Question about Square D Qo200 2 Pole 60 Amp Circuit Breaker
I need to add a 230 volt breaker for a hot tub and the panel in the brkr box is full. what do i need to complete this task.
  • 37 Answers
You can put in a sub panel and take out another breaker to run the sub panel and then you can run what you took out for sub panel and the hot tub from the sub panel
Posted on Dec 10, 2009
  • Bob Smith Dec 10, 2009
    make sure you put a gfi breaker in for hot tub
  • 27 Answers
Get a biger box fitted is the only way hot tub take alot of power u need a sparky
Posted on Oct 07, 2009
My hot tub has an issue. Only half the display is working, there's no heat and the jets wont turn on. If I trip the curcit, I can get the hot tub jets for 10-30 seconds and that's it. HELp
Almost all hot tubs use 230 volt AC power which comes from the power company in two power wires plus one common common wire. You get common 115 volts between a common and either other wire. "Half way" working could well be an attempt to run on only one of the wires. There is also likely to be a ground fault circuit breaker in the wiring which makes sure current going out to the tub is all returned via the wires and not through someone's legs to ground. If you're comfortable with an AC voltmeter check some voltages but understand that 230 volts is way into the killing range. Two people present and well insulated probes are important.
Apr 15, 2016 | Pool & Spa
I have a new Husky Model C801H air compressor 230 Amp, how do hook up the wiring
I'm assuming you mean it's 230 volts, not 230 amps. (big difference here)..and I think it's actually 240 volts. (minor detail)
This is really a job best left to a qualified electrician, as you're going to need to have a 30-amp outlet installed (compare to an electric clothes dryer outlet, or a welder outlet).
The cord supplied with the compressor should be a 4-wire cord,consisting of 1 black, 1 white, 1 red and 1 green wire.
The green wire is the ground and it absolutely *must* be hooked up to guard against an electrocution hazard. Of the other 3 wires, the black is 1 or the 2 hot leads (the red is the other hot lead). The white wire is the neutral.
You will need a *TWO-POLE* 30-amp circuit breaker of the type that's made for your specific make & model of electrical panel. This breaker will have two separate, independent bussbar connections on the underside and 2 separate screw lugs to attach your Black & Red wires to (individually, not to the same lug). These are unique as to brand and model, so you will need the right one. If this is going in your home garage and you're lucky enough that your breaker box is there in the garage where the compressor is going, then it's going to be much easier. (much less expensive) Still I am going to stop here as I cannot recommend anyone working inside their electrical distribution panel unless they are a qualified electrician. Please hire an electrician to hook this up for you. Please do not attempt to hook it up yourself.
Dec 01, 2014 | Air Tools & Compressors
230 volt welder
Breaker must be 50A and the size wire should be a 8/3.
Feb 23, 2014 | Welding Tools
What's youI just wired in my J-300 Jacuzzi hot tub. The GFI trips every time I reset it. I took the GFI out of the equation and the tub runs fine, does not trip the breaker at the main breaker box
#1. DO NOT GET INTO TUB FULL OF WATER WITH A GROUND FAULT.
2. There is a short. You need to get multimeter and start checking each part for current running to ground wire.
3) Power is ON. Connect power without GFCI.
4) Tape tester leads to wood sticks to keep hands away from power.
5) Do not touch anything directly or you will become the ground rod.
6) Ground wire must be present, and bonded back to main panel box.
7) Do not sit or touch directly on cement or bare ground. Do not touch or lean into anything made of metal.
8) Body and parts must be on sheet of plywood, or similar non-conductive dry surface.
9) Test each part with spa, but also test electric line coming from main box.
10) GFCI will also trip with any fault detected on line. So the wire coming to spa may have the fault.
11) Add a new dedicated line from main box to spa.
http://waterheatertimer.org/How-to-wire-GFCI.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Oct 02, 2012 | Electrical Supplies
Put in a new breaker box, wiring to furnace is not right. There are 3 wires coming from the furnace, a red wire, a brown wire and a white wire. The white wire is the ground, the red wire is attached to a...
I don't know where you live, so I don't know if there is a color code used like there is here, in Massachusetts. Typically, white is neutral. Neutral and ground are not really interchangeable terms to electricians - but often are to homeowners. Read this until you understand:
1) If you have two separate bars in your panel, and one has only white and / or gray insulated wires connected and the other has only bare or green or green and yellow striped insulated wires connected, you must connect the white wire to the bar with the white / gray wires. Do NOT connect it to the bar with bare / green insulated wires.
2) If you have one or more bars in the panel, and both have a mixture of white / gray and bare / green wires, and the bars are screwed directly into the panel back - or have a jumper connected between them, you should be able to connect the white wire to any available terminal on the bar(s).
Colored insulated wire (not green, white or gray) usually means it is not neutral or ground. In an electrical panel, most times if it is not neutral or ground, it is "hot". If there are two colored (hot) wires and a single white or gray (neutral), the white goes to neutral bar and the hot wires go on adjacent circuit breaker terminals - in this case, a 2 pole circuit breaker.
Your gas or oil fired furnace likely operates on 120 volts (hence the white wire for neutral), while the AC compressor and blower is probably 240 volts (hence the need for the second colored wire). You may need to connect these two hots to one "2 pole circuit breaker" for the AC to work.
A typical 2 pole circuit breaker has two handles tied together - and internal connections.
Look at the wires to get an idea as two what size breaker they need to be connect to - #8 copper 40 amps, #10 copper 30 amps, #12 copper to 20 amps and finally, #14 copper to 15 amps. If you are unsure, and my background on the way things should normally be do not jog your memory, STOP. call an electrician and have it connected correctly and safely.
Jun 06, 2011 | Heating & Cooling
My hot tub still trips the breaker,and i replaced it with a new gfci. What other things can i ck.
If your hot tub is pulling more amps than amps sent your breaker box, you'll keep tripping the breaker. Check the rating on the hot tub and compare that to the breaker rating. You may need to uograde the wireing. Make sure the wire gauge is up to code.
Mar 21, 2010 | Balboa Instruments Duplex Digital Panel 2...
Running a 220 volt 40amp service for my hot tub.
By code, this would require underground cable to a breaker panel with a double pole GFI (maybe that's what you were planning). Then from the breaker panel to outlets, pumps, etc.
40 amp breaker will require 8 AWG cable.
More info, let me know...
Charlie
Aug 23, 2009 | Qca Spas GT 396 Hot Tub
115 volt 20 amp breaker for hot tub keeps tripping
Is there anything else on the same breaker? Is that the proper amperage for the pump? How long has the pump been in service? It may need to be cleaned as possible obstruction causing too much strain.
Nov 29, 2008 | Waterway 1.5 Hp 115 Volt 2 Speed Side...
Generator electrical
On a 230 volt std hook up here's the way it is supposed to work. From black to white you should get 115 volts. From Red to white you shoudl get 115 volts. From red to black you should get 230 volts.
Concentrate on getting the correct output from the generator with the load to the house disconnected
This should be 115v (black to white, 115 volts red to white and 230 volts red to black.
On the load side (ie, the house connected) what are you using? 115 volt lights, etc on one side of the
230 volts, and some other 115 volt loads on the other side.. Are there any 230 volt loads. It could be
that one side of the 230 volts (ie, a 115 volt side is drawing a lot more current than the 2nd 115 volt leg.
Get back with me on just what the loads are botth 115 volt and 230 volt . also what are the rating on the circuit breakers.
Loringh
Oct 28, 2008 | Electrical Supplies
Electrical - Air Conditioning
Ben, you are on the right track. To upgrade the breaker, first look at the main house breaker panel and determine if allowing more current through main breaker will be taxing it too highly (will 20 more amps exceed my main breaker limit...what is the main breaker current trip at?) Then look at the wire size leading away from the 40 amp breaker to outside. If it is 6 gage copper or 4 gage copper-clad aluminum wire, you are ok to upgrade. Any smaller wire size could be unhealthy.
Sep 03, 2007 | Heating & Cooling
Square D Qo200 2 Pole 60 Amp Circuit Breaker  Logo
209 people viewed this question
Top Square Electrical Supplies Experts
Jim D
Level 1 Expert
ken skalski
JOHN LAPIER
Are you a Square Electrical Supply Expert? Answer questions, earn points and help others
