Question about HP iPAQ H1945 Pocket PC
I downloaded a update for the thing and now it hangs up
I downloaded a update for the thing and now it goes thur to the hp print ad and the rainbow pinwheel just keeps spinning and goes no farther.did a soft and hard reset got nothing.took the batt out and still the thing hangs up.emailed hp they told me i had to send it in and have to pay for it. i like the thing but its old and not worth the money i was wondering if there was a free way to reset it. if not ill give it to my 4 year old to pretend its a phone.
thank you for your time
p.s the update file is sp26263.exe
  • HP Master
  • 2,001 Answers
HP , drivers , and updates are complex. (as are all OS)
the file must match your OS and version.
match your pC (exact IPAQ in this case)
and installed in the correct order.
pretend its a phone, best for any thing this old , it has no real value.
why not ask first before doing any updates
why did you, ?
was there some problems, yes then ask.
if there is a problem of any kind this is the first stop.
its free to ask for help. try that. please.
Posted on May 09, 2017
  • 198 Answers
SOURCE: Finger Print Scanner
Hi again. Give me your email adress please, for me to send you the required upgrades. Read my other post in the other section you've wrotten and you will have the instructions on how to do everything there. Thanks.
Posted on Jan 23, 2007
  • 38 Answers
SOURCE: HP Ipaq rz1710
I have to agree with DirtyHarry1, it sounds like the battery could be weak. On my iPAQ when the battery is done charging the charging light changes from orange to green, I'm not sure if yours will do that. I'd try leaving it charging on the cradle for about 24 hours to see if that improves the life any.
Posted on Feb 01, 2008
  • 198 Answers
SOURCE: hp iPAQ h1945 won't start
Hello and sorry for the delay.
the h1945 series is a very intresting pda. I have seen all sorts of problems relating this one. There are some things you may want to try. Based on that knoledge I may be able to find what's rong with your unit.
First, check if the back cover fits tight on the back of the unit. It's important because on some ipaq models, there is a small micro-contact that doesn't allow the unit to power on if the back cover isn't attached. I'm not sure if the 1945 has one, it's been 2 years since i've last phisically repaired one of these, but you may look for one yourself. It's a small contact near one side of the back opening, check to see if it can be pressed. If you don't have anything like this just ignore this tip.
Second, leave the pda connected to the charger for about 6 hours. Even if it doesn't do anything. Then try to start the bootloader by pressing the 2 outer keys near the D pad (simillar to the hard reset procedure) then, while keeping those pressed, press the power button and in the same time press the soft reset button with your stylus. You must do this with your charger connected to the pda. It may be difficult to achieve in the first try. Just try to do this a few times and if the pda doesn't respond even now, please post back. Furthermore, if you need more info about these 2 tips please reply.
Posted on Mar 29, 2008
  • 8 Answers
SOURCE: HP iPAQ 2490B can not be hard reset
If all else fails, remove battery from unit & let completely run down
(usually 12-24 hours), possibly longer.
Pop on charger, & unit should turn on as if hard reset
Posted on Jul 11, 2009
SOURCE: Hp ipaq rx5935 hangs at the end of the HP booting sequence
remove battery for 6 hr and reinstal and then hard reset.
Posted on Aug 26, 2009
It says can't download the update. to test your connection, open system settings ad select network settings, test xbox live connection. Then when i do that it says the same thing again
The trick is to not test the connection. Just keep trying to download the update... It might take a few tries, it might take a few hundred, but eventually it will take. I believe this problem is caused by a busy server on microsoft's end, but am unsure.... just hang in there and keep trying to download the update without testing the connection.
Nov 20, 2010 | Microsoft Xbox 360 Console
HP Laserjet 1160 and Vista
Download update from HP on Vista.
Jul 11, 2009 | HP LaserJet 1160 Printer
go into tool on pc and open paint, that,s what works for me. or call hp and they will walk you thur
Jan 03, 2009 | HP Officejet J5780 All-In-One InkJet...
My hp laptop hangs up when it goes into sleep mode
my laptop hang during working no any keyboard and mouse key working during hanging . what i do.
Sep 01, 2008 | HP Computers & Internet
"Rainbow" word art (Microsoft)
Have you tried prinitng this in MONO on your 2840 printer.
Does Wordart from Word or other office programs cause this?
If it is the office suite, then look at downloading some service packs from Microsoft.
If it's just your 2840 doing it, then look at downloading a different driver.
For some printers there are different types of PCL drivers, like PCL5 or PCL6, these do behave differently per printer, so swapping the driver might not be a bad idea.
Also check if you are using a PS or Postscript driver, but again, try the PCL alternative for your printer.
I would install the different driver under another name, for testing, then if it works just delete the bad one.
May 08, 2008 | HP Color LaserJet 2600n Printer
HP PSC1210 won't print black
I do have the same problem, and mine started at the same time. Wonder what the problem is.
Maybe it was a system update or something?
Apr 06, 2008 | HP PSC 1210 All-In-One InkJet Printer
Can't print to 1410 after I upgraded to Leopard
You need to update your printer software. Download and install from this link;
Once it is installed I suggest that you open system preferences (found by clicking the apple in the top left) and go to print and fax and delete and readd the printer so it will pull from the most recent drivers.
Feb 11, 2008 | HP PSC 1410 All-In-One InkJet Printer
Laserjet 5L Hangs on Single Sheet Input Jobs
This probably means that the document you printed is set to manual and the printer is waiting for input
try this:
print the document, when the data light is on, press the button on the printer, does it print? if yes go into word and under page setup set the printer to "Auto select" for the paper tray.
or remove paper, print, when the data light comes on, insert the paper into the single sheet tray
hope this helps
thanks for rating
Jan 16, 2008 | HP LaserJet 5L Printer
HP iPAQ H1945 Pocket PC Logo
41 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
