Question about Tally Computers & Internet
Tally t2133 by hp print server
I've connected my tally t2133 by hp print server but it does not print. Could you help me?
    Novelist:
  • 169 Answers
Access the the JetDirect settings, this is normally done by accessing a web page on the print server (enter the IP address of the print server in a web browser) Locate the Parallel Interface settings for the print server and set the following type of options; Speed of Connection- Set to the lowest available Bi-Directional Communication- Disable this you may need to select a standard parallel intrface type
Posted on Dec 23, 2011
Slow printing
Slow printing I have a Laserjet 4200
Jun 26, 2013 | HP LaserJet 4200 Printer
How can I set up wireless printing?
Hi Brenda,
Considering that your printer has an in-built Ethernet feature means no need for external print servers.
  • Take the printers network/Ethernet cable and then plug it into a router/network Hub.
  • Once you've connected the computer to the network,install the printers software in all the[networked] computers that will use it.
  • Now try printing.Note that,the networked computers print jobs will be printed in order received.
Hope this helps.Thanks!
Oct 09, 2011 | HP Deskjet 6940 InkJet Printer
"how to print settings for
If you are talking about one of the TallyCom print servers there is a small blue test button on the side of the box, press this when the print server is connected to a printer that is online. If you press the test button for over 9 seconds the print server will be reset to factory settings. If you want to print from DOS to a network printer as I recall you have two options; 1) Install the printer in Windows and share it, you can then print to the share name 2) Use "NET USE" command in DOS to map a local port to a network port, this is nessesaey if you can not print to LPT1 or COM1 from the application. For help of NET USE go to DOS and use the help options.
Jan 05, 2011 | Tally (43555) Print Server
Can this Tally Print work with any 7,5v power suply?
The TallyCom works with a 7.5 volt power supply, you would need to ensure the correct size connector is used and also the power supply center pin is of the correct voltage.
Also ensure the power supply is able supply the ampage required by the TallyCom
NOTE the TallyCom+ uses a 5 volt power supply do not use a 7.5 Volt power supply if the print server is the + version
Nov 18, 2010 | Tally (43555) Print Server
Error code=403, system error code=10060. This is the message tally client displays. Tally server running successfully. Pls help. thanks
Sep 14, 2010 | Computers & Internet
I want to connect the print server ESI9132079.i need drivers for this print server.
hi,
Download and read the manual of this print server.
http://silexamerica.com/us/products/pdf/xtnd/dx-sx.pdf
You only need the actual printer drivers not the print server driver (there is no such thing for print server drivers). Once you connect to network and to Print server, you should be able to see what brand printer is connected to server such as HP, Epson, Fujixerox, Samsung, etc.
Hope this helps
Cheers
Shafie
May 08, 2009 | Troy ExtendNet SX Print Server
I am not print from tally software it is getting failed
please check that u select the proper printer before preceeding for print command. Also check that the printer connected to ur system is ur default printer.
Jan 10, 2009 | HP LaserJet M1522nf Multifunction Printer...
Tally support
maybe the licence for tally 9 is stored in an area of an application server on the network you dont have security access to? Do you have a system admin onsite to check this for you?
Feb 19, 2008 | Microsoft Windows Server 2003 Standard...
Print server
Check the port configurations on both XP machines. It should have the IP address of the print server connected to the plotter.
Aug 01, 2007 | NetGear PS101 Mini Print Server Print...
Computers & Internet Logo
709 people viewed this question
Top Tally Computers & Internet Experts
Vladimir Frolov
Roy
Level 1 Expert
Neil Williams
Neil Williams
Level 1 Expert
Are you a Tally Computer and Internet Expert? Answer questions, earn points and help others
