Question about Daewoo Car Audio & Video
The radio display light is too bright - can it be dimmed?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
I searched and searched but I could not find anything about adjusting the light on the radio using any of the controls on the radio.
I have an idea though. Why not try placing a cut out piece of window tint over it? It's available in all sorts of darkness. Just play around with it until you find the right darkness or try overlapping 2 or 3 pieces. (Tail light repair tape also comes to mind if you don't mind a red glow, might even look cooler that way. hehe)
Another idea is to try using a piece of tinted plastic that they use to cover headlights.
Posted on Oct 07, 2009
Testimonial: "Good idea, if all else fails - rather surprised that light cannot be dimmed"
I opened the control panel and painted slightly the LED's with a permanent marker. That solved the problem for me.
Posted on Feb 22, 2013
Which fuse is for the instrument panel back lighting?
Does the radio play ? Are any other back lighting components not lighting ? Does the HVAC control panel light up ? You probably need new radio !
The second interior lighting group includes lamps which may be dimmed. This group may use a combination of vacuum fluorescent (VF) illumination, LED illumination and incandescent lamps.
When the ignition switch is turned to the RUN position, the radio VF display turns ON at maximum brightness. When the park lamps are ON, all incandescent and LED back lighting turn ON at the dimming level indicated by the instrument panel (I/P) dimmer switch. At the same time all VF displays dim to match the indicated dimming level. The panel dimmer switch potentiometer is an input to the body control module (BCM). When the driver selects a dimming setting by moving the I/P dimming switch potentiometer, all incandescent back lighting lamps are provided with a specific voltage. When the I/P dimmer switch is moved from MIN to MAX, all VF displays, as well as all incandescent back lighting respond from minimum intensity to maximum brightness in response to the I/P dimmer switch.
Dose
Jul 14, 2015 | 2008 GMC Sierra 1500
Why doesnt my wave radio screen light up when the lights in theroom are on ?
That doesn't make sense does it? A few things first.... how bright are the lights in the room? Is the display of the WAVE facing the lights? The radio has a photo sensor that detects light, but for it to be effective, it has to "see" the light. It could be that you have a bad photo sensor, but I would try a few things first. 1. Make sure the light in the room is sufficiently bright. 2. Make sure the display is pointed in the direction of the light. 3. Make sure nothing is covering the photo sensor (like a piece of tape or something.... maybe a previous owner wanted to "turn off" the light". 4. If none of the above get you going, shine a flashlight at the photo sensor (a bright one). This should turn on the display. If this works (and nothing else did), that just means you ain't getting enough light to the sensor under your normal conditions and you will need to correct that underlying problem first,
May 29, 2015 | Bose Wave Radio
How to keep the radio light on?
The sensor behind the plastic readout window needs to be exposed to a sufficient amount of light to alter the display brightness from dark room mode to bright room mode (dimmed display, bright display). Be sure sufficient light falls on the digital readout display when desiring the display to be at its bright mode setting.
Apr 26, 2014 | Bose Wave Radio Am/fm Awr1-1w Remote...
Display light not working. can't see time at night
From the manual:
This alarm clock radio features an adjustable display backlight, with dim, medium, and bright settings. To select a backlight setting, press the Snooze/Dimmer Bar until the desired brightness is reached.
Dec 01, 2013 | Timex T309TT Clock Radio
Radio display is not bright
Press and hold alarm time for about a second, then press your tune/playlist button until your bright hi or bright lo choices display, once you chose which lighting you want, do not press anything else. It will set to your last selection.
Oct 31, 2010 | Bose Wave Radio
Lcd display very dim
My clock display is extremely bright, is there a way to dim it? thanks Natalie natalie1959@gmail.com
Jun 18, 2009 | Bose Wave Radio
Blue LED display too bright
TRY........with radio on and set on "AM", hold "Clock" button about 7 seconds and let up - bringing a setup menu. Using tuning knob,scroll to "Hardware". Press tuning knob in, bringing up contrast menu. Press tuning knob in, bringing up "contrast level". Turn tuning knob counter-clockwise to "00". Brightness, dimming level should be "170". Turn radio off to exit, then adjust "Dim" button to your liking.
Nov 02, 2008 | Boston Acoustics Recepter Clock Radio
Wave Radio-dial face,display very dim.
Our Bose did the same thing after a power outage. This one doesn't have a CD button, so we tried holding down the Clock button and used the volume control and that seems to have fixed it.
Mar 23, 2008 | Bose Wave Radio
Bose wave radio/cd
Found this in the manual:
To adjust the display brightness -
The display dims automatically to medium or low brightness, as appropriate for low light room conditions. You can adjust the brightness setting of the display for both strong light and lowest light environments, but not for the medium light setting. Turn the system off before setting brightness levels.
• In a strongly lit room, hold down CD Mode and press Volume up or down to adjust the setting between 5 and 9 (it is preset to 8).
• In a barely lit room, hold down CD Mode and press Volume up or down to adjust the setting between 1 and 5 (it is preset to 2).
• If you do not want the system to dim automatically, set both levels to 5.
Feb 25, 2007 | Bose Wave Radio
Car Audio & Video Logo
308 people viewed this question
Top Daewoo Car Audio & Video Experts
xxxxxx xxx
Are you a Daewoo Car Audio and Video Expert? Answer questions, earn points and help others
