Question about Canon EOS 450D Digital Camera
Connection problem with Canon 450D to PC.
I connect my canon 450D to the PC via USB. The Adobe elements picks up the camera and the camera shows BUSY on the screen. Elements shows connecting to device ... please wait message. After about 5 seconds the Canon stops showing Busy and the screen looks like I had just switched on without the USB connected. Elements then says the Device is not connected or busy. I have tried different USB cable and Port. Restarting windows etc all to know avail. This was all working fine two days ago and nothing has changed. Help !
  • 2 more comments
  • tim2122 Oct 07, 2009
    Will give it a try. Will be this evening before I can do it. I have tried just accessing via MY COMPUTER but the same things happens in that I can see the camera for a few seconds and then it disconnects. I will update once I have tried a REINSTALL of the cannon software. Thanks
  • tim2122 Oct 29, 2009
    Hi, Nope it didn't. What I did was reinstall the canon software but this did not help. However it is now working and I think this is due to a Canon firmware upgrade (to be carried out with caution)http://web.canon.jp/imaging/eosd/firm-e/...
    I did also deinstall some other software just prior to this which may have had an impact but I cannot be sure (sorry).
    Cheers, Tim
  • Marvo2 May 11, 2010
    Hi, This happened to my 350D once.. I ended up deleting the camera hardware from the computer and reinstalling the hardware cd and that cracked it.. Any luck??
My 450D is having this same problem. i have been fearing it might be a malfunction of the "digital terminal" (the cable "slot" on the camera itself) since the warranty ran out two months ago. did reinstalling the software help?
Posted on Oct 29, 2009
    Brigadier General:
  • 11,967 Answers
Use a card reader to download your pictures to a folder you create on your desktop.
Posted on Oct 07, 2009
Importing videos from sony hvr-hd1000e to premiere elements
hi,
you have to connect to your computer via FireWire cable, not USB !
Jul 16, 2013 | Adobe Premiere Elements 10
Canon 7D eos utility able to view all pictures select but when hit "download" keep getting a "busy" in red at bottom of dialog box and won't let me download or delete pictures...why???
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jun 28, 2010 | Canon Digital SLR Camera Kit - EOS 450D +...
Pc says camera is busy
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jan 11, 2010 | Canon EOS Rebel XSi Digital Camera
Canon 450D - Error 99 only when flash pops up
Flash Tube is bad inside the Flah head, tccamerarepair.com
Mar 08, 2017 | Canon EOS 450D Digital Camera
Probably the same problem as cate_cahill on Oct
Your description of the problem is confusing to me. First it seems you are saying your camera doesn't take a raw file in addition to a jpg. Then it seems you're saying when you look at the files using another reader the raw file is there. Usually you can connect your camera to a PC using the USB connection and it will show up as a removable drive, if you do not have the Cannon software on your PC. You can then drag the files into a folder on your hard drive. At some colleges they only use client PC's and applications reside only on their servers. It takes administrative permissions to attach drives or load applications. That MAY be the case where you attend. If this doesn't help you, please clarify whether the raw files can be seen on the Jessops card reader or not.
Dec 04, 2009 | Canon EOS 450D Digital Camera
No longer able to connect 450D to computer
When you tried the other 450d, did you use your cord or the other person's cord? You could try a camera reset. Go into the menu and scroll to "reset"...follow the on-screen instructions.
Dec 01, 2009 | Canon EOS 450D Digital Camera
Canon 450D is not being recognised by my computer (I run xp 32-bit). When I turn on the camera, windows comes up with a "install new hardware" option. I have installed the EOS utility etc. but still the...
Both the Canon XT 350D and the XTi 400D are recognized by any PC with XP windows operative system. It seems you have to check your USB port or USB cable used to connect your cameras to the PC. Sometimes, the PC does not recognize a specific device connected to an USB port. Yopu can get into the System -device manager screen, and uninstall the USB port, and run the utility to recognize changes in the device manager. This will install the USB port driver again, and if it is a software issue the reason of the problem, then it will be fixed.
Also, you can check your cameras and USB cable in a different PC so you can confirm if they both work has should be.
Regards,
Mar 26, 2009 | Canon EOS 450D Digital Camera
PROGRAMS TO DOWN LOAD MY FS10 TO A PC WITH USB AND IEEE1394 PORTS
I've found that Windows Movie Maker (built-in to Windows XP), Adobe Elements, Adobe Premier, Sony's Vegas Video and  Pinnacle all work well with my canon camera.
Jul 16, 2008 | Computers & Internet
Camcorder as source for video software not found
if you have a nv-gs35 i am pretty sure that ths camera can not do video transfer via usb, the port is not usb2. it can transfer video via the dv port only. please check the operating instructions.
Mar 16, 2008 | Panasonic PV-GS35 Mini DV Digital...
Canon EOS 450D  Digital Camera Logo
957 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
