My insignia NS-LCD42HD LCD TV has not picture and the power/standby light is flashing Red/Blue alternately.
  • 1 more comment
  • ukmoss Oct 07, 2009
    The last answer sounded like a guess. Has anyone actually encountered this problems and knows the cause. If it was power supply, how would the power/standby light be on at all?
    I checked the fuse. It is not opaque, so I can't see if it is blown. There is no discoloration on the fuse. I will have to go get one to check anyway. I left the TV unplugged all night and nothing changed. There is no info in the manual about the blinking lights and what they mean and nothing on the web I can find. Hence I am on this site. We tried hookimg up the camcorder for playback via another input but could not get the TV fired up. I am not qualified to remove the cover. I will try a new fuse. Will post info when I do it.
    Thanks for the advice. I checked the fuse and replaced it anyway. No change. I will have to take it to Best Buy
  • 360 Answers
Please unplug the TV and take cover plastic off by the power cord. Check and see if the main safety fuse is blown. If it is then replace with a 4A 250 slowblow fuse. Problems like this is usually the power supply. If problem is not solved, then a sevice repair is needed. You should also check your input signal. It might be a problem where it is not turning on the first diode allowing the TV picture to come on. Try another input device. If you open the cover to the set, in which I don't recommend unless you have TV repair experience, look around the power supply for problems.
Posted on Oct 07, 2009
  • 4 more comments
  • Richard Klein
    Richard Klein Oct 07, 2009
    Did you read the instructions from the manual? It's a safety fuse protecting the main. I'm going to take for granted that you did all of this, including batteries to the remote, and you actually hitting the power button. How much information does the blinking lights gives you. Do you think it's narrowed down to a particular item? And yes, I've seen where it was a power supply shorted problem. I need to know if your qualified to take the TV cover off, before I recommend have you do it. All I can do is have you follow the steps even though, I may all ready know the problem. Something caused it, and following the steps may help find that too.
  • Richard Klein
    Actually, if not a power board the problem more likely is a transistor that went out. Now I said, "diode," but, this TV maker what is usually a diode circuit, they simply made with transistors. These transistor circuits don't hold up as good as the diodes. But any how, I'll correct myself and say, "The traansistor is not turning on."
  • Richard Klein
    In checking the fuse you may discovered a problem with the way it is sitting in there. Allow enough power for the LEDs but, not enough to turn on.
  • Richard Klein
    Be sure to check the back light too, if qualified.
  • Richard Klein
    Most of these tv's get serviced by geek squad. Usually they replace a $350 board part/labor. The lucky ones were able to upgrade to a LG by Best Buy, due to a unsolvable problem. If you have noticed there isn't to many parts you can by for this TV. One main board, and accessories. But, there is a cable that mal-functions and goes bad, actually it burns up.
  • Richard Klein
    All the tv's with flashing alternating lights had the power supply board problem.
  • 10,515 Answers
Do you hear any sound? If not, more likely it's a Power Supply Problem on your set.
Try to unplug the Tv for few minutes. Again plug in and see if that could fix the issue. Unless you need to get it replaced or repaired.
If you wish, you can open the TV and get it repaired. Remember, it's not easy. You need to be good at electronics. You need to check all resistor's and capacitors. More likely, the faulty one would be swelled or leaked. Once confirm, you can order the board at :-
http://www.shopjimmy.com
You can also call them at their Toll Free number.
If you call a tech, the fix might cause you anyway between 200-350 bucks depending on the technician.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
  • taran_2005
    taran_2005 Oct 07, 2009
    Thanks for your response!!
    It was not a Guess. If you wish you could consult with other Experts on this Panel. Power is getting into the TV. The blinks that you could see shows that the Power is getting into the TV. This is a common issue with most of the TV's now a days.
    For every opinion, there is a reason. If you still wish, you can open and check the board. I would be glad to help you to check, if you are handy at electronics.
    Thanks.
Insignia tv light blinking red and blue
you have a faulty parts inside..try to disconnect one by one the supply of all board until you get stable lights..
Jun 14, 2012 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
Red going all through the picture
red dots or noise moving can be main signal board or power supply-is this what you are seeing?
Apr 15, 2012 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
Screen flashes on and off every few seconds
Sounds like you may need a new power supply. I found one at ShopJimmy.com and included a link. Hope that helps!
TeeVeeMan2@gmail.com
http://www.shopjimmy.com/insignia-adtv24250bb1-power-supply-unit.htm
Oct 25, 2011 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
I have a insignia ns lcd42hd 09 tv that on the left half of the screen has ghost images and sometimes vertical lines in it and i noticed when i shake it the screen goes back to normal but i have to do this...
I am also having a problem with my Insignia NS-LCD42HD-09. When I turn it on it is distorted and ghostly. It usually clears up within 10 minutes, but it can revert back at anytime. The television will be 3 year old this December. Does anyone have any advice (other than calling the Geek Squad)
Sep 07, 2011 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
Insignia NS-LCD42HD 2+ years old - color problem (getting lots of green, both composite and hdmi) - had been VERY happy with picture quality. Question should I repair or replace? (have done computer...
The TV is very low Grade considered a cheap china knockoff and the panel has gone bad as expected you need t replace the TV and next time steer clear of the non brand products (aka walmart)
Feb 12, 2018 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
Hello, I have an ns-lcd42hd Insignia TV I'm looking for the part number for the factory remote.My son lost it and I'd like to purchase a new one thank you
As for the part number... not sure. But you can purchase a new remote here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=NS-LCD42HD-09&uuid=12749564580310
May 27, 2010 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
RE; NS-LCD42HD-09 THE COLORS ARE TERRIBLE. THE
Here are some preferred settings for the same model in 32" It should get you close enough to fine tune from.
  • Picture Modes
    • Picture Mode : N/A
    • Color Temperature : Warm
    • Aspect Ratio : Wide
  • Precision Settings
    • Contrast : 60
    • Brightness : 50
    • Color : 52
    • Tint : G1
    • Backlight : 3
  • Advanced Video Menu
    • Noise Reduction : Off
    • 3DYC : Off
    • Dynamic Contrast : Off
Dec 25, 2009 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
NS-LCD42HD-09 Insignia. The power light is on, but no sound, no picture. TV is 13mths old. Best Buy junk I'm guessing, but as a electrical engineer, I'm determined to fix it myself. I think it's the power...
At least the 5VDC stand by power supply is working, there will be a control signal pin from the mainboard to the power supply board to turn on the rest of the power supplies (24vdc for the back light inverter boards, 12vdc for other circuits). Any bulging caps in the power supply?
Nov 24, 2009 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
