Question about Maytag Performa PAV2200
Wild clacking noise while spin dry going - Maytag Performa PAV2200
  • 27 Answers
The brushis have gone in the motor they can b replaced on sum models good luck .
Posted on Oct 07, 2009
My 18" inch accutek standing fan...whenever you put it on hight speed it spin for a wild then it start to give a funny soud and stop blow the air and after a few minutes it start to blow back normal
if the oscillation is on disconnect it
it is possible that the bushes are dry and the noise is from a vibration from the dry bushes
take it to an appliance repair shop and have it checked and lubricated.
Jul 01, 2015 | Cars & Trucks
Washer started to smoke during spin cycle then a cracking noise began after that.
You may just have a defective drive belt. The motor itself will smoke under certain failing circumstances. Can you give me a model # ?
Jan 07, 2013 | Washing Machines
The spin cycle does not work
most likely during the spin cycle it make (or used to) a clacking noise?
if so the motor coupling is cracked
Jul 18, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
Clacking sound on agitate cycle only, no noise on spin
The agitate cycle uses the motor and a spring to function. The spring is made in pieces and asit gets older some of the sections of the spring break. To verify that it is not a loose drum. Ope the washer during the wash cycle andhold the drun by hand. If the noise stops lool for the loose bolts or replace the springs, they may be weak after that many years.
Aug 18, 2009 | Washing Machines
Rumble/clacking while draining & spinning
Check for debris in filter of pump assembly. The filter unscrews out of the machine. It is located behind the bottom panel. Remove the two or three screws holding the panel in place, gently ply down and you will see what looks like a handle. It will be hard to turn but unscrew it and check to see if there is any debris. Have towels near by as there will be quit a bit of water coming out as you remove it. It the unit still makes noise there is a good chance the pump motor is going.
Feb 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Spins fine, but clothes still soaking wet
Clogged water pump. Not draing fast enough. If this is helpful, please post as such.
Feb 21, 2009 | Maytag Performa PAV2200
Loud while agitating
CHECK COUP-LER BETWEEN MOTOR AND GEARBOX.if coupler good,then gearbox bad.
Feb 12, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
NOISE and TUB IS WILD WHILE SPINNING
Is this a new occurence or has it been that way all along? What type of floor is your machine installed on? A soft floor such as pergo or soft shiny lino can cause the washer to be a wild monster when it spins. We placed a commercial type rug with a thick rubber back completely under our washer and that seems to hold it in place perfectly. I received this advice after a service call.
If it has not been happening all along, it could be that you have a problem with the machine being unlevel or that you do have a problem with the tub. Does the tub actually seem loose if you turn it with your hand when empty? Extra heavy loads will contribute to a wild spin as well, and loads that are mixed items. (such as towels with cotton shirts.) it is better to wash the same with each other and not too full.
Good luck to you and thank you for using Fixya! if you have anymore questions or comments, please feel free to get back to me.
Aug 21, 2008 | GE WPXH214A Front Load Washer
Washing Machines Logo
61 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
