Question about HP Compaq d330 (DG315A) PC Desktop
My PC dosn't work
I have an hp compaq d330 mainboard 323091-001 P4SD.
By power up the mainboard is working and cpu fan to, but i get no picture on screen and the keyboard dosn't work- caps lock & num lock- nothing.
I cleared the CMOS memory - still- nothing!!
Pleas help!!!
Eli
    Scholar:
  • 138 Answers
Try cleaning the RAM as shown in the image below:
If problems persist. Replace the RAM. Hope this helps.
Posted on Oct 07, 2009
  • 66 Answers
The first thing that you should try is to clean the ram as previously said. Then if the problem hasn't solved you can 1.Try an other ram, 2.Change the motherboard witch in most cases is the reason of that problem.
HP P4SD, its running good with 4 gb RAM, P4 3.0ghz, and a couple sata hd. The problem is the fan output voltage, i havent been able to read the output chassis and cpu cooler pins voltage cause i can find...
"i can find my dmm?" did you mean CAN'T?
"its clearly off", what is off?
the fans are 3 pins,2 are power, one is RPM tachometer.
"it all works fine", so you can boot and run any OS, ?
"the voltage reads +12vdc", where, at fan or PSU?
the fans run off 12vdc, they are DC motors (from outside fan)
if the fan runs slow at 12vdc the the fan is bad or is a low RPM
fan, as some are, bigger fans run slow, for less noise.!
first is the CPU fan it must run full speed, if not the CPU will overheat in seconds and ALL CPU shut them selves (by there selves) this way. so CPU fan is first. what does it do... there....?
then BIOS screens. GOT BIOS UP? and running? with, ESC key pressed>.
let me guess your symptoms
1: PC dead. will not boot.
2: BIOS dead.
3: all fans DEAD,.
4: power switch works and all PSU voltages read right, (seems not)/?
5: if the PSU power wire reads right(DMM), matching the side sticker voltages, and the CPU is dead, the MOBO is dead, or CPU is toasted.
here is a modern PSU, sticker.
see 5 to 10 power lines, see them. all must read correctly
if a fan is dead, then its dead if 12vdc is present on the fan power pins.
Apr 28, 2017 | HP Asus Motherboard P4SD-LA Socket 478...
Not swithching on, if connect to power flashes a green light,motherboard light flashes also on green,fans off,harddrive not spinning.whats the problem
hello iam vishal i will tell you the solution,
1)open the cpu
2)clean all the parts with a cloth
3)remove harddisk ,cmos battery and for reinsert after 5 minutes
4)remove the wire and re-attach all the pc wires
run the pc
5)problem is solved
Mar 31, 2011 | HP Compaq Business Desktop d330
It doesn't start when the power button is pressed the led lights but when released it goes off. it does not start at all
The power supply is defective and it needs to be replaced, if the computer is still under warranty then contact Compaq if it's out of warranty then either buy a power supply to replace yourself or bring it to a computer shop to get it replaced.
Feb 28, 2011 | HP Compaq d330 (DG315A) PC Desktop
When i turn my HP Desk top monitor displayed fan pin not connected,Then bottom of screen has F1 for booting,then we press F1 windows has start up. THX
can I buy some puctuation?
i can not understand most of that.sorry....
D330 PC, check
unstated monitor, what monitor of 1000s/?
post all that works and not, only all facts solve problems
we are blind here, cant see you or it. (those parts)
"displayed fan pin" i read that 10 times and draw a blank...
i see your screen is not dead ,it prompts you with text
I bet the BIOS hot key work , do they ,sure.
OK yes, the F1 joy, this is when BIOS discovers that the COIN cell is dead, as all PCs are this old,
dead dead dead, its just $2 coin cell battery
see this
https://support.hp.com/us-en/product/hp-compaq-d330-desktop-pc/342066/manuals
see
service man
http://h10032.www1.hp.com/ctg/Manual/c00059138
see page 46
BINGO, coin cell *****.
wow it lasted 11 years, , that be like a world record
Id frame the sucker.
Oct 13, 2017 | HP Compaq Business Desktop d330 Slim Tower
Need spare no: 308615-001 for HP Compaq d330uT computer.Show picture and assembly instruction
search this site...
http://www.sparepartswarehouse.com/Compaq,Computer,Part,308615001.aspx
power supply
to motherboard..
put the power connector to power socket of the motherboard..plus the 4pins connector to the 4pins socket into motherboard..
put the power connector of power
Oct 25, 2009 | Compaq D330 PC Desktop
920-fan command 2 pin connector from power supply not connected
then connect the fan to a 2-pin connecter if you cant do it take it to a computer place to do it for you
Sep 22, 2009 | HP Compaq Business Desktop d330 Slim Tower
HP d330 fried during pwr serge, fixed, boots but no screen signal
there are several possibilities. 1. replace the ram, make sure that its a good working ram module. 2. review all your work from system board to power supply. 3. try running it temporarily without the cmos battery. 4. check your monitor. 5. check your VGA. 6. retry and retry.
Jul 13, 2009 | HP Compaq Business Desktop dc5800
HP Compaq d330 (DG315A) PC Desktop Logo
339 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
