Question about Olympus DS-2300 Digital Voice Recorder
Says 'read only card' so unable to record. - Olympus DS-2300 Digital Voice Recorder
  • grahamshipp Oct 07, 2009
    I solved it myself by formatting the card.
  • 403 Answers
Check out this link for a PDF manual and Software downloads for your item from Olympus. Just copy and paste into your browser.
http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=1179
Hope this helps. Let me know if I can help you with anything else.
JimmyC
Posted on Oct 10, 2009
Need help working my camcorder/camera
In order to record, the camera needs to have a memory card installed. This particular camera needs an SD format card. If the camera does not have a card installed, the card is not properly formatted, or the card is full, you will not be able to record. Also, these cards have a write protect lock tab. Make sure that the tab is not in the lock position. The card should be formatted FAT32. If you can read the card on your computer, make sure it is not full and that the card is formatted FAT32. If you have another camcorder or camera that uses SD cards, you might want to try formatting the card, just to be sure.
Jul 16, 2012 | Mitsuba DV777 Camcorder
Dvd recorder unable to view recordings says no sd card what is this please
Sd card is the memory card u stick into the slot that said Sd card or memory card to the right side or left side edges of the unit device.
Mar 30, 2011 | Televison & Video
When I press button to take a photo the top of the screen reads Memory Card Error and the photo has not been recorded. Unable to record any new photos. Tried to take memory card out and stick it back in...
Card may have been locked I'll send you a diagram so you can see beside it's faster then i can type.
The other thing is you need to format the memory card Format not delete. Each time you download pictures to the computer you need to format the memory card. Instructions to do this are in your owners manual. most likely in your set up menu.
Diagram
Jan 13, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Im unable to read a 4gb SD memory card on my card
The card reader was not designed to read the SDHC type cards. You will need to buy a new card reader that accepts SDHC
Aug 09, 2009 | Cameras
Unable to use Stereo mix recording mode
This is a block at the sound card drivers, most vendors have removed the mixer option on the drivers causing this issue. Contact creative and ask them for a patch or fix to resolve this issue. Your system and card is working as designed with the provided driver / software.
Jan 10, 2009 | Creative Labs Computers & Internet
Lock/read only card message
Make sure all the files from the memory card have been downloaded and saved to the computer. You are going to need to format the memory card to remove the write protect/read only/lock issue. By formatting this will permanently erase all data from the memory card so you are able to use it again.
To format the card: go to Menu - to Submenu - to Format option - Start - then Start again - Press Menu to initiate the process - When done the recorder will be able to be used for recording purposes again.
Dec 18, 2008 | Olympus DS-4000 Digital Voice Recorder
Unable to install pinnacle dvd recorder for recordeing anlog vide
Regarding to your Q.1.
Please check you video card if the drive is up to date. Please tell the what type of video card do you have in your computer?
To check go to device manager then click on the display adapter and you will see the exact name of your video card.
Regarding to your Q.2.
Make sure that in the step number 1 select video source the dazzle must be selected not pinnacle file capture.
Last, Q.3 you must accomplish first the given procedures in Q.1 and Q.2 so that this will fix the Q.3
Nov 12, 2008 | Pinnacle Dazzle DVD Recorder
New compact flash card reads "blank card" then when I push record reads "full card"
I had this problem too recently. The unit needs a firmware update. The only hitch there, is that you need to send it in to the D&M Pro (Marantz Professional Equipment) Service Center to get the update. No cost to my knowledge, other than shipping.
Call 630.741.033 or e-mail techsupport@d-mpro.com and they should be able to take care of you.
Nov 06, 2008 | Marantz PMD670 Desktop Digital Voice...
Locked file ?
The folder lock can oly be solved by chosing the option "format" in the sub-menu. But please copy the *.dss - files still resting at your card at your harddisk first.
When the recorder finishes the format procedure, all folders will be unlocked again.
The "Read-Only-Failure" will occur again at recorders with differend user profiles, when you put the switched-off recorder into the docking station first and switch the power button to "on". So avoid this constellation!
Jun 19, 2008 | Olympus DS-4000 Digital Voice Recorder
Olympus DS-2300 Digital Voice Recorder Logo
417 people viewed this question
Top Olympus Audio Players & Recorders Experts
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
