Question about OKI C3530N Color MFP Printer
How do you reset any drum on an OKI C3530N Color MFP Printer?
Change the fuse in the right side off the drum unit.
Posted on Jan 09, 2013
    Guru:
  • 355 Answers
Drum cant be reset
Posted on Oct 07, 2009
Scanner home sensor error
check for dust or any forgien particle in the scanner unit clean it ,
Jun 06, 2013 | OKI C3530N Color MFP Printer
OKI C3530N
Take cartridges out of the printer.
Close cover.
Unplug printer for 30 minutes.
Reconnect printer to power.
Printer demands cartridges.
Reinsert cartridges as demanded.
Oct 31, 2008 | OKI C3530N Color MFP Printer
Scan sensor error
what is it is it gives any error code or just can't scan
I have an oki c3530 and it is making a terrible grinding noise, any ideas?
One of the drums needs to be replaced. Systematically remove one at a time until the grinding noise no longer happens, then replace that drum.
Jan 26, 2010 | OKI C3530N Color MFP Printer
073 fatal error in OKI c3530
Oki ERROR 073 is a H/W Overrun detect. this occurs when the video circuit has set the overrun bit. Restart the printer and check the first print out. Try printing a different job and then reprint the same job that the error occurred. If you get the same error again, try using a different driver, ie swap from PS or PCL whichever you were using to see if that clears the error.
Dec 28, 2009 | OKI C3530N Color MFP Printer
OKI C3530 Fatal Error 031
Hi.. i only remove the memory ROM in the board and refixed it, then i turn on the printer and now its working :)
thanks Admin
Feb 19, 2009 | OKI C3530N Color MFP Printer
Okui 3530 toner sensor error
turn off eq - open and remove the drum with the color cartridge in locked position still in place - on the drum on the cartridge lock side you will find a small (1/4 ") rectangular "window"...with the catridge in locked position the window should be open so you can see the sensor...when the cartridge is unlocked the window should be closed...so with the cartridge locked, using a tiny pointed object (paper clip), gently move the panel up or down to the open position (mine moved up)....replace the drum with cartridge...make sure it is set properly...close up everything and turn eq back on....you may have to do this two or three times to make sure the window stays open when the lock is engaged...but this is what the "tech"(salesman) did...good luck
Nov 10, 2008 | OKI C3530N Color MFP Printer
OKI C3530N Multifunction Printer
Check the left side of the drum cartridge.
There's a little door that may be stuck closed.
Carefully push it open with a small screwdriver.
OKI C3530N Color MFP Printer Logo
636 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
