Question about Kenmore 24032\24036 Top Load Washer
Kenmore washer #11024632300 fills up but then nothing happens
  • 5,911 Answers
Check your lid switch. If the washer fills, agitates, then stops at the rinse and won't drain, or if the washer does an initial fill, then stops, this is a common symptom of a lid switch malfunction.
The following link explains how to access and/or replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
If the lid switch is found to be defective, it can be purchased at any of the following websiteskenmore washer #11024632300 fills up but then noth - 2.gif:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
The part number is 3949238 and the average price is $25 to $35. Prices vary between these sites, so shop around for the best deal.
This is a very simple repair, but if you still have questions, please let me know. I hope this helps you.
Posted on Oct 07, 2009
Testimonial: "i did it! and it is working thank you soo much... you were the first to say it was a lid switch"
Fills with water and then nothing kenmore washer model 23822100 type 111
Top load machines will fill with water while the lid is open. Your problem starts when you close your lid. NOTHING happens. I believe this to be your LID SWITCH . Replace or have replaced and you should be OK. GOOD LUCK.
Jul 26, 2011 | Kenmore 23822 Top Load Washer
Model #11024632300 doesn't spin or agitate.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11024632300/0582/0153200?pathTaken=&prst=0&shdMod=11024632300
and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Feb 15, 2011 | Kenmore 24032\24036 Top Load Washer
Where is the water level switch or censor on washer model number 11024632300
See the following documents / sites:
First is the Sears Parts Site for your washer with diagrams and parts / prices:
Second is the Whirlpool / Kenmore Service Manual for top load, direct drive washers with diagnostics, testing and troubleshooting sections:
Third is an illustrated description of how to release the console and remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=0da65cea0e338fe930b1fde153a243f0
The water level switch is in the console.
Nov 21, 2010 | Kenmore Washing Machines
Timer only works on heavy cycle not on normal model #11024632300
Could be a bad timer or loose contacts.
Unplug the washer.
Open the control console.
Remove the wire harness connector from the timer and re-insert it.
Also advance your timer manually 360 degrees around several times. This can cause stuck contacts to work correctly.
If this does not correct your problem you will need a new timer.
Feb 14, 2010 | Kenmore 24632 Top Load Washer
Washer fills up then nothing else happens will not wash or spin it will fill and empty
if u hear the motor running after it fills then u need a motor coupling
Jul 21, 2009 | Kenmore 44072 Front Load Washer
Kenmore Top Loader Washing Machine
check to make sure the lid switch is closing when you close the lid. When you open and close the lid you should here a click similar to a wall light switch.
Also check the lid to make sure the tab has not broken off that actuates the lid switch, your model may not have a tab on the lid.
ask more questions is lid switch is functioning,
Jul 16, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore top load washer machine
check that none of your hoses are blocked, by pulling the back cover off. If any of these hoses r blocked it will stop the washing machine from working same thing happened to me and thats how i fixed it
Jun 02, 2008 | Kenmore 80754 Top Load Stacked Washer /...
Kenmore 24032\24036 Top Load Washer Logo
437 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
