Question about ViewSonic VP2000s 20.1" Flat Panel LCD Monitor
Viewsonic VP2030b takes 5-10 minutes to start
It began gradually over the past six or so months, with the screen taking longer and longer to power up and display any signal after pressing the power button. Now it has come down to almost a 10 minute wait if powered on after being off during the night and I really can't stand it any longer.
Once it is running fine you can turn it off and on however you like, but if it stays off for a few minutes it will take longer to start again. Which components can act in this way and needs to be replaced? I'm thinking a capacitor that is sloooowly being brought to life or so. I read something about fuses but I don't think that's the case since a blown fuse would make the monitor not start at all, right?
While it is "booting" the little LED power indicator flickers very very weakly with a green/orange kind of spark deep down inside the LED almost only visible in a completely dark room. While turned on and not having a signal, the LED is orange like it's supposed to and green when it's finally on and displaying a signal.
I've had the monitor for more than three years now and apart from this problem it has been the best monitor I've ever had.
Any help would be greatly appreciated!
  • 80 Answers
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Follow the directions and good luck!
Posted on May 15, 2010
2 Suggested Answers
rulds2008
  • 3866 Answers
SOURCE: Viewsonic VP2030b LCD monitor - No power
There should be one fuse in the power supply inside. You can check and replace that if its dead. now if its not dead and you got power to that point you do need to rule out any capcitors at that time but if the fuse is gone it will not hurt to check the rest of the supply for the fault.
Please rate and accept the answer if it did help.
Posted on Aug 18, 2009
I have an acer aspire 5630 it has worked well for nearly 4 years, about 4 months back I noticed that the screen would be dark and slightly reddish for the first 30 seconds to a minute after turning it on...
hi
try rebooting the system (i think its F8, to get to SAFEMODE) . in DESKTOP , right click and go to PROPERTIES, go to SETTINGS, go SCREEN RESOLUTION and take the arrow to the left ; set to 640x800 and and take the color setting to 256 drop down . hopefully this works after rebooting the system. if it doesnt, it may sound like the inverter card may be bad (PC bourd that connectes to the screen : this requires a service technician)
good luck !
Dec 09, 2011 | Acer Aspire 5630 Notebook
For a long time the monitor wouldn't come on right away when the computer was in sleep mode, or hibernate. I'd move the mouse around and nothing would happen for 2 to 3 minutes - sometimes. Other...
Probably not a setting
If you are on windows : Can you change the power setting in the interim , to stop it going into hibernation - sleep mode
settings > control panel > power options>high performance should be clicked and then click change plan, PUT THE COMPUTER TOP SLEEP > NEVER
Does not solve the intial issues, but tis impossible to diagnose in this forum
Hope it helps
Apr 21, 2017 | ViewSonic VP2030b 20.1" LCD Monitor
Screen will not come on
If your screen is taking that long to turn it is a hardware issue with the screen and I would suggest contacting the manufacturer and try having them repair it at 18 months it still may be under warranty.
I hope this helped.
Thank you,
Norse
May 18, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
Gradual diming of screen over the past month.
The speaker assmbly slide out, it has two fingers on it, see pictures here on what to look for inside: http://s807.photobucket.com/home/budm/allalbums
Mar 22, 2010 | Dell E173FP 17" LCD Monitor
My screen began to take longer and longer to come on in the morning, up to 5 minutes. Then throught the day if my computer went on standby power, it would take 2-3 minutes to come back up..(and both ways...
kvons, Your monitor's behavior common to all brands not just Samsung. May need servicing by electronic technician. Read my and other tech's FIXYA profiles about solutions to BLACK screen problems and the two most common failure modes. 12fixlouie
Feb 04, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
Aug 18, 2009 | ViewSonic VP2000s 20.1" Flat Panel LCD...
Ignition will not turn on
take your car to the dealer and get a new key cut off your vin # your key is probably a many times duplicated key and, is no longer any good
Apr 21, 2009 | 2006 Saturn Vue
Samsun dpl HLN5056W
it's pretty normal for it to take up to 45 seconds for this set to fire up, could be starting to have a problem with the ballast which controls the lamp
Nov 15, 2006 | Samsung HLN5065W 50" Rear Projection...
ViewSonic VP2000s 20.1" Flat Panel LCD Monitor Logo
551 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
