Question about Sony DSR-1800 DV/Mini DV VCR
Error-91-1D5 playback normal but no video output and also error 3900 appears
  • 153 Answers
Microsoft suggest that we can fix error 91 by creating a new registry key. To create a new key follow the steps below:
Click on Start
Type Regedit in the search box
Press Enter
Locate the following entry in the registry HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Transaction Server
Now select the transaction server and right click on it
Select New and then choose Key
Name the key as Debug
Right click on the Debug key and choose New
Now select Key and name the key as RunWithoutContext
Ref: http://backspacetab.com/error-91/
Posted on Jul 15, 2011
  • 4,234 Answers
You indicate that playback is normal yet there is no video. Can you please explain further? I'll look up the error code tonight, but in the meantime, run a cleaning tape through the system. It doesn't take much to lose the video signal at the heads.
Stay tuned for more...
Dan
Posted on Oct 07, 2009
  • 736 Answers
A CD came with your unit .. on that CD is the service manual .. (dont need user manual) ... the service manual lists all the error codes ... if you no longer have that CD then you can purchase the service manual here
http://www.manuals-in-pdf.com/search-dsr1800+service+manual.html?&forward=plist
its about $15 at this site as a downloadable PDF
thats a very nice machine .. hope you get it going ..
Little green squares appear in video playback
Had the same problem, usually when trying to upscale video ! Try reducing size of video on laptop when using transfer software, see if that helps. With my aged laptop, problem seems to be because my laptop has an extremely slow processor chip, and it just can't keep up with the video !
The software I use, which is free, is Freemake Video Convertor, which gives you a choice of output formats and sizes.
Mar 16, 2016 | Canon ZR Video Cameras
Describe your Hitachi DZ-MV580A DVD Cant Read Discs ERROR 2881
here is the instruction manual for it,go through it carefully and u will find the sol.
Click here to download
Goodluck,
Dont forget to rate me as fixya..
Jan 31, 2008 | Hitachi DZ-MV580A DVD Camcorder
Can you please tell me how to delete individual frames without deleting everything. I have had a bad experience and don't want to repeat it. I can't find my manual....Thanks
Video clip cutting (extracting)
Display the video clip from which you wish to extract a segment.
Display the NORMAL Mode
Playback Menu (page 37), select
"EDIT VIDEO, and press the
button.
Select CUT!! and press the SET
button.
The Cutting Screen appears.
Specify the start point of the extract.
Use the procedure below to specify the frame from which the video clip extract will start.
• Play the video clip until approximately the desired point, pause the video clip, then play the video clip one frame at a time, stopping at
start point of the extract. This will be the first frame of the extract.
• If the start point of the video clip is also the start point of the extract, proceed to step 5.
Play:
After pausing playback, press and hold the SET button to the right
about 2 seconds for forward playback, or to the left for reverse playback.
Pause:
During playback, press the SET button.
Accelerated playback:
During playback, toggle the SET button to the left or right to change the playback speed.
Single frame:
After pausing playback, toggle the SET button to the right to move forward one frame, or to the left to move back one frame.
5
Toggle the SET button up.
• The start point of the video clip
extract is set, and the screen
•Specify the end point of the
extract by following the same
procedure as in step 5.
a. Toggle the SET button down.
Each time the SET button
toggled down, the sections
delete and the sections to
save are reversed.
b. Specify the end point of the extract. The frame following
end point of the extract will
the start point of the latter portion to be joined.
6
Press the VIDEO CAMERA button.
A screen appears for you to select either to save the edited video clip as a new (separate) file, or to delete the original video clip and replace it with the edited video clip.
SAVE AS NEW:
The edited video clip will be saved as a new file. The original video clip remains unchanged.
OVERWRITE:
The original video clip will be deleted. Only the edited video clip will be saved.
REVIEW CLIP:
Play back the edited video clip before saving it.
7
Select the desired option, and press the SET button.
• Editing starts.
• When editing ends, you are returned to the NORMAL Mode Playback
Menu.
I think this is what you are after if this isn't what you need you can find the manual at
http://www.retrevo.com/support/Sanyo-VPC-CG9-Camcorders-manual/id/18378dj397/t/2/
Jun 17, 2011 | Sanyo Xacti VPC-CG9 Digital Camera
RCA STA-3900 standby light on will not turn on
POWER SUPPLY BLOWN FUSE CAUSED FOR A BLOWN OUTPUT TRANSISTOR , DO YOU HAVE THE NUMBER OF THOSE TRANSISTORS??
Sep 06, 2009 | RCA Audio Players & Recorders
No sound during normal playback
make it 16-bit instead of 12 bit
Mar 01, 2009 | Canon ES75 Camcorder
I have a philips DVD home theatre system HTS8100. Its fine except that NO dvds play in synch. I have checked them on my normal DVD player & they are fine. The synch button on the remote sometimes fixes...
Synch problems on Philips machines can be caused by the video output setting.
Usually there are 3 options for video output:
  • PAL
  • NTSC
  • AUTO
PAL & NTSC force playback in that setting, regardless of DVD format, and sometimes cause a time delay in the conversion.
Try changing this option to AUTO. IF you have a modern TV, it should allow both PAL & NTSC playback.
May 12, 2008 | Televison & Video
Playback problems with previous recorded miniDV
Just check your setting and make your camera in default setting try to use the recommended tapes only
May 05, 2008 | Panasonic NV-DS55B Mini DV Digital...
Choppy recording and playback
If the heads become dirty, “NEED HEAD
CLEANING” appears during recording. During
playback, moreover, the following symptoms
appear.
≥Mosaic-like noise appears partially or the
sound is interrupted.
≥Black or blue mosaic-like horizontal stripes
appear.
When normal playback cannot be performed
even after the head cleaning
One possible cause is that normal recording
could not be performed because the heads were
dirty at the time of recording. Clean the heads,
and perform recording and playback again. If
normal playback can be performed, the heads are
clean. Before an important recording, be sure to
conduct a test recording to make sure that normal
recording can be performed.
≥If the heads become dirty soon after cleaning,
the problem may be the tape. If so, try another
cassette.
≥During playback, the picture or sound may be
interrupted momentarily, but this is not a
malfunction of the Camcorder. (One possible
cause is that the playback is interrupted by dirt
or dust that momentarily adheres to the heads.)
Mar 27, 2008 | Panasonic PV-GS150 Mini DV Digital...
No video signal
• The resolutions available for HDMI output depend on the connected TV or projector. For
details, see the user’s manual of your TV or projector.
• When the resolution is changed during playback, it may take a few seconds for a normal
image to appear.
• If you set the HDMI output resolution 720p or 1080i, HDMI output provides better picture
quality.
• If 720P or 1080i is selected, C-VIDEO, S-VIDEO and component video will not ouput video
signal. Press and hold the SUBWOOFER button on the front panel to reset the HDMI
Resolution setting.
Oct 06, 2007 | RCA RTD258 System
Sony DSR-1800 DV/Mini DV VCR Logo
191 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
