Question about Frigidaire FRS23KF7AB Side by Side Refrigerator
Frigidaire Icemaker not making ice.
We had a power outage. After the power outage, the icemaker stopped making ice. At first I could not get the raker arm to turn, but now it turns. However, the ice maker doesn't seem to cycle. Nothing is happening. The ice tray is empty, now water in it. I'm getting water to the water dispenser on the door. So I'm wondering if maybe the water line to the ice maker is frozen? How do I troubleshoot this issue to see if it is a frozen water line or a broken ice maker. The icemaker is one with the metal on/off arm.
Same problem, I had several power outages in a day recently. Don't know if this is when it quit making ice or not. The tray cycles, but no water ever enters the tray. I've tried the hair dryer on the tube and the back part of the freezer around it. What's the next step to diagnose the problem?
  • 2 more comments
  • slowride Jan 01, 2008
    I have a Frigidaire Electrolux.The water despencer puts out water but the ice tray doesn't get water. is there a way I can check it to see if it is clogged? I too had a power outage around the same time. Could this be the cause?
  • myschne Jul 31, 2008
    Prior to leaving on vacation, i turned off the main water supply to my house. After returning and turning the water back on, the ice maker is not making ice. It appears no water is in the try. water dispenser works. I seen the ice maker cycle. but did not hear the normal clicking when water would usually be dispensed into icemaker
  • Anonymous Nov 28, 2008
    same problem
  • Anonymous Apr 12, 2009
    ice maker is making small cubes or very little ice
  • 833 Answers
That on/off should be able to move it and it will likely make a small click when the switch goes on or off. That arm controls the ice making. There is also a float, is it working freely? It has a switch too. Ultimately, the water is controlled by a solenoid valve. It may be defective. Many of these units are removable to test the switches with a multimeter. Turn off the water and remove to test. Some parts are available...some parts are by the unit only.
Posted on Dec 24, 2007
The ice maker will not work if the freezer temp is not below 5 degrees "F". had the same problems. My defroster in the bottom back section of the freezer was frozen in a block of ice and not allowing the freezer to work properly.
Posted on Mar 22, 2008
The ice maker and water is not working.
Posted on Feb 15, 2009
Power went out freezer won't make ice in ice maker
Hey friend, thanks for your inquiry!
Normally, if power is not being received by your Frigidaire refrigerator it will not produce ice within the icemaker. Now once power has been restored it could take up to 24 hours to maintain temperature and start producing ice. If the power went out it is possible that the icemaker could have shorted or the water valve could have went out. I hope this information has been insightful. -Matt
Oct 19, 2014 | Frigidaire Refrigerators
No ice
Sounds like ice maker is bad.
Sep 13, 2017 | Frigidaire FRS26R4A Side by Side...
Ice maker has stopped working
IT is either your inlet valve which is cheaper than replacing the icemaker, when you replace it(located behind panel on back of fridge) make sure you do not have ice build-up in the water tube behind icemaker. If that does not work than you will have to replace icemaker. If you take a flathead screwdriver and pop the cover off of your icemaker you will either have a screw that you can manually turn to test the icemaker to see if it is working. There is one you can do this with, the other one you would need an icemaker tester that most tech's have. Good luck!
Aug 20, 2010 | Frigidaire Refrigerators
The ice maker was making ice then some of the ice turned yellow and now the ice maker has stopped making ice. The freezer is still freezing the food in there.
The icemaker concists of a gearbox that has oil inside it.When the gearbox wears, it starts to leak at the shaft. Suggest you replace the icemaker.
Jun 22, 2010 | Frigidaire Refrigerators
Frigidaire freezer stopped making ice
freezer temp must be 10F or lower, feeler arm down, if icemaker is still not starting a harvest cycle there is thermal fuse inside icemaker that may have opened up.
Jan 05, 2010 | Frigidaire FRS26R4A Side by Side...
Frigidaire ice maker not working
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting
Aug 11, 2009 | Frigidaire FRS6R5EMB Side by Side...
Icemaker dont work after power outage
Make sure the ice bail wire is not lifted. If it is, the ice maker will not make ice.
The water valve may have failed to. It's in the bottom back of the refrigerator, and the water line normally connects near where the valve is.
Let me know what you find.
Jan 30, 2009 | Refrigerators
Frigidaire FRS26ZRGW8 ice maker stopped working
on your icemaker you can tell if its a internal problem or a water valve ,,,,, 1st feel inside for any ice ,,, if ice is in icemaker the valve is working ,,, pull fingers on icemaker to get it started and watch it, if it makes its cycle and fills again the the icemaker itself is bad ,,, contact me and i will see if i can help with part or parts / larry
Dec 08, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire Side by Side Icemaker
The icemaker evaporator system that releases the cubes is faulty , and must be replaced.
Apr 02, 2008 | Frigidaire FRS-26DR7D Side by Side...
Frigidaire FRS23KF7AB Side by Side Refrigerator Logo
9,437 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
