The door on my cd rom cant not open when i eject, i dont hear the motor but the light shine just at start up
    Sniper:
  • 77 Answers
Look on the front of your cd-rom, there should be a small hole somewhere just under the tray portion. Turn off your machine (to avoid possible short-circuit issues) and use a thin piece of wire (ie: a straightened paper clip) and insert it into this hole. Push it gently, you will be able to feel the unit unlocking itself and the tray will open slightly. Now you can use your fingers to pull the tray open. Be gentle when opening, you don't want to mess up the gearing.
Posted on Oct 07, 2009
  • 38 Answers
On the cd rom there will be a tiny hole. You need to insert a pin (blunt side) and be careful not to harm yourself with the sharp side. This hits the internal Eject button and should open the cd rom drawer for you.
Gateway dx4200 09 dvd drive will not eject?
Unable To Eject DVD From DVD-ROM Drive With The Eject
The DVD-ROM drive will not open to release the DVD when the button is pushed on the drive. RESOLUTION:
  1. Shut down the program that you are installing or running that uses the DVD-ROM drive.
  2. Wait 10 to 15 seconds, and then open the DVD-ROM drive by pushing the eject button on the DVD-ROM drive.
  3. If the DVD-ROM drive door still does not open, do the following:
    • Insert a paper clip or small pointed object into the small hole near the button on the DVD-ROM door.
      Gently push in the paper clip until the DVD-ROM door opens.
    • Remove the CD from the drive.
To prevent the DVD-ROM drive from exhibiting this behavior again, follow these steps:
  1. From the Start menu, point to Settings, and then click Control Panel.
  2. In Control Panel, double-click the System icon.
  3. In the System Properties dialog box, click the Device Manager tab.
  4. On the Device Manager tab, double-click the CD-ROM category.
  5. Double-click Toshiba DVD-ROM.
  6. In the Toshiba DVD-ROM Properties dialog box, click the Settings tab.
  7. On the Settings tab, clear the Auto insertion notification check box, and then click OK.
  8. Click Close.
Dec 03, 2013 | Gateway DX4200-09 PC Desktop
Cannot find eject button on laptop
I assume you want to eject a Disk? Usually there is a button on the DVD?CD Rom drive door. You can open the the Rom drive by opening the Computer folder in Start Menu, right click on the device Icon, choose EJECT and click.
Apr 20, 2013 | Fujitsu Siemens Computers & Internet
1st sorry for my bad english ... but my cd rom dont want to open . when i press the button the green light turns one and i hear a sound, but the cd rom dont open , can u solve this please? ... thnx
This happens when the drive motor inside dies.
You can take a small paperclip and insert it into the tiny hole you find in the face of the drive to manually open the tray. Use this method to remove any disk stuck inside of the drive currently. go to www.newegg.com for a cheap replacement drive.
Aug 24, 2011 | Samsung (SC-152) Internal 52x CD-ROM Drive
Cd rom door wont open
Do you see blinking light on your CD Drive. If not, you may need to check you power supply to CD Drive.
If yes, may be door looks jam, opening up once may remove any dust to smooth it out again. To open up there is small pin hole on cd drive, generally on the right side, use needle and press it through the pin hole, it will eject the CD Door and you can pull it out completely.
May 13, 2010 | Computers & Internet
CD-ROM not opening
The eject mechanism is driven by a seperate belt. You'r's is worn or broken, however, there is a small pinhole in the face of the player that you may stick a paperclip into and the tray will open.
Oct 09, 2009 | E-Machines emachines (emachinees) CD-ROM...
When I press the bottin on the dvd burner to open the door, the green light comes on and i would hear the door try to open but no open.
yes frn this is happen due to the jam in the DVD rom. when you press the eject button put one pin in the hole that is just below the eject button. so that you can eject your DVD. or just hit the cd ROM slowly.
May 16, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
The cd door does,nt open
Make sure you feel some resistance when pushing, also try by going to My Computer, righ-click the CDRom and select eject (in case the eject button is broken.
If you hear bad noises, you'll need to replace the CDRom
Mar 29, 2009 | E-Machines emachines (emachinees) CD-ROM...
CD Rom
Well...first lets make sure the drive still can physically open.
http://i36.photobucket.com/albums/e40/freddyhard/CD13.jpg
There in the picture will show you where the manual eject button is. Use a paperclip and push the button in the hole. Once the drive is open enough for you to pull the tray, go ahead and pull it as far as it will come out. It will stop, and it shouldn't come all they way unattached from the rest of the unit.
Go ahead and take any cd or dvds that was in the drive out and turn your computer back on.
Once into windows, push the regular eject button and the drive should close the door itself. Let it sit for a second or two, and try hitting the eject button again. 9 times out of 10, that usually fixes my drives.
Hope this helps!
Jan 15, 2008 | Memorex 32023252 Internal 52x CD-ROM Drive
The cd-rom door not open
Sir,
You have encountered a problem often seeen in LG models. It could have spontaneously generated or as a sideeffect of recent servicing. It is difficult to correct. so an alternative way is use a pin to force open the door.
On the front panel there will be a small mm hole through which insert a straightened paper slip to force eject the door. once door is out a little. pull it or use button to fully take out the tray.
For future, always keep a cd rom inside. that will probably let you eject the tray automatically. Problem occurs usually only withthe empty tray. good luck
Dec 04, 2007 | LG (CRD-8400CB) CD-ROM Drive
My dvd cant eject
You need to provide more information.
A CD-ROM/DVD drive only needs power to eject a disc. It does not care if the drivers are installed, for that function, it only needs power.
If this is a new drive it might be a bad one. If this is a drive you have used before, it might have gone bad.
If you have a Disc stuck in the drive, you can always use a paper clip to preform a manual eject. Just unbend a paper clip, and stick it in the pin size hole on the front of the drive. Keep pushing until the drive door opens.
If this is new drive, make sure it is connected correctly.
Nov 10, 2007 | LG GCC-4522B (0048231293594) CD-RW/DVD-ROM...
Computers & Internet Logo
166 people viewed this question
David Payne
David Payne
