Picture probs with Orion 14"CRT TV
I have an Orion 14"CRT 12/240vTV. 2 problems(may be related)
Prob.1:On start-up,screen will often 'ficker' and/or have black and white diagonal lines across the screen(occasionaly it will start with just a very 'thin' picture) A 'technical tap' will usually fix these problems, but lately the tap has to be firmer, and I'm not happy hitting it too hard!!Occassionaly the set cuts out (stops) completly(no pic/no sound) and then start again,sometimes without a 't/t;.
Prob. 2: When connected to a VCR, we get a very distorted, and reddish picture, sound OK.
Both probs seem to occur on both 12v and 240v.
Ian
  • 8,457 Answers
U know how to solder?Take the tv aparts,take a screwdriver back the plastic handle side taps around,resolder that part,or replace it.
Posted on Oct 07, 2009
  • 31 Answers
There is a poor or many poor solder joints in the vertical section of you tv, this is a simple repair for a technician. the set should not be used until this is fixed or this could damage other parts of the television.
  • Pimpinaudio Oct 07, 2009
    there is a poor or many poor solder joints in the vertical section of you tv, this is a simple repair for a technician. the set should not be used until this is fixed or this could damage other parts of the television.
Some keys didnot work. num and litters
First, try to find out if the issue is related with the hardware or software..
1. go to BIOS
2. press the alphabets which are not working (if you get beep the prob is related with software if not the prob is with hardware)
----------if its hardware related------
1. power drain by removing ac adapter, battery n other accesories connectd
2. go to BIOS n set it to BIOS default
3. check if its working in BIOS page which are not working in the desktop screen(if its not working, the prob is related with the hardware issue. it has to be given for service
--if the prob is related with the software--
2. do system restore (all programs -> accessories -> system tools -> system restore)
3. try BIOS default
4. Update BIOS
5. Uninstall the drivers
6. restart
7.try system recovery
(if it doesn't work, its to be given for service)
let me know if it works
Jun 16, 2011 | Toshiba Satellite A40 Keyboard
Picture on tv keeps going out and coming on
If the previous posts didn't fix youru problem, and I doubt they did, then you most likely have a weak CRT and the video is being muted. you can sometimes tell if that's the problem by turning up the screen voltage slightly to see if the picture comes back on. If it does, then the CRT is weak. This is a very common issue with Sony CRT TVs, and can sometimes be rejuvenated by a good shop for fairly cheap.
Oct 20, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
We have an orion 2501B TV.no vertical display
The vertical Ic maybe are damaged and some of the electrolitic capacitors near by
Jun 30, 2009 | Orion Televison & Video
Tv picture is shrunk to the middle of the screen and turns off
if you mean line across middle no vertical deflection prob circuit prob. need tech.
Dec 13, 2008 | Zenith C27A24T 27" TV
Picture size is shrinking within screen
hi there, you have vertical section prob., repalce imeditely the electrolytic capacitor at the vertical section. do some test and check up. ty
Feb 18, 2008 | Philips 27MT3305 27" TV
Screen is "shrunk in"
hi there, you have a horizontal section prob., a defective capacitor with low microfarad like 1 to 10 mfd, or resistor, it maybe a pic cousion prob. at the horizontal sec., do some check up and testing.
Feb 17, 2008 | Sharp 32U-F510 32" TV
2 Problems
1st problem-reduce the supply voltage on the power supply to the recommended 95v.if prob does not clear change suspect capacitors around the line output transformer. 2nd problem-check;continuity of av-cables ;dry joints on av inlet sockets of the tv card.
Aug 24, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
139 people viewed this question
Top Televison & Video Experts
Electro Med Services...
