Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Wher can i get parts for my macbook . Like a new harddrive and new case
    Problem Solver:
  • 11 Answers
I would say use the trusty apple site:
http://www.myservice.com/?_kk=macbook%2520repair&_kt=cb7a990c-025d-4d76-9eef-e29aa2b1f7e3&gclid=CKyZlK_Ms50CFZJM5QodzReMiw
Posted on Oct 10, 2009
Backup macbook pro harddrive
you can use the OSX built in "Time Machine" and connect an external HD or even better a Time Capsule WiFi station from Apple.
Can use Apple Time Machine to restore to new MacBook Ask Dave Taylor backup-macbook-pro-harddrive-abadwnk1mj4brvvpzp1wcyyy-4-0.jpg AirPort Time Capsule 2TB
Oct 17, 2013 | Apple MacBook Pro Notebook
Tip
MacBook Pro Display housing coming off
If you don't want to spend a lot fixing your old macbook, this is an easy way to do it!
I hope it can help you.
keywords
MacBook Pro Display housing coming off fix
MacBook Pro display housing partly unattached fix
Macbook pro screen separating from the case fix
MacBook Pro unibody housing fix
Macbook Pro screen separation problem fix
MacBook Pro screen glass coming off fix
Broken MacBook Pro hinge fix
on Jan 29, 2016 | Apple Macbook Pro 13 - Brushed Titanium -...
HAVE MODEL A1237 MACBOOK AIR. THE RIGHT HINGE, IT SEEMS LIKE IT BROOK. HOW CAN I GET AND REPLACE IT MYSELF IM VERY MECHANICAL
Here is wher you can buy replacement hinges.. $150 (wow)
http://www.powerbookmedic.com/Macbook-Air-Display-Hinge-Set-p-17201.html
Here is their free instruction guide page
http://www.powerbookmedic.com/mac-repair.php They also have a send in repair service.
You might want to shop around for the hinges.. ebay??
Mar 13, 2011 | Apple Macbook Air Display Hinge Set...
How can i open my new seagate 500gb hard drive?
May be a little different, than the Seagate FreeAgent external harddrive enclosures I've opened up.
Here are for two styles;
1) Style one:
External enclosure sits on a hollow tube that ends in a base.
Turn the Seagate FreeAgent external drive over on it's top, base up in the air. The base is formed out of two parts made of plastic.
A flat part on top, and a cupped shaped plastic part underneath. (Shaped like a rectangular cake pan)
The rectangular 'cake pan' part has 4 feet on it.
The rectangular shaped part comes out of the flat base.
If you look close you will see a parting line where the two plastic parts meet.
A flat tipped screwdriver is used to pry the rectangular shaped 'cake pan' out of the flat top part.
Start in one area of the parting line, pry up a little. Move over, and pry up again. Keep going around until the rectangular shape comes out.
The flat part attaches to a hollow tube shape. Looking down there are three Philips head screws to remove. Removing them removes the flat shaped part of the base.
One on each outside edge, (Two total), one in the middle.
The flat part comes off.
Then you will see two more Philips head screws to remove. One on each side.
After removing the base, and the two screws listed above, the external enclosure comes apart in two halves like a clamshell.
The two halves have a parting line where a flat tipped screwdriver is inserted to pry them apart.
DO NOT insert the flat tipped screwdriver tip, in between the two halves of the case, more than the length of half the length of a fingernail!
It ISN'T an easy task to separate the two halves. You won't be using the external enclosure's case anymore.
Also watch your fingers! The plastic edges are S-H-A-R-P!
One half of the external enclosure's case has tabs that stick out along the edges of the case.
These are shaped like a square loop. The loop has a hollow space in it. A Female tab if you will.
The other half of the external enclosure's case has tabs, that snap into the square loops. A Male tab if you will.
The female square loops are plastic formed from the case, and can break easily.
After you open the case you'll see what I mean.
One half of the case removes. The other half has the Harddrive attached to it.
After you remove the case half, you will see a metal shield.
There are two long Philips screws that go down through the metal shield, and hold the Harddrive assembly to the other half of the case cover.
Remove them. Two on each side.
You now half to use your fingers, and a little brute force, and pry the Harddrive assembly out of the case half.
Metal shield and all.
You will see two wires, (Red and Black) that connect to the case half, and come up to a White connector that attaches to the Harddrive assembly.
Disconnect the connector from the Harddrive assembly.
Lay the case half aside.
You can now see how to remove the Harddrive from the rest of the assembly.
2) Style Two:
Shaped like a book, with one side having a taper, or slope.
I believe this explains it better than I could. It's a video.
http://www.youtube.com/watch?v=73jHstTFGFo&feature=related
CAUTION!!
I would NOT use a sharp bladed Knife!!
Use a butter knife, or a thin flat tipped screwdriver!
WATCH your fingers. There's No need to hurry, or use dangerous techniques.
Want you safe!
Post comments or additional questions in a Comment. (Believe upper right of your page)
Regards,
joecoolvette
Nov 08, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have an IOMEGA 60 GB HDD probably from 2003. Power supply input is 5V / 1A. I mistakenly plugged in 16V / 4.5A from IBM PC power Adapter. Any suggestions how I can extract data or which parts to...
Just take the drive out and put it into a new enclosure would be your cheapest option to keep it portable
I label all my PSU's with a dymo label maker to try avoid the situation you just had (fingers crossed)
Or you could insert the drive into a computer that has a suitable interface eg. SATA or IDE
May 07, 2010 | Iomega HDD External Desktop (32660) 80 GB...
What is the best mac repair shop in NYC? (need to replace harddrive of a macbook pro). Tekserve was pricey and slow last time.
Go to Macbook Repair, it's a service in NYC with good turnaround time. There are also free Macbook Repair guide that show you how to fix it yourself. The part is on Ebay.
Nov 12, 2009 | Apple MacBook Pro Laptop Computer with...
Beyond micro mobile disk BMMDU2 is not recognized
The drive USB interface may be damaged; an external case is available form various vendors for about $20. The drive should pop out and into the new case. If still not recognized, then the ID track on the drive may be compromized - that can happen if the USB is unplugged while it is still writing to the drive. There is drive recovery software out there, like EASEUS that works quite well (they have a demo that you can try free) to see if that would work.
Apr 18, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Macbook keeps restarting
http://www.retrodata.co.uk/notice_apple_seagate_drives.php
May 04, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
One Touch 4 Maxstor 750 external hard drive installing on a macbook pro
If you have a hard-drive that is formatted as NTFS which stands for (New Technology File Ssytem), Mac OS X can only read the partition. It cannot write to it.
The trick is to use your drive manfacturer's disk-formatting software which will allow you to format your drive as one large partition. Formatting your drive as one large FAT 32 partition is the easiest way to make a drive so it can be used with both PC's and Mac's.
Another option is to use a third part utility so that you can read a MAC formated harddrive's from your PC. Here is one option: http://www.macdrive.com/.
Good luck.
SeekPCRepair
Feb 08, 2008 | Computers & Internet
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
65 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
