Question about HP Compaq Presario V6000T Notebook
Computer start-up recovery fails!
The hard disk indiactor is not lit up and computer doesnot respond.
Start-up recovery starts but reports that the problem cannot be solved
  • James Young May 11, 2010
    At this point you are left with the solution of re-installing your OS. Or using the system restore disk that came with your computer. Basically something has damaged the MBR of your HDD. Insert the System disk that came with your computer and boot from the DVD/CD, when asked select restore to factory default. This will format your drive and re-install all software taht came with your computer.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 119 Answers
Hello if your in waranty ststus you call hp care and says this problem so they may send to you recovery disk of hp brand
have a nice day
you vote me
Posted on Oct 07, 2009
Model S400CA-CA006H, Power ON, only back lit blank display. Battery icon is green while the BULB icon LED is orange in colour.
  • rjsymmes has the most accurate solution. Start with a battery replacement. Next course of action is to use a Bootable Media Source (Windows Disk or Recovery Disk) to see if the laptop responds and can have the Start Up repaired. If a Boot Media fails, then examine RAM, Hard Drive removal, then boot. Last resort Motherboard.
Jun 22, 2014 | ASUS Computers & Internet
90B fan error
Start your notebook and start tapping the F2 key. In the diagnostic screen perform the hard disk diagnostic. If the diagnostic reports a hard disk smart test fail, then your hard disk is failing and must be replaced. That is the only way you will be able to return your notebook to useable condition.
If hard disk is ok I suggest you goto HP support Forums at
http://h30434.www3.hp.com/t5/Notebook-Lockups-Freezes-Hangs
Jan 23, 2014 | HEWLETT-PACKARD Pavilion dm4-1265dx...
"drive 1 wdc wd10eads 00m2B0 fail return" Add more to question pc powers up goes into widows 7 then the arrow stays on screen , for ever . And I can not boot from cd reports it can not find device ?
sounds like the Hard Disk is failing. try booting into safe mode by Pressing F8 Before the Windows 7 Splash Screen. The run diagnostics on the C Drive. Open Recovery by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, type recovery, and then click Recovery.
You can use Recovery to restore the state of your computer's system to a previous point in time, or restore the contents of your hard disk from a backup. You can also reinstall Windows from a recovery image installed on your hard disk.
Oct 10, 2013 | Dell Computers & Internet
Windows has detected a hard disk problem
you could run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to recovery any bad sectors and automatically fix any corrupt files on your hard drive there are many ways of running the chkdsk utility
click start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors or you could tick one box and wait until its finished then return and tick the other box
then select check now,start should schedule this task when restart
it will only schedule on restart if its the Primary hard drive with an operating system on it
do not do anything while the chkdsk utility is in progress any input may damage your computer
hope it helps
Apr 14, 2012 | Samsung SpinPoint M8 HNM500MBB 25in 500GB...
Windows fails to start
Is the hard disk, change the hard disk and/or the sata interface wire.
Mar 10, 2012 | Toshiba Computers & Internet
I was using D845 GVSR mother board . The issue is that the system is not getting booted up . The power is coming to the board as green LEd behind the fan in the mother bid is lit up . If I press on the...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Apr 26, 2011 | Intel D845GVSR Motherboard
1781 - disk failure problem startup for HP nc 6220
This happens if the harddisk data is corrupted.
Hard disk has a data that the computer reads first before going to the operating system. To fix this to to do a debug or do a full format of the hard drive. Try to run a diagnostics first by pressing the F9 upon the HP logo. if it does not report any error run a recovery by pressing the F11 upon the HP logo then choose the SYSTEM RECOVERY. then simply follow the prompts to revive your computer to the original factory default. Do this a couple of times. If this will not work then most likely the recovery partition is deleted or corrupted. If you can still see the HP RECOVERY IMAGE, then go to START > COMPUTER / MY COMPUTER > right click and choose MANAGE > DISK MANAGEMENT > look for the HP RECOVERY IMAGE > right click and choose > SET AS ACTIVE PARTITION, then reboot the computer then simply follow the steps for the recovery.
Apr 22, 2011 | Computers & Internet
Failes to start
try booting the computer in safe mode by pressing F8 and see if that works if that doesnot work then you need to do a windows installation kindly arrange from any computer shop
Dec 24, 2009 | Acer Aspire 3050 Notebook
Laptop will not start past loading bar.
To check if the hard disk is faulty, check the BIOS setting to see if the hard disk is detected. The BIOS may have a hard disk diagnostic utility, if so run the diagnostic.
Another way to check the hard disk. Remove the hard disk and connect it to an USB hard drive adapter, then plug it into a working computer's USB port. The computer should detect it as an external hard drive and if you can see, open the folders and files then the hard drive is OK, if not then you need a new hard drive for your laptop.
Jun 24, 2009 | Gateway T-1631 Notebook
Computer problem, help.
This generally indicates a hard drive crash/failure, in which the hard drive will need to be replaced. Rare, but occasionally you will get this error from an operating system glitch. Before you run out and buy a new hard drive, try reloading the operating system. If you have any problems during or after the install, then the hard drive is shot.
Jul 01, 2008 | Sony VAIO FRV25 Notebook
HP Compaq Presario V6000T Notebook Logo
73 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
