels. If this does not work, un install and re install the driver and software for the printer and if all this does not work try changing the ink cartridge. it may be defective. Hope this gets you up and printing with great color. If this helps you at all please take the time to rate it fixya. If you have any questions feel free to ask.
George
Jul 25, 2008 | Office Equipment & Supplies
Canon iP6700D printer
Browns printing pink suggest the blue/yellow jets are clogged or not functioning. If the uses head in cartridge type[that is with a sheet of contacts on the front of the cartridge- then take then out ,damp a tissue in some warm water an place on a plate or similar - then stand the cartriges in the damp tissue until the tissue turns colour - then replace the cartrdge. If it is head in the printer Then take a look here www,fixyourownprinter.com
May 24, 2007 | Canon Pixma iP6000D InkJet Photo Printer
Canon Pixma iP6000D InkJet Photo Printer Logo
216 people viewed this question
old marine
old marine
